Old 09-07-2019, 10:02 PM   #43
Lantanafrs2
Drives: 2013 frs red
Originally Posted by Grips&slips View Post
Having this exact problem but I have triple checked everything including the grounding bracket. Any other thoughts?
Disconnect and reconnect battery, check for pinched o rings, vacuum leaks.
Lantanafrs2 is offline   Reply With Quote
Old 09-07-2019, 10:03 PM   #44
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The resolution is on the first post.
Clutch Dog (09-07-2019)
Old 09-07-2019, 10:06 PM   #45
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Literally
I ignored the instructions and went off a video with some common engineering practises and had no issues with the car. Since then had a modified OFT tune and wow, it really shoves the torque dip down below usable rpm range
Clutch Dog is offline   Reply With Quote
Old 09-07-2019, 10:43 PM   #46
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Originally Posted by Clutch Dog View Post
Literally
Is there no e85 in Cali?
Dr. BRZ is offline   Reply With Quote
Old 09-07-2019, 10:46 PM   #47
Clutch Dog
There's alot of E85 in Califorina
my tune is a stage 2 E85 tune with launch control and BPB modifications with maf rescaling
Old 09-07-2019, 10:58 PM   #48
Lantanafrs2
I use them with e85 as well
Old 09-08-2019, 10:21 AM   #49
Grips&slips
Drives: 99 mazda miata sport
No the bracket is on. I just took it off and wire brushed the block a little bit and the bracket it's self just a bit to see and it actually stayed on longer and idled better but then it dies after about a minute. I'm going to do it again I guess and clean it up even more but idk what else to do. The bracket I have does seem to be heavily coated in zinc or something. Not sure if that is really a problem or not but but a little with brush helped a little.
Grips&slips is offline   Reply With Quote
Old 09-09-2019, 01:07 PM   #50
Grips&slips
Found what I believe to be the issue. Sanding down the bracket actually did make it idle much better and longer but still was going up to about 2k rpm then dropping to about 400 rpm and shooting up to 1500 rpm then dying. This time I took out the orange rubber gaskets from the underside of the plastic manifold and there was a decent cunck missing from one. So I just ordered new gaskets and I'll try this again. Really hope that's my problem.
Old 08-01-2020, 11:18 PM   #51
Vicgbbjj
Vicgbbjj's Avatar
mine keeps haveing this issue, but the ignition control unit is bolted down
Vicgbbjj is offline   Reply With Quote
Old 02-25-2025, 06:38 PM   #52
J95
J95's Avatar
Hi guys, I just installed the kit today but I didn't had the grounding bracket. However I checked with a multimeter and I measure continuity between battery negative and ECU metal body, even without connecting the bolt to the frame, which should be the actual grounding point
Idle seems to work fine, no issues
Should I just forget then or try to find a bracket still?
J95 is offline   Reply With Quote
Old 02-25-2025, 10:08 PM   #53
Compelica
Compelica's Avatar
Drives: 86 GT
Mine didn't come with a bracket either, so I just crimped some wire onto two ring terminals, held down with a 10mm nut and bolt for the one side without any thread and tightened down.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 02-25-2025, 11:45 PM   #54
tomm.brz
Drives: brz 2017 hksv2
you ll know if you have grounding issues there near DI ecu
Old 02-26-2025, 05:12 AM   #55
J95
J95's Avatar
Ok yes I will do something like that if required
But I'm wondering if required, because as I say I measured continuity between DI ecu frame and negative battery 😅
In 15mins drive I didn't feel anything weird or idle issues
The Following User Says Thank You to J95 For This Useful Post:
tomm.brz (02-27-2025)
OpenFlash Tuning Tutorial: Crawford Billet Power Block Mapping changes Shiv@Openflash Software Tuning 209 12-28-2022 10:21 AM
Scion FR-S Crawford Performance Turbo/Block Build newfienorthca CANADA 12 11-29-2014 11:24 PM
BRZ, FR-S, GT86 | Power Block Manifold Riser by Crawford Performance | UP TO 25% OFF! iA Performance Groupbuys 18 11-04-2014 05:25 PM
Crawford Power Blocks like new oTaGGeDo Engine, Exhaust, Bolt-Ons 0 07-27-2014 10:22 AM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 12:18 PM
