Drives: 2013 FRS
Shift kit for auto transmission
Transgo makes a shift kit for our transmission.
http://www.transgo.com/products.php?...&parent_id=172 Same kit for the Tacoma. Haven't done it yet but will most likely put the kit in both the FRS and the Tacoma... I was looking for a shift kit for the truck and than decided to ck for the car and it's the same kit... ![]() Right now I just run full synthetic fluid and about 40% dexron III to to stiffen up the shifting and harder lock up...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
| The Following 4 Users Say Thank You to shr133 For This Useful Post: |
#2 |
Drives: 2017 Toyota 86
What do these do?
#3 |
Drives: 2015 BRZ Limited
Here's the first result from Google: https://www.mistertransmission.com/what-are-shift-kits/
TLDR: It removes shifting overlap between gears to increase shifting speed, which decreases wear of clutches and seals and improves fuel economy. Having driven an automatic BRZ, I feel like the shifting is pretty quick. Obviously not dual clutch quick, but not slushy or slow by any means. I'd be interested to hear about the results if you end up doing it.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
| The Following 4 Users Say Thank You to FunnyGopher For This Useful Post: |
#4 | |
Drives: 2017 toyota 86
I am at the stage of my build where i am highly considering building my tranny. Been looking at the SSP high stall converter, valve body ,and clutch pack, this kit could be a good addition to those. or I wonder if i did converter, valve body, and shift kit (already have trans cooler) how much torque the tranny could reliably hold, might not need to do the clutch pack to reliably hold 350ft lbs, seems like the clutch pack is the hardest and most costly to install. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | shr133 (09-29-2019) |
#5 | |
#6 | |
And SSP makes a high stall torque converter ( roughly 3k rpm) a stage 1 and 2 valve body, and a clutch pack. |
#7 | |
#8 |
https://www.clublexus.com/forums/is-...installed.html
some info from someone who installed this very tempting to see how this would pair with a valve body since you remove valve body to install anyways. |
| Shift knob for automatic transmission | smoke86 | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 05-05-2018 05:41 PM |
| Perrin Transmission Mount+Shift Bushing, Whiteline Positive Shift Kit | zohaib | Transmission and Driveline | 5 | 03-08-2017 11:51 PM |
| OFT and Auto Transmission | Jrider | Software Tuning | 15 | 08-10-2016 05:11 PM |
| Auto to manual shift bezel (shift boot) | oh96s | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 05-23-2016 02:24 PM |
| Cold transmission hard to shift from 1st to 2nd | neutral | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 08-08-2012 02:24 PM |
