Old 08-16-2019, 12:50 AM   #1
shr133
shr133's Avatar
Drives: 2013 FRS
Shift kit for auto transmission
Transgo makes a shift kit for our transmission.
http://www.transgo.com/products.php?...&parent_id=172
Same kit for the Tacoma. Haven't done it yet but will most likely put the kit in both the FRS and the Tacoma...
I was looking for a shift kit for the truck and than decided to ck for the car and it's the same kit...
Right now I just run full synthetic fluid and about 40% dexron III to to stiffen up the shifting and harder lock up...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
The Following 4 Users Say Thank You to shr133 For This Useful Post:
86TOYO2k17 (08-16-2019), Dadhawk (08-16-2019), Mr_Eyo (08-17-2019), Tristor (08-17-2019)
Old 08-16-2019, 02:21 AM   #2
Mr_Eyo
Drives: 2017 Toyota 86
What do these do?
Mr_Eyo is offline   Reply With Quote
Old 08-16-2019, 05:41 AM   #3
FunnyGopher
Drives: 2015 BRZ Limited
Originally Posted by Mr_Eyo View Post
What do these do?
Here's the first result from Google: https://www.mistertransmission.com/what-are-shift-kits/
TLDR: It removes shifting overlap between gears to increase shifting speed, which decreases wear of clutches and seals and improves fuel economy.
Having driven an automatic BRZ, I feel like the shifting is pretty quick. Obviously not dual clutch quick, but not slushy or slow by any means. I'd be interested to hear about the results if you end up doing it.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
The Following 4 Users Say Thank You to FunnyGopher For This Useful Post:
86TOYO2k17 (08-16-2019), korhun (08-16-2019), Mr_Eyo (08-17-2019), Tristor (08-17-2019)
Old 08-16-2019, 11:13 AM   #4
86TOYO2k17
Drives: 2017 toyota 86
looks interesting.
I am at the stage of my build where i am highly considering building my tranny. Been looking at the SSP high stall converter, valve body ,and clutch pack, this kit could be a good addition to those. or I wonder if i did converter, valve body, and shift kit (already have trans cooler) how much torque the tranny could reliably hold, might not need to do the clutch pack to reliably hold 350ft lbs, seems like the clutch pack is the hardest and most costly to install.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
shr133 (09-29-2019)
Old 08-17-2019, 01:08 AM   #5
Mr_Eyo
Ooh cool, thx for the info! I didn't think googling it would help since the words seemed so generic. Are there many producers of upgrades for this AT?
Old 08-17-2019, 01:16 AM   #6
86TOYO2k17
This shift kit,
And SSP makes a high stall torque converter ( roughly 3k rpm)
a stage 1 and 2 valve body,
and a clutch pack.
Old 08-17-2019, 08:40 PM   #7
FunnyGopher
No worries, I wasn't calling you out, I was just providing a source of knowledge.
Old 08-19-2019, 01:50 PM   #8
86TOYO2k17
https://www.clublexus.com/forums/is-...installed.html
some info from someone who installed this
very tempting to see how this would pair with a valve body since you remove valve body to install anyways.
Shift knob for automatic transmission smoke86 Cosmetic Modification (Interior/Exterior/Lighting) 12 05-05-2018 06:41 PM
Perrin Transmission Mount+Shift Bushing, Whiteline Positive Shift Kit zohaib Transmission and Driveline 5 03-09-2017 12:51 AM
OFT and Auto Transmission Jrider Software Tuning 15 08-10-2016 06:11 PM
Auto to manual shift bezel (shift boot) oh96s Scion FR-S / Toyota 86 GT86 General Forum 10 05-23-2016 03:24 PM
Cold transmission hard to shift from 1st to 2nd neutral Scion FR-S / Toyota 86 GT86 General Forum 9 08-08-2012 03:24 PM
