#15 | |
Drives: 2017_86 2016_frs 2007_335i
wow, that a lot of info u just posted i will try my best to answer i am doing autox around 10 and 4 or 5 track day per year my local track is main in 2sec and 3 gear with high rpm up shift and down shift a lot. and i do the heel and toe every single time when the water temp is up it is still a stock engine with drop in air filter and a intake tube the climatic is around 0-30 all year, usually have the track day around 20-30c my car is 2017 86 base,so i did not get any data. but my buddy who is always track with me got 17 brz with the oil temp and coolant temp he said the oil temp is very stable but the coolant is the one where he is keep eye on it. every time i am back from track, i feel the car exhausted. not smooth as usual, the gear box too. it will became normal after a few days that is reason i am looking for the oil cooler and i just bought the obd2 "mx+" to see the data. and will install it after that to compare. the jackson racing na oil cooler has the "Thermostatic Oil Adapter for Proper Oil Warm Up" which should good for the warm up oil here is the link for the part http://jacksonracing.com/product/fr-...il-cooler-kit/ any suggestion at my situation ?
YouTube Video:http://www.youtube.com/channel/UCBXFeelPFI8XzGese8Eug-g
ins:zayliu.jiayu Build Journal:http://www.ft86club.com/forums/showthread.php?t=136068 "if in doubt flat out" Last edited by jayliu.jiayu@gamil.com; 09-09-2019 at 05:06 AM. |
#16 |
Will it work, yes, is it what you need, maybe?
What temp is the thermostat?
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#17 |
Drives: 2017 BRZ Premium
I have the mishimoto oil cooler with thermostat on my 17brz and everything fits as it should. OE Airbox with blitz filter and perrin tube
#18 |
any leak on the mishimoto one, people said their part has the high choice on oil leak, that y i went to jackson racing
ins:zayliu.jiayu Build Journal:http://www.ft86club.com/forums/showthread.php?t=136068 "if in doubt flat out" |
#19 | |
dont know much about the machine, just going to trust them. which i always pick the big brand to help me avoid any failure.
#20 |
GReddy and Jackson Racing.
#21 |
Shop smart
#22 |
yep, and all the support from people in here is wonderful.
#23 |
jackson racing na oil cooler ordered
#24 | |
Drives: 2005 Toyota Camry
So 2013-2016 is one kit, 2017+ is another. Obviously does not matter for your purposes but will matter for OP. |
#25 |
#26 |
Drives: 2017 toyota 86
Anyone know where to get a higher thermostat to swap into the mocal
Thermostat plate? Preferably 195-205F or 90-95C range. Temps aren’t getting hot enough with the 180F thermostat. |
#27 |
#28 | |
Or what is the Delta pre and post cooler on say JR Oil Cooler kit? I get to about 155F in close to same time as before but after that it takes forever to get to even 170F in 60F ambient temps. But if its a 15+ degree pre and post difference then maybe reading 170F on OBD would be fine. |
| SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge | tws98 | Engine, Exhaust, Bolt-Ons | 0 | 05-28-2019 10:50 PM |
| Oil Cooler Options for 2017 Manual BRZ 86 | TofuJoe | Engine, Exhaust, Transmission | 12 | 09-21-2017 11:26 PM |
| 2017 BRZ and Perrin Oil Cooler Install | JSube | Tracking / Autocross / HPDE / Drifting | 18 | 04-29-2017 07:49 AM |
