#15 | |
ProCrastinationConsultant
i haven't seen a good answer for that
| The Following User Says Thank You to soundman98 For This Useful Post: | norcalpb (10-16-2019) |
#16 |
Drives: 2013 FR-S Series 10
Doesn't get too hot around here so even with FI there's no need for oil cooler if you're not tracking. I don't think i've seen my temps past 235, 240 degrees. Most of the time it's ~220.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#17 |
Drives: 2017 BRZ WRB with PP
Dug through some old pics pre-boost and found my coolant temp has always been right in the middle (it was 115 outside that day). Oil Temps need to be addressed.
![]() Just for grins the Pic in the owners manual... Sent from my SM-N960U using Tapatalk
#18 | |
you should be seeing a battery voltage of either 12v when the vehicle screens are on but the motor is off, or you'll see a battery voltage of 14.2-14.4v with the engine running. any deviation from 14v means there's something wrong.
#19 |
Um... It's from the owners manual.
Sent from my SM-N960U using Tapatalk |
#20 |
yes, i know, i'm just specifying not to use it as a reference for anything other than their own description, as at least one of the indicated levels is not a typical vehicle condition.
#21 | |
https://demos.starbase7.net/t3Portal...00T5102GX.html This is a good thread where I was inspired to reproduce a test of the difference between pressure at the stock port and at the tap just upstream of the mains gallery. The whole thread is a good read but if you want to cut to the chase, see post 89. I'm happy measuring at the mains. It's a convenient spot and the numbers are especially meaningful after seeing how much more the downstream pressure fluctuates with temperature. I don't bother looking at temp anymore. I can deduce it on the fly by comparing pressure against engine speed.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#22 |
Not on a 17+ the charge logic will cut the alternator at idle when hot and battery is fully charged. I see that voltage on mine all the time. It does not stay there long. This will reduce fuel usage at idle and should increase battery life.
| The Following 3 Users Say Thank You to Grady For This Useful Post: |
#23 |
Drives: 2017 BRZ
My NA 17 gets to this anytime it's over 100F and freeway driving. Hard uphill canyon driving I can get up to 250ish but not for long. I would say 200 to 220 is pretty normal. The first few pictures... Probably too hot.
#24 |
Drives: 2017 Subaru BRZ
Press and hold center button on right steering wheel control to change scale of coolant temp on gauge.
My oil temp on stock 17' can easily get past 250F. |
| The Following 4 Users Say Thank You to BRZ FTW For This Useful Post: |
#26 | |
Drives: 17 BRZ
no thats normal coolant temp if you hold the center dot on the right side of the steering wheel it will tell you that that level is 190F |
#27 |
Drives: 17 BRZ
You just push and hold for a few seconds, and the guage also adjusts to the lower mark, as in the on my dash 190F is that lower mark as shown but to everyone else without the labels on the side, their coolant temps are also or just around 190F.
But also the using the other unlabeled method the cold coolant light turns off as soon as you can see the slightest red line on the coolant section, meanwhile for me since i use the labels mine does not... |
#28 |
Thanks for that coolant gauge tip!
![]() Sent from my SM-N960U using Tapatalk |
| Engine Oil Temps after Oil Cooler | ryoma | Engine, Exhaust, Transmission | 31 | 03-23-2016 10:21 PM |
| Air temps and impact on engine load | brn12345 | Software Tuning | 0 | 04-30-2014 03:50 PM |
| Boxer engine and temps | SlinkyAvalanche | Engine, Exhaust, Transmission | 9 | 03-27-2014 04:00 PM |
| Reducing engine compartment temps | mike_ekim1024 | Engine, Exhaust, Transmission | 1 | 12-11-2013 03:57 AM |
| Normal Engine Coolant Temps? | Dezoris | Engine, Exhaust, Transmission | 1 | 04-05-2013 04:17 PM |
