Old 09-21-2019, 08:16 PM   #1
bulldog11267mad
bulldog11267mad's Avatar
Drives: 2013 BRZ Limited manual
Alternative brz transmissions
Hey guys I’m looking for alternative manual transmissions for the brz. I’m making 500whp and need something that will hold up. Of course cheap would be great but the most important thing would be strength. I would like a list that have been swapped and what people thought of each one. Thanks for any info
IAG built stage 3 block, HKS camshafts, built and tuned by national speed. 1050 ID injector, garret GTX3071 93 octane 415whp, E85 524whp monster! Quaife QBE69G sequential transmission!
bulldog11267mad is offline   Reply With Quote
Old 09-21-2019, 08:17 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
CD009
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
The Following User Says Thank You to Joveen For This Useful Post:
rixter145 (09-26-2019)
Old 09-21-2019, 08:26 PM   #3
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
TKO600
since you are doing fab work anyways
or a T-56
the CD009L also gets a vote here but its HUGE
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
Tristor (09-21-2019)
Old 09-23-2019, 03:16 PM   #4
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
Originally Posted by Joveen View Post
CD009
+1 for this!
eastendraceshop is offline   Reply With Quote
The Following User Says Thank You to eastendraceshop For This Useful Post:
Old 09-23-2019, 11:19 PM   #5
solidsnake11
Drives: brz
Originally Posted by eastendraceshop View Post
+1 for this!
+2 here is mine, plus I have the 4wd cd009 in my Samurai.
https://www.ft86club.com/forums/showthread.php?t=135294
solidsnake11 is offline   Reply With Quote
Old 09-23-2019, 11:24 PM   #6
solidsnake11
Drives: brz
Rattles like crazy with a solid hub clutch.
Make sure it doesn't hit the body anywhere. It's 10x times louder if it touches.
Shifts great, huge gears inside, cheap at the junk yards, shorter than Oem and if you give up on the fa20, bell housings are available for 2jz, sr20, and LS style engines.
Old 09-23-2019, 11:34 PM   #7
solidsnake11
Drives: brz
Make sure you get the Cd009 or newer. They have the better syncronizers.
Old 09-26-2019, 09:13 PM   #8
bulldog11267mad
im thinking about going all out and doing a sequential.
Old 09-27-2019, 02:18 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
sequential boxes with straight cut gears can handle loads of torque and gear switch is bliss .. but imho will make car not DD usable. Very loud gear whine .. i'd be ok with such on track, but certainly not hearing all the time, especially in long drives.
jeepmor (10-16-2021)
Old 09-27-2019, 03:00 AM   #10
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Hmm deep pockets I see.
Old 09-27-2019, 03:02 AM   #11
Irace86.2.0
https://www.mazworx.com/mazworx-favq...t-frs/brz.aspx
Old 09-28-2019, 09:29 AM   #12
bulldog11267mad
They have helical cut gear options that will easily handle my power plus another 300hp. That would pretty much eliminate the gear whine. My car is not a daily driver and hasn’t been for awhile. I always wanted a sequential but never thought to much about them because I had no need for one but now that I have to do something with the trans I’m seriously thinking about it.
Old 09-29-2019, 05:43 PM   #13
TeaFee
Drives: 2017 BRZ - Manual
This what I wanna eventually put in mine:
https://www.jackstransmissions.com/t...romesh-gearset
It's still helical but slightly less than stock.
TeaFee is offline   Reply With Quote
Old 10-24-2020, 09:40 PM   #14
bulldog11267mad
It’s been awhile. I ended up going sequential with a Quaife 69g. A few things had to be modified to make it fit in the car. The transmission works great! The harder you ouch the car the smoother the shifting is.
The Following 3 Users Say Thank You to bulldog11267mad For This Useful Post:
Irace86.2.0 (10-24-2020), NoHaveMSG (10-26-2020), WildCard600 (10-25-2020)
Makes me sad (manual transmissions in US) covance Other Vehicles & General Automotive Discussions 20 05-12-2016 10:15 AM
Transmissions concerns M/T - is this normal? mstoochn Issues | Warranty | Recalls / TSB 27 05-28-2015 08:10 AM
OpenFlashTablet for Automatic Transmissions paddleshifter Software Tuning 41 05-01-2014 07:45 PM
What other engines fit our transmissions 1strwdcar Engine, Exhaust, Transmission 36 08-02-2012 05:45 PM
The BRZ / FR-S / GT 86 transmissions and driveline: what we know so far jruhi4 Engine, Exhaust, Transmission 25 02-17-2012 04:33 PM
