Old 10-28-2019, 03:20 PM   #57
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Unless the interior is gross and rotted e30s deserve better than lemons, at least go to chump car.
Oh interior is completely wasted and nasty. Will be tyvek suits and respirators to gut it. Lots of mice have made it home. Then it will need pressure washed out.
Old 10-28-2019, 03:21 PM   #58
@Tcoat, here's one for you on BaT but you would have to move fast..
https://bringatrailer.com/listing/19...vair-monza-15/
There are several cars on BaT right now I'd consider and they look like they will fall under $8,000.
Old 10-28-2019, 03:38 PM   #59
Don't care for the first gen. They were the crappy ones that gave the model the bad name it never could shake.
Old 10-28-2019, 03:45 PM   #60
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
One of the engineers at my first job had a Corvair turbo convertible. Not sure of the year. He also had a DeTomaso Pantera and a Ford model T that he sometimes drove to work on backroads. I always thought it was such a strange "collection" of cars. That's all he had as far as I know.
NWFRS is offline   Reply With Quote
Old 10-28-2019, 03:49 PM   #61
Didn't look at it too closely, yea I agree on that. I just noticed it was on your side of the border.
Old 10-28-2019, 08:22 PM   #62
Bluefire98
Drives: 2015 Scion FRS
5th gen prelude all the way. Base model with a manual. Not as good of a chassis but with double wishbone suspenion all around and imo a more fun engine (vtec yo), as well as a sleek body, that car is a steal at 3-4k. I miss mine. I don't think it could replace the frs since the car is fwd. But damn are they fun. Spend the extra 4k on wheels, tires, suspension, exhuast and some maintenance items, and you got yourself a solid fun dd.
Bluefire98 is offline   Reply With Quote
Old 10-28-2019, 10:09 PM   #63
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Hell yeah great looking car. I've seen a couple of them modified and I just love how they look. No bs if I would've bought that as my first car a couple years ago, I would probably still have it lol
Will BRZ is offline   Reply With Quote
Old 10-29-2019, 12:15 PM   #64
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by RToyo86 View Post
I'd like another one of those.
The problem here is finding a clean one that hasn't been killed by rust.
I know of a 2 owner one here that will be for sale soon. Florida car it's whole life.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-29-2019, 12:19 PM   #65
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by fatoni View Post
the amount of people not saying miata leads me to believe that there is a large percentage of people saying things like "drivers car" or "slow car fast" or "momentum car" solely to excuse the shortcomings of this car without appreciating the things they are speaking about.
A Miata just doesn't meet a lot of people's requirements. I would buy one for an autocross car, track car or weekend car. But not a car I'd use daily, it's just not practical enough. And since not everyone autocrosses or does track days, having a car solely for a weekend car can be a bit much (of course I have several of them but whatever).
Also every car in the world is a momentum car. No car on this planet is faster if you slow down too much for corners. Really hate that phrase used to describe low horsepower cars.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-29-2019, 12:32 PM   #66
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Low HP cars that can corner well are momentum cars. Once you modify a Corvette and a Miata with equal suspension and tires, the Miata is still passing on the Corvette on the outside. Momentum cars.
Old 10-29-2019, 12:42 PM   #67
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah I understand why people say it, but it's still true that all cars have to corner quickly to produce fast lap times. Which means ALL cars need to maintain maximum momentum through corners. Which in turn means all cars are momentum cars.
And I haven't had any Miata's out corner my stock Camaro in advanced run groups so far.
I've certainly caught up to plenty of other cars though with my own "slow" but good handling cars (like the BRZs).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-29-2019, 05:41 PM   #68
EAGLE5
Dismember
EAGLE5's Avatar
The higher the power, the later the desired apex, at least if there's a straight next. Cornering speeds may go down, but the laptime can go down too.
Old 10-29-2019, 05:53 PM   #69
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Originally Posted by daiheadjai View Post
Make sure you get a good test-drive including running it to redline.
I testdrove a 2003 Matrix XRS (I wanted the 2003 for the higher fuel-cutoff) but the thing felt like it wasn't even capable of hitting lift (it was warmed up already).
Thanks for the advice. Will keep that in mind when I attempt to look for one.
Old 10-29-2019, 06:37 PM   #70
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I know I don't have a lot of track experience and all.. but you are now talking about grip vs power. Give a 1,000HP car enough grip and it can follow the same line as a Miata. And it should if it's not grip limited putting the power down. This is also generally only the case in complex corner, in a normal corner every car will want to be full power as early as possible, low HP or high HP. I've even played with this specifically at Sebring following the so called "high HP" car line vs the "low HP" car line. My car has enough mechanical grip and I have enough throttle control to be faster on the "low HP" line. Lower laptimes/higher corner speeds through T10, and pretty much the same speeds from T11-T13 (within lap to lap margin of driver error) because the car can't overpower it's mechanical grip in those turns and at those speeds. Now the "high HP" line does allow for safety factor.. but so does driving 8/10ths. Maybe worth noting, the record lap for NASA TT2 at Sebring is a 650HP Camaro that's basically stock (tires, exhaust) and that driver uses.. the "low HP/momentum" line.
Now take a Miata and put some old terrible tires on it.. I think I'd go for the "high HP" line myself.
In many years of W2W racing I've always seen the fastest cars taking the same line.... sometimes those cars are Miatas.. sometimes they are Mustangs with V8s.. sometimes they are FWD cars..
I guess I could convince myself of a momentum car if there was a car and track out there where the car could be at top speed the entire lap only (by that I mean 1 speed the entire time) with a normal apex, never going late.. and certainly never early.
End of the day though, do whatever makes your laptimes the lowest - just don't early apex ha
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Bad ball joint;possible to just replace balljoint or do I have to replace control arm kev0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-03-2019 03:07 PM
What to replace... Skeneypoo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 06-21-2018 03:02 PM
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 02:26 PM
To replace rims or not replace? unlimited86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 23 09-21-2015 12:12 PM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
