Old 10-08-2019, 05:01 PM   #15
pevsfreedom
Drives: 2014 BRZ
Obligatory "IT LIVES" video:
pevsfreedom is offline   Reply With Quote
Old 10-08-2019, 05:05 PM   #16
pevsfreedom
Drives: 2014 BRZ
Right now trying to find location of ignition coil D and wiring (found it).
Old 10-08-2019, 06:57 PM   #17
pevsfreedom
Drives: 2014 BRZ
We got it. Injector coil was bad. No lights no hiccups!
The Following 3 Users Say Thank You to pevsfreedom For This Useful Post:
Lantanafrs2 (10-09-2019), mrg666 (10-08-2019), soundman98 (10-08-2019)
Old 10-08-2019, 07:18 PM   #18
mrg666
pessimistic skeptic
mrg666's Avatar
Congrats! You did a great job with replacing the engine and figuring out the problem.
The Following User Says Thank You to mrg666 For This Useful Post:
Old 10-08-2019, 07:45 PM   #19
pevsfreedom
Drives: 2014 BRZ
Thank you! Can't believe it all worked out.
Only trouble now is it idles a bit rough - just wondering if it needs time for all the liquids to circulate around properly. Drives smooth.
Old 10-09-2019, 01:39 AM   #20
pevsfreedom
Drives: 2014 BRZ
So it continues to idle roughly, some lights came on and it went back into "limp" mode, I unplugged the battery and that went away. It's overall very jerky, and vibrating quite a bit. At low RPMs it seems to stutter pretty severely. No codes since. Not sure what's up.
Old 10-09-2019, 01:57 AM   #21
If you're lucky, the engine is just relearning after being unplugged. If that's the case it will straighten up after several miles.
CONGRATULATIONS on YOU learning -
Old 10-09-2019, 03:30 AM   #22
pevsfreedom
Drives: 2014 BRZ
Lol, thanks. I am grateful to actually have swapped it out (was terrified).
Lights back on, which I take as a good thing cause I have something to go off. Either way I think I just need to bring it into a shop so they can plug it in and check all the systems. I'm sure it's in some sort of shock
Old 10-09-2019, 05:45 PM   #23
pevsfreedom
Drives: 2014 BRZ
Codes showing are P0301 P0300 P219A P119F P119E; I think I just need to replace the other 3 coil packs and we'll be in business, I hope.
Old 10-09-2019, 07:01 PM   #24
Those codes are a mix of misfire on cylinder one and airflow and exhaust sensors. Throwing coil packs at it probably is not the answer.
Old 10-09-2019, 08:48 PM   #25
Lantanafrs2
Drives: 2013 frs red
I would check all intake connections (hose clamps), clean maf sensor. Did you install intake manifold? Those orings can be a challenge
Lantanafrs2 is offline   Reply With Quote
Engine / Tune Issues 1Botnet Engine, Exhaust, Transmission 4 09-05-2018 05:10 PM
Any issues installing FA20 Auto Engine into Manual Car jamison884 Engine, Exhaust, Transmission 1 10-16-2017 09:21 AM
Is this engine or tranny issues? 86Hiro Engine, Exhaust, Transmission 9 09-23-2015 02:51 PM
Toyota FTS report engine issues with FR-S running 91 octane DYOLF26 Issues | Warranty | Recalls / TSB 24 08-06-2012 01:22 PM
Any issues with Subaru engine? CyberFormula Engine, Exhaust, Transmission 10 06-26-2010 05:02 PM
