Drives: white fr-s
6th Gear Whine Under Acceleration (Manual Tran)
My manual transmission have this whining noise. It occurs in 6th gear, and only under acceleration (stepping on the gas pedal). The whine is prominent between 40mph through 60mph, and faint between 70mph though 80mph. I can’t hear it from 50mph to 60mph, though it might be there; just covered up by road and tire noise. My car is
- Year: 2016 - Original Owner - Mileage: 63850miles - Transmission: Manual and original - Mods: Stock other than a TRD Door Stabilizer and a Whiteline transmission mount; but it is off the car now. Installed at around 30k miles. It added so much noise and vibration I couldn’t handle it as a daily. I removed it after 2 days of install. - Transmission fluid is Motul300, changed at 5k miles and 35k miles. Differential fluid is also Motul300, changed at 5k miles. I can’t say if the noise was there since new. I do hear it with softer music, but didn’t give it much thought. I let my coworker drive my car the other day, first thing he said was “What’s with the whine in 6th?” He thinks is bad synchro? He had a RX-8 previously. Just curious if someone else have the same/similar symptom? Is this mechanically detrimental? So far, the car has been mechanically trouble free, just regular oil change; I really hope it stays that way Thanks Update: I try to record the whine. It is the higher pitch noise. You can hear it as I step on the gas pedal, and the sound disappers as I let my foot off. Last edited by midnitz; 10-19-2019 at 12:43 AM. Reason: Update |
#2 |
Drives: 2013 FR-S Series 10
I have some gear whine at 75mph and up. Have had it since i've had the car and hasn't done any harm. Just one of those things.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#3 |
Drives: 4wd zooks
At 40mph/60kph in sixth gear it is probably labouring.
I prefer to use 5th gear at this low speed. |
#4 |
Drives: FR-S,GTI
Yeah
Stepping on the gas at 40 mph in 6th gear is not a very good thing to do. This car doesn't have a high torque V8. It has a 4 cylinder with very little low end torque. Don't do it. |
#5 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
normal...we all get gear "whine" (more like resonance) in 6th...another case of ignore sounds if the car is driving fine.
#6 |
ProCrastinationConsultant
40mph in 6th? i'm usually running 4th... i don't use 6th under 60.
| The Following User Says Thank You to soundman98 For This Useful Post: | spike021 (04-17-2021) |
#7 |
Drives: white fr-s
Maybe that's why I didnt notice the whine earlier (until my coworker pointed it out when he drove my car). I usually use 5th gear until 55mph or so. But since my coworker pointed it out, I've been experimenting, running 6th at lower speeds; trying to identify the root cause of this whine...
#8 |
don't listen to coworkers.
| The Following User Says Thank You to soundman98 For This Useful Post: | ElijahF (10-19-2019) |
#9 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I find it hilarious to suggest this car doesn't have low end torque. It's thousand rpm wide plateau of peak-torque starting in the mid 2000 range is the whole reason it's got a "torque dip" top begin with.
| The Following User Says Thank You to RZNT4R For This Useful Post: | DarkPira7e (10-19-2019) |
#10 | |
Rust bucket enthusiast
The gear whine is nothing to worry about. It's a combination of lack of sound deadening and rigidity in the transmission mounting. If anything, I love transmission whine in a car- I think it sounds awesome. Then again, I was one of those guys who drove my first car with AM radio on an empty frequency and high volume to pickup engine frequency interference |
#11 | |
this car is more lively in 6th gear at 40mph than that truck, but it's sluggish and slow in a way that i'd have to drop all the way down to 3rd move around in traffic, so it's just not worth dropping revs that much. but i also ain't care about gas mileage... the only real fix for this would be for me to build a 800hp monster, and i'd end up driving like this through traffic every day. my self control game is not very good. which is why a 200hp car is much better for me.
#12 | |
My point is, I drive in 6th between 50 and 60 KM/H all the time (2017 4.3 diff tho), On my way to work I've got a 10% grade that I take at 50 KM/H in 6th and it just digs it's heels in and goes with barely any throttle.
Not using 6th under 60 mph or thinking it's labouring at that speed is nonsense, in fact, the exact opposite is endorsed by the manufacturer. If you've got GEAR ON in the dash, you've got a little upshift arrow that flashes 3 times when the car determines it could do whatever it's doing right now, but in a taller gear. Just driving around normally with the flow of traffic, it usually flashes around 2000 rpm for me. Quote:
I've got my car outfitted with 16lb 16x7 STI wheels. |
#13 |
#14 |
Drives: 2019 BMW ///M4
Gear whine is normal on this car. There isn't much sound deadening material.
| Tags |
| differential, transmission gears, transmission issue, transmission sound, whine |
| No acceleration past 3000rpm Manual mode | 860 | Issues | Warranty | Recalls / TSB | 25 | 03-01-2019 11:35 AM |
| What's My Motor And Tran Worth??? | gtpvette | Engine Swaps | 6 | 04-17-2017 07:04 PM |
| Poor acceleration from 3rd gear | brzzy | Engine, Exhaust, Transmission | 19 | 10-15-2015 12:08 AM |
| Automatic Acceleration in Manual vs Auto modes | kavanagh | Engine, Exhaust, Transmission | 41 | 08-04-2014 09:19 AM |
| 1st gear + 0 Acceleration: Will not stall | TIE Pilot | Engine, Exhaust, Transmission | 40 | 10-19-2013 01:18 AM |
