Old 06-02-2019, 08:20 AM   #1177
keen as
keen as's Avatar
Drives: 86 GT MT
I'm after a new electric motor with or without the compressor.
I've had the system for a few years. Last year, the motor spun in the housing and twisted the cables. Same as this post from someone else. I followed the recommendation and applied sealant to fix this problem.
http://www.ft86club.com/forums/showp...postcount=1095
The cable insulation must have been damaged. Many months later, the compressor would work intermittently. I checked the connections and found one cable loose at the motor. I opened the motor and found one cable almost burnt out with some burn marks on the inside of the motor case.
https://photos.app.goo.gl/X4sKFT6iPRgzAfd76
https://photos.app.goo.gl/wiP2GhY6sSv5p1pe7
I disassembled the compressor. Same as this post from someone else.
http://www.ft86club.com/forums/showp...postcount=1100
I measured the unit in case it helps someone point me to a replacement.
It runs on 28V, I think it is 4000W
Motor diameter 55mm, Length 67mm, Shaft diameter 8mm. Shaft length 39mm. (The shaft is modified and tapped)
https://photos.app.goo.gl/Dj7XhH2mf2HdDFMWA
keen as is offline   Reply With Quote
Old 06-26-2019, 12:52 AM   #1178
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
Does anyone have an extra throttle switch pedal they don't need im looking to buy one
Sent from my SM-G935T using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 06-26-2019, 04:33 PM   #1179
DAEMANO
Time Traveller
@keen as @BlOody_BoOger
I might have some extra parts available to sell for the both of you but I won't know till this weekend. Will post more later.
Old 06-26-2019, 05:37 PM   #1180
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Sorry it's probably been answered but there's 85 pages, just too much to read.
What are the dyno numbers for the electric supercharger with header and e85?
And if one was to buy one now, where is it possible to get the oft tunes? They are no longer available on the website
Dr. BRZ is offline   Reply With Quote
Old 06-26-2019, 07:16 PM   #1181
BlOody_BoOger
Cool man yea message me
Old 06-26-2019, 07:22 PM   #1182
BlOody_BoOger
On e85 you make roughly around 230whp and 215wtq. I'm able to pull away on 350z and wrx's on full bolt ons. My buddies 370z barely walked me on a 60mph pull 4th gr, we were neck and neck untill I hit 6th gear then he started pulling away
Old 06-26-2019, 07:48 PM   #1183
DAEMANO
Time Traveller
Those are exactly my numbers on the dyno (hot day) with a very similar setup so.. confirmed and co-signed.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
BlOody_BoOger (06-26-2019)
Old 07-10-2019, 05:17 PM   #1184
DAEMANO
Time Traveller
Have some spare parts but not exactly these things. Sorry guys.
The Following User Says Thank You to DAEMANO For This Useful Post:
keen as (08-20-2019)
Old 07-20-2019, 01:58 PM   #1185
BlOody_BoOger
Dang all good thanks
Old 07-22-2019, 12:24 AM   #1186
BlOody_BoOger
What parts do you have exactly?
Old 09-06-2019, 11:14 PM   #1187
dtek
Drives: 86 A00I
Post is here about my intent to mod a Phantom v1.5 to be lithium powered, if anyone has similar interest or advice on it:
LINK to other thread
dtek is offline   Reply With Quote
The Following User Says Thank You to dtek For This Useful Post:
DAEMANO (09-07-2019)
Old 09-07-2019, 07:08 PM   #1188
Urmyson
Are you planning on jumping up to 7s or 8s? I can't really see there being any increase in performance if you stick with the 6s setup we are currently using.
Urmyson is offline   Reply With Quote
Old 09-09-2019, 04:54 AM   #1189
dtek
Drives: 86 A00I
Mine is a v1.5 version, not sure what you're currently running?
Sounds like some much later spec lithium kits are circulating amongst you USA guys.
Old 09-09-2019, 09:34 PM   #1190
Lantanafrs2
Drives: 2013 frs red
Are you turning to the dark side, dr?
Lantanafrs2 is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 09:08 AM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 07:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 04:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 10:51 AM
