Old 08-29-2019, 07:42 PM   #1
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Loose bolt in engine/transmission assembly?
I randomly decided to take a look at my engine bay today and noticed a bolt that appears loose where I assume the transmission connects to the engine itself. I do not have the right tools to check if it is actually loose, can anyone shed some light if this is anything serious that could be a problem for concern?
Thinking about taking it to the dealership so they can double check all the bolts, since the engine was out of my car @5k miles for service.
Thanks.
Oxyg3n is offline   Reply With Quote
Old 08-29-2019, 07:49 PM   #2
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
That bolt definitely should not be sticking out like that. 14mm, tighten it up or bring it somewhere. Have whomever check all are torqued down correctly.
That bolt is helping to hold the transmission to the engine.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
The Following User Says Thank You to Tonrogs For This Useful Post:
Oxyg3n (08-29-2019)
Old 08-29-2019, 09:11 PM   #3
new2subaru
Weight Weenie
Drives: 15 FR-S
The engine was out of your car at 5k for service? What happened at 5k?
Old 08-29-2019, 09:38 PM   #4
Grady
Grady's Avatar
Engine was out..... Technician F'ed up and forgot to tighten that bolt. I would have them re-torque all the bolts and do a good inspection.
Edit.
Make sure it is documented so if any quality issues come up in the future.
The Following User Says Thank You to Grady For This Useful Post:
humfrz (08-29-2019)
Old 08-29-2019, 09:48 PM   #5
Oxyg3n
Oxyg3n's Avatar
Indeed it was loose, after the car cooled down I was able to finger tighten it back for now.
And yes, I had a CEL at 5k so the engine was out to perform fixes. The car is now at 21k.
The Following User Says Thank You to Oxyg3n For This Useful Post:
new2subaru (08-29-2019)
Old 08-29-2019, 09:52 PM   #6
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Based on their post history, a valve adjustment was needed.
In regards to the loose bolt OP... if you don’t have the tools and mechanical confidence to address the issue, let the dealership deal with it and ask that they recheck all bolts. Bolts such as that one that hold the engine and transmission together are quite vital.
NCtoBRZ is offline   Reply With Quote
The Following User Says Thank You to NCtoBRZ For This Useful Post:
Old 08-29-2019, 10:01 PM   #7
Meanwhile, I suggest you just snug the bolt up. Snug = hand tight then 1/2 turn more with an open or box end wrench.
Old 08-29-2019, 11:26 PM   #8
new2subaru
Weight Weenie
Drives: 15 FR-S
But after seeing something so obvious you’d want them to go over anything that was touched. That’s really sloppy!
Old 08-30-2019, 12:54 AM   #9
Butterballz
Drives: Black FRS
Thank god for this post cause I got OCD and checked my transmission bolts after getting a TOB repair done by the dealership. One of my transmission bolts was loose sticking out an inch, I'm missing a transmission bolt on the left side that bolts into the cover, the bottom transmission bolt that goes through the same cover came loose at one point cause the cover fell down and interfered with my steering rack, and the best part was that they didn't even mount the big ground wire that bolts on the bottom starter/transmission bolt.
Epic fail.
Butterballz is offline   Reply With Quote
The Following User Says Thank You to Butterballz For This Useful Post:
86league (10-08-2019)
Old 08-30-2019, 01:28 AM   #10
True. My post followed the post by @NCtoBRZ 's post where he suggested that the OP take the car back to the dealer for a complete checkup -
new2subaru (08-30-2019)
Old 08-30-2019, 02:29 AM   #11
Oxyg3n
Oxyg3n's Avatar
Epic fail.
Jeez it sounds like you have a ton of loose bolts. Hopefully you can get them all fixed up. I better find all the bolt locations and check my other ones. I wonder if the techs just forgot to tighten them or once they are loosened and re-tightened, they just don't hold up as well through usage and rough shifts..
Whats worst is that today, August 29th, marks exactly 3 years since the day I purchased the car
Old 08-30-2019, 06:28 AM   #12
Epic fail.
How did your car start without te ground wire attached?
And no you don't have fucking OCD. Learn what OCD is before misapplying the term.
Grady (08-30-2019)
Old 08-30-2019, 09:43 AM   #13
Grady
Grady's Avatar
Maybe he did check the bolts four times for the fifth time?
humfrz (08-30-2019)
Old 08-30-2019, 10:38 AM   #14
Butterballz
Drives: Black FRS
Jeez rough morning? Obviously I’m not saying OCD in that manner but anyways. I don’t know how my car started. Maybe the hanging ground bracket was touching the chassis. Are you implying I was imagining the ground bracket wasn’t bolted?
ermax (08-30-2019)
Adjustable Coilovers - Loose Shock Assembly and Spring Unloading EndlessAzure Issues | Warranty | Recalls / TSB 14 09-27-2017 09:23 AM
Broken Assembly Bolt VIP BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-18-2016 10:02 PM
Rust on bolt on headlight assembly slicktop Cosmetic Modification (Interior/Exterior/Lighting) 0 12-13-2013 09:11 AM
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 08:07 AM
