#15 | |
Drives: 13 Scion Frs
Yeah I originally thought it might have been an exhaust leak as well, but he checked around the exhaust for any leaks and couldn't find any. That and from what I can tell an exhaust leak would affect mpg and wouldn't cause the issue of it not turning over any longer, right? I was rockin a nice 35mpg with all the highway driving I'd been doing. |
#16 | |
You may have a couple of unrelated issues going on so it would not be your starter noise.
#17 | |
Just stopped by the shop and we tried turning it over, sounds like the starters just not engaging. I'm betting when it's cracked open something got damaged in there and thats what I heard break off. |
| The Following User Says Thank You to Alfrz91 For This Useful Post: | Tcoat (10-02-2019) |
#18 |
Drives: car
#19 |
Sounds like a loose/damaged flex plate. Probably took out some other stuff after being driven that way for so long.
![]() That first video with the sound under acceleration is a real tell. Something's getting tweaked out of line and colliding with the block or bell housing.
#20 |
#21 | |||
video of the rattling from inside of the car after a cold start. The rattle is occuring anytime I move it out of park, but also happens on first start up. https://www.ft86club.com/forums/show...73#post3208473 I wish I knew what actually happened in this situation, because it sounds like the same exact thing as mine. Quote:
Unfortunately set pins doesn't mean much to me. Last edited by Alfrz91; 10-08-2019 at 10:38 AM. |
#22 | |
#23 | |
Flexplate cracked again, thinks I could have a bad transmission, or unbalanced crank. Also it was noticed that dowel pins were missing. From what I can tell from my limited google-ese, they're to align the tranny to the motor, I would imagine they would also limit the play going on. |
#24 | |
F
#25 |
To be faaiiirrrr it's a really reputable and popular shop, the two dowel pins are supposed to be in the engine from my understanding and not come out. For whatever reason it seems like a crapshoot of whether they come out during the removal and stay in the transmission I guess. He didn't lose them, the motor came without them in. These aren't the pins that would go on a flywheel, they're literally pressed into the engine block.
#26 | |
They fall out all the time. It's a thing.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (10-11-2019) |
#27 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Yeah it's a toss up wether they stick to the engine or trans when you separate both. Whenever I replace an engine or trans for a used unit, there can be two, one or none at all, and yeah it's pretty important to have them in.
I'm surprised a mechanic would forget them since they make mating the engine to the trans way easier by lining everything up. You align those and the two big puzzle pieces just snap together and every bolt hole lines up perfect. Would be a pain without those. Btw, I'm not sure if I'd be confident in that engine anymore, if the transmission was misaligned enough to break the flex plate, it probably put a lot of stress on the rear most crank bearing especially during startup with no lubrication. I wouldn't be surprised if the rear main was scored from having the crank wedged off axis. |
| The Following User Says Thank You to RZNT4R For This Useful Post: | Ultramaroon (10-12-2019) |
| ticking sound with el header install. | fluffy-reindeer-slayer | Engine, Exhaust, Transmission | 10 | 05-11-2021 01:13 AM |
| Ticking/rattling after engine install, turns into...? | Alfrz91 | Engine, Exhaust, Transmission | 0 | 10-01-2019 01:18 AM |
| Ticking/Rattling noise at idle. | Razgriz | Issues | Warranty | Recalls / TSB | 4 | 08-17-2017 09:02 PM |
| Ticking/Rattling coming from steering column/gauge cluster | Imprezzave | Issues | Warranty | Recalls / TSB | 24 | 09-17-2016 09:38 AM |
| Engine rattling sound like bogging the engine when not. | stockysnail | Engine, Exhaust, Transmission | 6 | 09-15-2016 12:57 PM |
