Old 08-27-2019, 08:57 PM   #1
norcalpb
norcalpb's Avatar
5th gear not showing up on HUD after 4.3 diff swap
Hello all,
I should’ve seen this coming but the onboard computer that measures the speed and rpm of the car to calculate/indicate what gear you’re in doesn’t work too nicely with a higher FD. Every gear is fine except for 5th. I shift the car into 5th and nothing shows up on the hud for about 10 seconds and then it’ll give up and show 4th again.
Is there any way via OBDII to recalibrate the gear indicator sensors?
Old 08-27-2019, 11:20 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
I am 90% sure you can fix this with OFT and presumably ecutek also.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
norcalpb (08-28-2019)
Old 08-28-2019, 11:28 AM   #3
mabviper
Drives: WRB BRZ
You have to recalibrate the gear calculation table. That's what I did. New value = old value / 4.1 * 4.3
mabviper is offline   Reply With Quote
The Following 4 Users Say Thank You to mabviper For This Useful Post:
Compelica (12-28-2021), DarkPira7e (08-28-2019), norcalpb (08-28-2019), tmaz42o (06-14-2020)
Old 08-28-2019, 12:01 PM   #4
elBarto
elBarto's Avatar
Drives: Toyota GT86
Originally Posted by norcalpb View Post
Hello all,
You need to change the Gear determination tables. Only possible if you are tuned (OpenFlash or ECUtek).
In RomRaider you can find those tables in the "Miscellaneous - Thresholds" folder (probably it's going to have a similar name in ECUtek).
Then change the tables accordingly.
I think you can use the values of a 2017 model since those use an 4.3 FD.
Th above example is for a 4.556 Final Drive.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following 3 Users Say Thank You to elBarto For This Useful Post:
norcalpb (08-28-2019), sroby (03-08-2020), tmaz42o (06-14-2020)
Old 08-28-2019, 01:04 PM   #5
norcalpb
norcalpb's Avatar
Thanks guys
The Following User Says Thank You to norcalpb For This Useful Post:
sroby (03-08-2020)
Old 08-28-2019, 08:28 PM   #6
norcalpb
norcalpb's Avatar
In case any one stumbles across this thread:
4.3FD
1. 9403.05
2. 6232.05
3. 4677.63
4. 3777.35
5. 2990.87
6. No input needed
sroby (03-08-2020)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Diff Gear Change Riftur Engine, Exhaust, Transmission 35 08-20-2016 04:14 PM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 03:59 PM
RR Diff swap Triumphrider Engine, Exhaust, Transmission 25 10-21-2014 09:34 PM
Diff swap help wootwoot Engine, Exhaust, Transmission 30 06-10-2013 12:05 PM
