Old 07-25-2019, 09:59 PM   #1
Rookie_34
Drives: 2014 frs
Need help with suspension
Hi guys im new to this forum. Ive been looking and googling but I cant seem to find anybody with the same issue i got. So theres something wrong with my rear end. When ever I take a long corner, like a big on ramp loop. During the loop, my rear end is slipping, swaying as well. It feels very dangerous. Is it just my car, or does anyone else get that?
Rookie_34 is offline   Reply With Quote
Old 07-25-2019, 10:22 PM   #2
i8ur911
Drives: 17 BRZ Series.Yellow
I'd recommend checking your tires first....tread depth and tire pressure. If both of those are good, I'd recommend checking your alignment.
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
The Following 3 Users Say Thank You to i8ur911 For This Useful Post:
new2subaru (08-25-2019), strat61caster (07-25-2019), Tristor (07-25-2019)
Old 07-26-2019, 12:25 AM   #3
Decep
Drives: 2013 FR-S Series 10
How many miles? Also could be worn rear dampers.
Old 07-26-2019, 12:40 AM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
All good advice so far. Start checking things.
Old 07-26-2019, 01:51 AM   #5
Rookie_34
Drives: 2014 frs
At first i thought it could be the shocks, then i switched to coilovers and it still does the same thing. Tire pressures fine. Ill have to get an alignment this weekend. Thx, ill come back and update.
Old 07-26-2019, 01:52 AM   #6
Rookie_34
Drives: 2014 frs
Car just hit 40k miles..
Old 08-25-2019, 03:42 AM   #7
Rookie_34
Drives: 2014 frs
Sorry to bring this back from the dead. I finally got my cars alignment done today. My car is even worst now. Its very scary to drive. It makes sudden swerve feeling and it doesnt feel safe. Tire pressure has been checked, alignment done. Recently put on coilovers about 2 months ago. Ive been searching the web for answers, found a couple threads about this issue. But everyone just says, oh its gotta be your alignment. Any help would be nice. Anyone have the same problem?
Old 08-25-2019, 03:58 AM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
The thread title should read 'Need support with my suspension'
Old 08-25-2019, 05:44 AM   #9
kev0
Drives: '14
Tire pressure has been checked but what about the tire itself? It might be too worn out. What tires do you have? Try swapping out the fronts with the rear tires. See if it still happens.
kev0 is offline   Reply With Quote
The Following User Says Thank You to kev0 For This Useful Post:
why? (08-25-2019)
Old 08-25-2019, 08:05 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
And how about posting alignment numbers (why i advise always to ask for printout or at least take a pic with phone off screen)? Alignment been done is NOT always alignment dialed right. Only seeing actual numbers can let others to point - that's ok, problem somewhere else, or how could you drive with particularly that or that being that much off, find normal alignment shop instead of that quack shop.
Tristor (09-15-2019), wparsons (08-26-2019)
Old 08-25-2019, 08:54 AM   #11
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Which coilovers? Who did the install? How low are you on each axle? Do you have enough suspension travel left or are you hitting bump stops?
Is the issue symmetrical or are turns in one direction worse than in the other? Have you checked the suspension for any play?
The Following User Says Thank You to timurrrr For This Useful Post:
Old 08-25-2019, 10:07 AM   #12
Ernest72
Are the sway bars stock?
Old 08-25-2019, 10:53 AM   #13
Rookie_34
Drives: 2014 frs
Yes, im going to lift the car up and check to see if there is any damage to the sway bars.
Old 08-25-2019, 11:58 AM   #14
Rookie_34
Drives: 2014 frs
I have on the bc br coilovers, i installed them myself. My car is on 18's and im running 225 front and 235 rear. I honestly dont think im hitting the bump stop. And so far all my test turns have been towards the right. Havent yet tried a loop turn lefty. If this helps, last night did pedal dance and took a long right loop, about 80mph, after exiting the loop. my car started to swerve like very dangerously. I ended up slowing down to 60mph. Its very scary.
Rear Suspension Clunking, front suspension groaning Butterballz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-14-2018 07:10 PM
OEM suspension and Rear Suspension Lateral Link Rod jprules Want-To-Buy Requests 3 10-04-2017 06:56 PM
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 10:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
