#15 | |
They didn't have tests done that say all is fine.
Your tests are fine. You have over 5,000 miles since the work was done. Relax!
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Grady (09-20-2019), soundman98 (09-24-2019) |
#16 |
Rust bucket enthusiast
The issue that blew out engines were not things in the oil, they were insolubles that clogged passages for that very reason.
He's also curious as to why when you're being told test results, you don't believe the report. Don't ask for help if you don't want it
#17 |
Drives: Toyota Celica
Not believing and getting 2nd opinions are two different things. This is all i'm doing. There are very knowledgable people on this board I appreciate and trust. All I did was share this information and with you to verify. Thanks
#18 | |
My comment is that you have a valid test result from a respected company that says "No problem". Looking for support or rejection of that report from a bunch of guys with dubious qualifications is not going to help anything.. My suggestion is to take that good report, relax and enjoy your car. The oil looks good, you have 5K trouble free miles and no issues. Fretting and second guessing some slightly elevated silicon results isn't going to get you anyplace.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#19 |
| The Following User Says Thank You to Grady For This Useful Post: | soundman98 (09-24-2019) |
#20 | |
Drives: 13 BRZ Limited
I too had high silicon (94) and Iron (24), and I was also told this was normal. Silicon in the oil isn't what causes problems post recall. Chunks of silicon breaking off causes the failure. Silicon trace in the oil is from offgassing, which will occur any time new silicon is used. I think we're gonna be ok man. https://imgur.com/a/EveNAmj |
#21 | |
They did recommend, however, I should do another one to check for bearing wear, which may be a sign of trouble. |
#22 |
TRACKBREAD
Post Recall Blackstone Report
My post recall test came in pretty clean, only 2000 miles though
#23 | |
Drives: 2013 FR-S Series 10
https://www.blackstone-labs.com/the-...ljinbhlr1))%2f Interesting write up here for OP. |
#24 | ||
| How long is too long for post-recall repair? | ndsleep612 | Issues | Warranty | Recalls / TSB | 2 | 08-04-2019 06:35 PM |
| HORRIBLE GAS MILEAGE POST RECALL (ಥ﹏ಥ) ¯\(°_o)/¯ | mswbrz | Issues | Warranty | Recalls / TSB | 14 | 08-02-2019 06:38 PM |
| Loud ticking post recall fix | Outlander | Issues | Warranty | Recalls / TSB | 27 | 07-16-2019 01:11 AM |
| She lives once more! (post-recall damage) | BlackOptics | Northwest | 9 | 03-22-2019 07:53 AM |
