Old 10-20-2014, 04:55 PM   #1
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
RR Diff swap
Any one have any issues with a diff swap? IE: speedo error, Trac control problems?
I have all the typical bolt ons,
UEL headers
Greddy Axle back
Perrin filter
Crawford power blocks
and OFT tuned
I am not going supercharged until the car is no longer a daily driver. So I am thinking of a diff swap to run a bit shorter gearing. My car is Auto so I would just swap diffs with a friend that has a MT.
Triumphrider is offline   Reply With Quote
Old 10-20-2014, 05:03 PM   #2
gramicci101
Off Topic
What is the ring and pinion ratio of the auto diff vs. a manual diff?
Are you looking to swap the diff carrier and everything, or just the ring and pinion gears? The entire rear diff assembly would probably be easier.
Do you know how properly set pinion depth or set backlash on a ring gear?
What does your friend with the manual get out of this little exchange?
Old 10-20-2014, 05:08 PM   #3
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I don't think there is a difference. If there is I need to swap with an auto now.
Old 10-20-2014, 05:12 PM   #4
Triumphrider
Well I can buy the ring gear and pinion....about $800 online, or pick up a complete diff on ebay for about $600 and bolt it in. The Auto has quite a bit longer gear ratio's ...5th gear in my auto is the exact same ratio as the MT's 6th gear.
Old 10-20-2014, 05:17 PM   #5
Reaper
Reaper's Avatar
Drives: violent
Nope. I just pulled the part numbers. They all have the same rear diff.
Old 10-20-2014, 05:18 PM   #6
gramicci101
Off Topic
Those are transmission ratios though. Do you know what the actual diff ratio is?
Old 10-20-2014, 05:18 PM   #7
Reaper
Reaper's Avatar
Drives: violent
4.10 for both. Just checked. OP is very confused.
Old 10-20-2014, 05:20 PM   #8
Triumphrider
I'm pretty sure The rear diff ratios are different, I'll find the article and post back
Old 10-20-2014, 05:20 PM   #9
gramicci101
Off Topic
I wouldn't say very. He's probably looking at the final drive ratio, which takes both pieces into account.
Old 10-20-2014, 05:22 PM   #10
Dipstik-sportech
Dipstik-sportech's Avatar
Nope. The speedo is taken from the abs sensors so it doesn't affect that. I've been driving mine with the 3.73 rear gear for months, no issues.
Old 10-20-2014, 05:27 PM   #11
Reaper
Reaper's Avatar
Drives: violent
How do you like that? I've been thinking the same. Is 300 rear ends are pretty cheap.
Old 10-20-2014, 05:31 PM   #12
Dipstik-sportech
I love it. The only complaint I have is that at 50mph it's only pulling 2000rpm and my car doesn't really pull at that rpm. They're not cheap lol.
Old 10-20-2014, 05:32 PM   #13
Reaper
Reaper's Avatar
Drives: violent
I've seen them for 400$ but I'm not sure if it's the lsd.
Old 10-20-2014, 05:33 PM   #14
Triumphrider
You are correct sir, I been looking at final drive ratios....I was wondering why M/T diffs are on ebay for less than a ring and pinion and no one snapping them up haha my mistake. At least I haven't bought one...
Thanks
FS: FR-S Stock Diff(LSD) Sehwan Kim Transmission and Driveline 2 09-25-2018 04:34 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Anyone tried a TOMS diff? dave77 Engine, Exhaust, Transmission 7 06-18-2014 12:15 AM
Diff swap help wootwoot Engine, Exhaust, Transmission 30 06-10-2013 11:05 AM
So what is the Big Diff? (pun intended sorry) Erik @ GBox Engine, Exhaust, Transmission 22 10-21-2012 09:21 AM
