Old 09-29-2019, 05:37 PM   #15
Lantanafrs2
Drives: 2013 frs red
But the a.t. is too slow
Lantanafrs2 is offline   Reply With Quote
Old 09-29-2019, 05:51 PM   #16
It chicks when you flick it just right with two fingers.
spike021 (09-29-2019)
Old 09-29-2019, 06:12 PM   #17
spike021
spike021's Avatar
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 09-29-2019, 07:11 PM   #18
Jordanwolf (09-29-2019), spike021 (09-29-2019)
Old 09-29-2019, 07:40 PM   #19
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
ac unit kicking in
thomasmryan is offline   Reply With Quote
Old 09-30-2019, 02:14 PM   #20
Chikna
Drives: 2018 BRZ TS 244/500
I was told all manual cars make a lot of noises nothing to worry about. Even though I have been driving over a year noises are still there. One thing to note 1st to 2nd gear is always a pain in the b*** especially from the cold start.
Chikna is offline   Reply With Quote
Old 09-30-2019, 04:11 PM   #21
g e
Well mine does have a whine from the tranny.
Buy it a drink.
g e is offline   Reply With Quote
The Following User Says Thank You to g e For This Useful Post:
Tcoat (09-30-2019)
Old 09-30-2019, 04:20 PM   #22
Lantanafrs2
Just need a louder stereo. Then I wont hear the throw out bearing, direct injectors, fuel pump, rocker arms, shift linkage, dash creaks, road noise, suspension crackles, differential groan.....
Old 09-30-2019, 04:31 PM   #23
All MTs do make sounds when you shift. People that are used to FWD or AWD just don't hear them since the transaxles are located up ahead of them. The MT in this car is only a couple of feet down and directly in line with from your ears. Add in the fact that it has tissue paper for insulation and the result is you hear every little snick and click. You also get more noise since the shifter is directly attached to the tranny instead of through a bunch of cables or rods that all absorb the sounds.
When the tranny is cold just go neutral to second give it a blip and up into first. Works every time for me.
soundman98 (10-01-2019)
Old 09-30-2019, 04:32 PM   #24
Originally Posted by g e View Post
Buy it a drink.
Prefers crack.
Old 09-30-2019, 05:11 PM   #25
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by Joshua.Staskus View Post
Hey everyone, new to the forum and a new Subaru owner.
After a year of ownership you will look back fondly on this experience and think, "Remember when I was concerned about that chick noise? If I only knew then about the noises it would make later!"
I'm approaching six years of ownership, and mine is still coming up with new and interesting sounds.
The Following 3 Users Say Thank You to extrashaky For This Useful Post:
Lantanafrs2 (10-01-2019), Spuds (09-30-2019), Tcoat (09-30-2019)
Old 09-30-2019, 05:30 PM   #26
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I remember when I was worried about the throttle body sound when blipping the throttle on downshifts...
soundman98 (09-30-2019), Tcoat (09-30-2019)
Old 10-01-2019, 12:35 AM   #27
Lantanafrs2
Need a thicker inlet tube. Run smoother and gain 5 horsepower too.
Old 10-01-2019, 01:09 AM   #28
Spuds
The Dictater
Spuds's Avatar
I can't tell if you are serious, but I haven't heard it since I installed my Perrin tube and a high flow filter, so... Yeah.
I did get +5hp too, but that was definitely from the sticker I added at the same time.
Lantanafrs2 (10-01-2019), soundman98 (10-01-2019)
K Sports making noise? Brentkeys1814 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-22-2016 07:24 PM
Grinding noise when shifting into 4th wise345 Issues | Warranty | Recalls / TSB 4 04-19-2016 12:53 PM
Whirring Noise When Shifting? Joe-G Issues | Warranty | Recalls / TSB 3 03-01-2015 02:23 AM
A clunck noise when shifting jflogerzi Issues | Warranty | Recalls / TSB 3 09-09-2013 01:16 PM
Ballast Making Noise remorse87 Cosmetic Modification (Interior/Exterior/Lighting) 7 10-24-2012 11:35 PM
