| Engine Swaps Discussion of engine swaps. |
Drives: "Baby Gurl" of FBM
FBM drag car to 2JZ/CD009/FuelTech skreet car build
In 2014 I drove the Full Blown Motorsports R&D car during its FA20 engine development where we took it to the (once upon a time) FA20 record of 10.34.
After all the FA20 FBM parts were made the car sat in the corner of the shop with my name still on the window. I made the offer to make it mine, and with the guys at FBM basically being my brothers I brought it home. I immediately ordered a 2JZGTE non-vvti from Ichiban JDM in California as FBM had just come out with the mounts. I've been chipping away at the build for a couple years now with the help of FBM. I'm looking to Spring 2020 to be complete. Here's the list: 2JZGTE- stock rebuild with BC 264 cams FBM Parts: Engine Mounts CD009 Conversion with Clutch Masters 850 twin disc 14.1 lb. FBM spec Carbon Driveshaft by QA1 8.8 rear diff conversion with TruTrac "2JZ The World" turbo manifold FBM spec double adjustable rear coil-over kit by QA1 Double pump hanger in trunk mounted fuel cell Pure Automotive Timing belt tensioner kit Gforce Engineering Outlaw axles Borg Warner S366 Fuel Tech FT600 management The end game for the build is a 750hp street car with A/C that I can drive to work on Fridays, drag race on the weekends, and drive it home. There isn't really a class this car would fit into so ultimately I just want to send one or two automatic hotrods home on any given bracket day, drive it home and have a BBQ. Here are some recent pictures of the grind
2JZ/CD009 drag car with license plates IG: Stevemode62 Last edited by Stevemode; 10-11-2019 at 12:32 AM. Reason: Picture hosting |
| The Following 9 Users Say Thank You to Stevemode For This Useful Post: | Cookiemonster (09-07-2019), DustinS (08-12-2019), GrabTheWheel (09-07-2019), ILLSMOQ (08-11-2019), JonAvalon (08-11-2019), Kiske (08-11-2019), Sportsguy83 (08-12-2019), Summerwolf (09-07-2019), wparsons (08-11-2019) |
#2 |
Drives: FRS
That sounds so bad ass!! I think need to rethink my swap goals lol
Looks awesome man!! |
#3 |
Drives: '17 BRZ M6 & '17 Corvette Z06 M7
Good stuff, Steve. I'm jealous of that rear end!
I'm looking to do the same thing next year, with the exception of using stock instrument panel w/ PA's Motec system + harness. Though I'm torn between a drift setup I can also take and autox from time to time, or just a drag setup...both being daily drivers with A/C like yours, but no cage. Congrats on this build! Edit: Didn't read parts list and asked dumb question. |
| The Following User Says Thank You to Cookiemonster For This Useful Post: | Stevemode (09-14-2019) |
#4 |
Drives: 2013 frs red
Nice work man! I'm happy for ya
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Stevemode (09-14-2019) |
#5 |
Drives: LS Swapped Scion FRS = 440HP
KCS jr dragster in the background?
#6 |
You must have an Eagle Eye patch on your sleeve. 04 KCS we ran for a couple years when my son wasn't taller than me (now 16.....and taller than me)
2JZ/CD009 drag car with license plates IG: Stevemode62 Last edited by Stevemode; 10-11-2019 at 12:37 AM. |
#7 | |
I raced a similar 02 KCS "top fuel" up to 2006
| The Following User Says Thank You to spitsnaugle For This Useful Post: | Stevemode (09-16-2019) |
#8 |
Steve - I know you said 750hp (assuming that's on race gas, correct me if I'm wrong), but what kind of power are you expecting to put down on regular pump? E85?
Asking selfishly, as I'm trying to see what I should be expecting from 93 Oct (only 1 E85 station within 30 miles of me). |
#9 | |
Well, I'm shooting for 750 whp knowing the turbo will be the limiting factor. It may end up 730 whp or so but it'll be run on pump E85 with a flex sensor hooked up to the FuelTech to manage. Here in Minnesota we have E"85" everywhere so I haven't had a performance car on non-ethanol ever, so I'm not sure what the power limitations would be for 93 octane. I did consider trying to run non-ethanol pump, achieve power goals, and possibly cut down on the fuel pumps needed but out here that's like saying you're going to run a carburetor just because. lol. I've been working on plumbing lately, and killing time with fittings and $100 Jegs orders to save up for the spendy axles.
2JZ/CD009 drag car with license plates IG: Stevemode62 Last edited by Stevemode; 10-11-2019 at 12:38 AM. |
| The Following User Says Thank You to Stevemode For This Useful Post: | wparsons (09-23-2019) |
#10 |
More details being done.. Recently the Corbeau seats and brackets fitted (brackets from a 240), and the connection from internal slave to MC.
Also completed the heater hose re-route that Clash0901 did in his build thread. Thankful for that top tip for sure. It's done, and the Outlaw axles from Gforce are in the works!
2JZ/CD009 drag car with license plates IG: Stevemode62 Last edited by Stevemode; 10-11-2019 at 01:03 AM. Reason: added clear photos |
#11 |
Drives: 2016 Ablaze FRS
How close are the 240 brackets?
Parts for those are so much cheaper. |
#12 | |
I used some stepped coil-over brackets and bolted them to the factory floor. The stepped up brackets helped keep the sliders clear of everything. Then I set the seats on top and checked the seat position to the cage. Swiveled the brackets to the most ideal location and spot-welded them when the seat was in place. Finish welded them and painted. P.S. Can someone let me know if the pictures are coming through all jacked up on this thread? It's been so long since I posted pics on a forum I'm still using free Photobucket.
2JZ/CD009 drag car with license plates IG: Stevemode62 Last edited by Stevemode; 10-11-2019 at 01:05 AM. |
#13 |
Drives: 2017 Toyota 86
#14 |
Drives: 13 White MT FR-S
Uploading the pictures to the site has been the easiest way for me. I really want to see too!
| The Following User Says Thank You to ML For This Useful Post: | Stevemode (10-11-2019) |
| CD009 350Z Transmission into FT86 Swap | xoBethxo | Engine, Exhaust, Transmission | 26 | 07-02-2019 11:39 AM |
| 2JZ VVTi With CD009 Mounts Are Complete! | Pure Automotive | Engine Swaps | 4 | 02-15-2018 02:30 PM |
| NOW AVAILABLE!! PURE 2JZ VVTI W/ CD009 TRANSMISSION MOUNT KIT FOR FRS/BRZ/GT86! | Pure Automotive | Engine Swap | 0 | 02-15-2018 10:51 AM |
| June 7th after Perrin meet drag racing at Portland Raceway or watch us drag! | stockysnail | Northwest | 15 | 06-08-2014 02:08 PM |
