Old 09-08-2019, 08:15 PM   #4117
Mr_Eyo
Drives: 2017 Toyota 86
Has anyone tried running 295/30R18 on a 18x9.5 +45 rim in the back? I'm currently running 255/35R18 on a 18x8.5 +45 rim and have Tein Flex A CSG's with about 0.4" drop and have had no issues so far. It looks like there's about an inch of room left before the 255 touches the springs, but that was a guestimate on a lift at full droop.
Mr_Eyo is offline   Reply With Quote
Old 09-10-2019, 12:45 PM   #4118
Leonardo
Country Boy 4 Life
Leonardo's Avatar
IMO a 295/30 is too big for a 9.5. It BARELY fits on a 18x10"
http://www.ft86club.com/forums/showthread.php?p=2243491
http://www.ft86club.com/forums/showt...=41083&page=77
I LIKE TIRES!
Old 09-10-2019, 11:01 PM   #4119
jRuN
ESR SR05 18x9.5
Just picked up the wheels and have some BC Racing DS coilovers on the way. What would be the widest tire I could safely run without fitment issues?
What about if I were to get the fenders rolled?
Anyone know if any of the BBKs would fit behind this wheel?
Thank you for the help!
Sent from my Pixel XL using Tapatalk
jRuN is offline   Reply With Quote
Old 09-11-2019, 02:03 AM   #4120
Mr_Eyo
Thanks for the links! It looks ok, but I think I've settled on 275/35.
Old 09-11-2019, 08:25 AM   #4121
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I would read through this thread.
https://www.ft86club.com/forums/showthread.php?t=41083
265/35 is the largest most guys run. Then because of diameter, most do not run a 275/35, and go straight to a 285/30. (which is really close to stock diameter.
Additionally, they are also running a little bit lower offset 18x9.5 wheels, like +38.
Good luck.
I LIKE TIRES!
Old 09-20-2019, 08:50 AM   #4122
86TOYO2k17
Drives: 2017 toyota 86
anyone know if 17x9 +45 with a 255/40r17 tire will have any fitment issues in the rear on stock suspension or lowered on RCE yellows?
Old 09-20-2019, 09:31 AM   #4123
Vital
Drives: 2015 BRZ
Yes, it will rub in the front with stock struts. Might want to look into a +35 offset or coils or you can run a 3-5mm spacer up front
Old 09-20-2019, 09:32 AM   #4124
86TOYO2k17
I know about front. Specifically asking about rear.
Old 09-20-2019, 09:35 AM   #4125
Vital
Drives: 2015 BRZ
Oh sorry didnt read your post correctly. Yes, rear will fit fine.
Old 09-20-2019, 10:35 AM   #4126
86TOYO2k17
ok thanks, ill probably give it a shot, i got a 4mm hubcentric and wheelcentric spacer i am going to use in the rear so i can still get some slight camber in the rear.
Old 09-25-2019, 02:08 PM   #4127
Leonardo
Country Boy 4 Life
Leonardo's Avatar
You may already know...
3mm is the thickest spacer recommended for OEM length wheel studs. But, I have read a few posts where guys are running a 5mm spacer on stock length wheels studs without any issues. Still, I would recommend ARP extended studs.
I LIKE TIRES!
Old 09-25-2019, 02:33 PM   #4128
86TOYO2k17
That is why I'm using a very uncommon 4mm spacer, which i heard leaves enough turns/threads to be fine and that 5th mm is what puts it over the top to not have enough.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Leonardo (09-25-2019)
Old 09-25-2019, 05:04 PM   #4129
lumbeardjack
lumbeardjack's Avatar
I got the wheels finally! As soon as I figure out how to post pictures I will throw them up.
I got the Focal F55 wheels in black, 17x8 and left the tires on and they stretched. Looks great but idk about the tires with winter coming and all of the curbs on my daily commute
lumbeardjack is offline   Reply With Quote
Old 09-26-2019, 11:22 PM   #4130
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Is it true that tire size 225/40/18 has a difference of 0.47 in. (1.9%) from stock diameter while the larger tire size 245/35/18 only has a difference of 0.13 in. (0.5%)? I was on this tire size calculator website and found that pretty interesting. I’ve decided on wheel choice finally just debating 17s or 18s. I’d like to stay as close to stock as possible for speedometer accuracy, overall height etc.
Will BRZ is offline   Reply With Quote
The Following User Says Thank You to Will BRZ For This Useful Post:
Leonardo (09-26-2019)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
