| Software Tuning Discuss all software tuning topics. |
5th gear not showing up on HUD after 4.3 diff swap
Hello all,
I should’ve seen this coming but the onboard computer that measures the speed and rpm of the car to calculate/indicate what gear you’re in doesn’t work too nicely with a higher FD. Every gear is fine except for 5th. I shift the car into 5th and nothing shows up on the hud for about 10 seconds and then it’ll give up and show 4th again. Is there any way via OBDII to recalibrate the gear indicator sensors? |
#2 |
Señor Member
I am 90% sure you can fix this with OFT and presumably ecutek also.
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | norcalpb (08-28-2019) |
#3 |
Drives: WRB BRZ
You have to recalibrate the gear calculation table. That's what I did. New value = old value / 4.1 * 4.3
| The Following 4 Users Say Thank You to mabviper For This Useful Post: |
#4 | |
Drives: Toyota GT86
In RomRaider you can find those tables in the "Miscellaneous - Thresholds" folder (probably it's going to have a similar name in ECUtek). Then change the tables accordingly. I think you can use the values of a 2017 model since those use an 4.3 FD. ![]() Th above example is for a 4.556 Final Drive.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#6 |
In case any one stumbles across this thread:
4.3FD 1. 9403.05 2. 6232.05 3. 4677.63 4. 3777.35 5. 2990.87 6. No input needed |
| The Following User Says Thank You to norcalpb For This Useful Post: | sroby (03-07-2020) |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| Diff Gear Change | Riftur | Engine, Exhaust, Transmission | 35 | 08-20-2016 03:14 PM |
| Swap AT Diff with MT Diff | sydious | Engine, Exhaust, Transmission | 2 | 03-17-2016 02:59 PM |
| RR Diff swap | Triumphrider | Engine, Exhaust, Transmission | 25 | 10-21-2014 08:34 PM |
| Diff swap help | wootwoot | Engine, Exhaust, Transmission | 30 | 06-10-2013 11:05 AM |
