Old 09-07-2019, 03:00 PM   #1
jayliu.jiayu@gamil.com
jayliu.jiayu@gamil.com's Avatar
Drives: 2017_86 2016_frs 2007_335i
best oil cooler for 2017 airbox?
hi guys
anyone had the experiences on oil cooler with the 2017 air box
was thinking to buy the perrin one, and it is not fit when i check there website. any other opinion?
jayliu.jiayu@gamil.com is offline   Reply With Quote
Old 09-07-2019, 09:01 PM   #2
PulsarBeeerz
Drives: JRSC BRZ SOLD
I know the Blitz oil cooler fits the MY17 airbox as I have a newer airbix one on my MY13.
PulsarBeeerz is offline   Reply With Quote
Old 09-07-2019, 09:06 PM   #3
while i am keeping search on the oil cooler
i found a jackson racing oil cooler will fit the 17 air box also the port for sensor for oil temp
i am thinking to get one of that any feedback on jackson racing product?
Old 09-08-2019, 12:50 PM   #4
Semiihcircle
Drives: 17 BRZ
I just ordered the jackson racing oil cooler should be here tomorrow!
Semiihcircle is offline   Reply With Quote
Old 09-08-2019, 01:00 PM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
The ones I know of are the Forester XT, and Jackson Racing V2 NA and Dual Radiator versions.
MS, CSCS, TSAC-F, CPT
Old 09-08-2019, 03:42 PM   #6
I ordered Jackson racing na , but they r not mentioned the v2 tho ,
Hopefully it is the newer one
Old 09-08-2019, 03:46 PM   #7
Semiihcircle
Drives: 17 BRZ
The v2, i was assuming it to be the updated version that fits the 17+ models
Sent from my SM-G973U1 using Tapatalk
Old 09-08-2019, 09:58 PM   #8
finger x
Old 09-08-2019, 11:54 PM   #9
86MLR
86MLR's Avatar
hi guys
What temps have you got?
Street or track?
NA or boosted?
Typical climatic conditions?
Stock engine?
Current oil pressure data?
You need to know these things to pick oil cooler type and size, if not you can overcool, not cool enough, drop your oil pressure, etc. etc.
Actually, why do you think you need a oil cooler is the first question to answer.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following User Says Thank You to 86MLR For This Useful Post:
weederr33 (09-08-2019)
Old 09-09-2019, 12:01 AM   #10
weederr33
weederr33's Avatar
Street or track?
NA or boosted?
Stock engine?
This! This is what needs to be asked. My go to is the Forester XT regulator. It works great even when driving spiritedly in the Texas heat.
Old 09-09-2019, 12:43 AM   #11
86MLR
86MLR's Avatar
I use the Forester item as well, mainly for the benifit of heating up my oil from cold faster, the quicker my oil hits 90° the quicker I can make mad skids
It has worked well for when mine was NA, and so far has not seen any issues since the car has had a turbo, albeit for only a limited time and it has only seen street duties in temps ranging from 15° to 30° centigrade.
If, and only if, my temps start getting above 125° then I will look more deeply into a well engineered solution.
IMO some of the "pre-fab name brand" oil coolers seem to be 1. To large (to much cooling and oil pressure drop), 2. To long (oil pressure drop), 3. No thermostat (or if they do have a thermostat it opens to early, personally, I would like my oil no cooler than 90° centigrade).
Alot of cars fitted with these coolers, when used on the street, struggle to keep oil temps over 90° centigrade.
I was looking at a good site a while ago explaining correct size and type choice, I'll try and find it again..
Opinion may vary
Old 09-09-2019, 01:19 AM   #12
86MLR
86MLR's Avatar
https://www.pegasusautoracing.com/do...ocID=TECH00133
Personally, I'm would first look at one of these, all the benifits of the Forester unit, just larger, plus less chance of rock/crash damage > https://www.crracing.com/product/oil...4-inlet-outlet
Old 09-09-2019, 01:25 AM   #13
86MLR
86MLR's Avatar
http://www.laminova.se/
Old 09-09-2019, 01:46 AM   #14
86MLR
86MLR's Avatar
https://www.scintex.com.au/products/...amping-showers
SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge tws98 Engine, Exhaust, Bolt-Ons 0 05-28-2019 11:50 PM
Oil Cooler Options for 2017 Manual BRZ 86 TofuJoe Engine, Exhaust, Transmission 12 09-22-2017 12:26 AM
2017 BRZ and Perrin Oil Cooler Install JSube Tracking / Autocross / HPDE / Drifting 18 04-29-2017 08:49 AM
