Old 09-17-2019, 08:29 PM   #15
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
The fix for harmonic dissonance is all based with acoustics.
I had this issue with my catless headers and a muffled track pipe for the tip. The volume and sound was decent but the "buzzing" in my head was atrocious.
The fix is a 1/4 wave or "j pipe" using the helmholtz effect to your advantage.
Without getting into the gritty you need to measure which frequencies are most prodominate at whatever rpm you feel and then punch in some math (lotta math..) and youll get what size of pipe, the wall thickness and the length of pipe to weld on the side of your main tube. and that would help.
You can booger it slightly by using a chambered muffler with a length of pipe. Off the top of my head something like a 4 inch pipe at 2.25 ID at standard 0.065 wall thickness would need a 6 inch/8 inch chambered muffler to quiet anything from around 2-4k rpm
Clutch Dog is offline   Reply With Quote
Old 09-17-2019, 08:33 PM   #16
Ernest72
I used dynamat and foam ensolite everywhere in the trunk area and I still have plenty of drone with invidia q300 which is supposed to be quiet. It’s not. I have a resonator in the mid pipe, still drone. Even had a helmholz resonator, still drone. These cars are tinny and noisy, but fun.
Old 09-18-2019, 12:21 AM   #17
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Originally Posted by Contender View Post
You don't put it on the exhaust you put it under the back seat and trunk area inside the car.
I know that but it specifically says for pipe use and it's in the name. Knowing some of the people on this forum, they might not read between the lines or the fine print.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 09-18-2019, 01:09 AM   #18
gpvecchi
gpvecchi's Avatar
Many thanks to all, I was thinking that it was just resonance, I think I have to live with the noise. I'm probably just getting too old...
Old 09-18-2019, 11:58 AM   #19
Clutch Dog
It got so bad on my car I went back to the stock muffler.. and i cried a little on the inside..
Old 09-18-2019, 12:24 PM   #20
You will get used to it. Then when you drive something else it will sound weird.
Old 09-18-2019, 12:46 PM   #21
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Just turn the music up.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-18-2019, 12:48 PM   #22
Then, when you get a bit older, you won't hear it anymore -
Old 09-18-2019, 01:56 PM   #23
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Originally Posted by jsimon7777 View Post
No, sound insulation won't do much. Your resonance comes from the exhaust, not the trunk.
That's not entirely accurate. Yes, the exhaust will resonate at whatever frequency it decides to (based on your specific configuration), but the interior of your car also can act as a resonating chamber (no differently than, say, a subwoofer enclosure) and when your exhaust hits the resonating frequency of the body, you can get some pretty awful drone.
Case in point: My car. I have a very unique exhaust combo on my car at the moment, and there are VERY big differences in the volume inside the cabin depending on the interior configuration. With the rear seats in their normal configuration, the cabin is relatively quiet. If I fold the rear seats down, I get some pretty significant drone around the 3-3200 RPM range. However, if I open the windows, most of that drone again goes away. None of that has to do with the exhaust configuration. It has to do with the "enclosure" in which those sound waves are bouncing around.
I have a thick slab of Luxury Liner Pro (like 1/2" thick, closed cell foam) that I slid behind the rear seatback felt. Not sure how much that contributes to the relative silence with the seatbacks up (as compared with the seatbacks up but WITHOUT that foam) but the point there is a lot more to interior resonance than JUST the exhaust setup. Obviously, a quiet, non-droney exhaust setup will prevent the issue in the first place, but if you do have a droney exhaust, your interior setup can be the difference between a quiet ride, or a miserable one.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 09-18-2019, 06:46 PM   #24
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
deadening. there's another fucking e in the word!
Excuse me while I bish slap you for being a dusty hoe , leave the mate alone for fucks sake !
mswbrz is offline   Reply With Quote
Old 09-18-2019, 07:29 PM   #25
Originally Posted by Stang70Fastback View Post
............….your interior setup can be the difference between a quiet ride, or a miserable one.
Yep, I found that the exhaust sound when the trunk is empty is one level of sound in the cabin, but, when we travel and the trunk is full, the interior of the car is significantly quieter.
And, that is a good thing; so I can clearly hear mrs humfrz's comments on my driving:
* I didn't mean to scream, but I didn't know if you saw that car coming.
* why didn't you park there?
* why do you always park so far away?
* why do you always park so my side is next to a curb?
Just to name a few -
(then she wonders why I don't take her out more often)
Old 09-18-2019, 08:12 PM   #26
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
God damn. The drone of whining in this thread (not OP) is stunning.
Old 09-18-2019, 08:49 PM   #27
solidsnake11
Drives: brz
This helped with my tomei 80. 16 inch vibrant.
solidsnake11 is offline   Reply With Quote
Old 09-19-2019, 07:02 AM   #28
Stang70Fastback
A.K.A. Starlord
Exactly. I've noticed if I have the trunk loaded a certain way, I can get interesting beat frequencies from my exhaust sound, lol.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
humfrz (09-19-2019)
WHAT IS THIS SOUND? alexdrums Engine, Exhaust, Transmission 4 03-18-2019 11:49 AM
Does this sound deal sound decent ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 29 11-21-2015 10:02 AM
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 01:04 AM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 09:57 AM
Sound - ASL ScottKR Electronics | Audio | NAV | Infotainment 0 07-01-2013 10:34 AM
