Drives: BRZ Turbo
Complete power out after stall, came back in about 5 mins?
Hi everyone,
Had something really strange happen on the weekend. I was creeping through a slow area/gateed entrance and accidentally stalled, but as soon as it turned off, it went completely off. Everything was off, like the battery had been disconnected. I checked all the terminal fuses, and everything was okay. After about 4-5minutes it just came back on and I was able to start the car again. The dashboard and radio had reset like the battery was disconnected. Has anybody experienced this and what might have caused it? |
#2 |
[insert cool phrase here]
Drives: BRZ Premium
Auto or manual trans?
Well, if it's been a few years usually 3-4 year an oem battery might be on its way out. Or... check the terminals for excessive corrosion and or loose clamp.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | humfrz (09-02-2019) |
#3 |
ProCrastinationConsultant
EMP. You entered a restricted zone.
| The Following User Says Thank You to soundman98 For This Useful Post: | Ultramaroon (09-02-2019) |
#4 | |
Drives: BRZ Turbo
Honestly it felt like that haha. |
#5 |
It would be a good idea to clean an tighten your terminals then.
These kits are a little gimmicky, but they do seem to work. I put one on every one of my cars, haven't had a green sea monster in quite a while. https://shop.advanceautoparts.com/p/...inal+protector
#6 |
That joint between the lead terminal and the plastic housing is the weakest part of the battery. Because lead is so soft, it takes very little torque to crack the seal. Once it starts leaking, the only cure is a new battery.
It's all in how the terminals are handled when installing or removing the leads. Don't over-tighten, and always support the lead while torquing the fastener. Also, when purchasing a new battery, avoid those that show even the slightest hint of weeping around the terminals. They're already goners.
| DIY - Easy clutch grab adjustment (~10 mins) | Koji_Online | DIY (Do-It-Yourself) Guides | 745 | 11-09-2022 01:44 AM |
| Complete Power Folding Mirror Changeover | ChrisJ | Exterior Parts (Aero, Lighting, Etc.) | 4 | 05-09-2020 10:09 AM |
| Low idle/dip and stall/loss of power | GoZ21 | Issues | Warranty | Recalls / TSB | 5 | 12-08-2017 07:50 AM |
| Loss of power/stall under light throttle. | Model Citizen | Forced Induction | 49 | 10-21-2014 09:50 AM |
