Old 08-16-2019, 11:52 PM   #1
Timmygt
Drives: 2013 gt86 gts
Water pump replacement
Who has replaced a water pump? I'm at 192000kms and not sure if I should.
Timmygt is offline   Reply With Quote
Old 08-16-2019, 11:54 PM   #2
Is it broke? If not why change it?
Audio (08-20-2019), humfrz (08-17-2019), soundman98 (08-18-2019), strat61caster (08-18-2019)
Old 08-17-2019, 02:57 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Ditto.
Unless you have weeping coolant coming out the piss hole then it's time to replace it.
Otherwise if it's not broke don't fix it.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
humfrz (08-17-2019), strat61caster (08-18-2019)
Old 08-17-2019, 03:03 AM   #4
If you are considering preventative maintenance, I haven't heard of a water pump going out on this engine, so I wouldn't worry about it.
Old 08-18-2019, 11:39 AM   #5
Timmygt
I agree but, I was reading on another forum that some people have been through a couple. So, I just wanted to get an idea as to 1 how common, and 2 if it's a good idea at my milage to put in a new one. I cannot afford to have engine problems etc.
Old 08-18-2019, 01:48 PM   #6
extrashaky
Drives: 2014 BRZ Limited
A water pump is not a preventive maintenance item. It's the kind of thing you leave sealed up until you actually have a problem. Usually you can see cooling issues coming from a ways off if you pay attention.
Then you should get a bicycle.
Otherwise, get a roadside assistance program and use the money you're trying to waste on an unnecessary water pump replacement to start a savings account for emergency funds.
The Following User Says Thank You to extrashaky For This Useful Post:
Old 08-18-2019, 03:47 PM   #7
1. - it's not a common problem
2. - you don't need a new water pump
There ya go -
Like the old farmer said "Most of the stuff people worry about ain’t never gonna happen anyway".
Audio (08-20-2019)
Old 08-19-2019, 04:41 AM   #8
Timmygt
Lol, thanks guys. Water pump stays.
The Following User Says Thank You to Timmygt For This Useful Post:
humfrz (08-19-2019)
Old 08-19-2019, 06:06 AM   #9
ermax
ermax's Avatar
If someone has gone through multiple pumps on a Twin then clearly they don’t use the correct coolant. Probably running straight water or something dumb like that.
Old 08-19-2019, 08:56 PM   #10
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
In the past, people usually replaced the water pump and serpentine belt at 100k, but technology has improved since then.
At that mileage, I would take a look at your serpentine belt and look for any cracks. If you see any cracking, that means the rubber is drying out and that is something you should replace.
Old 12-15-2019, 08:20 PM   #11
KDad2
KDad2's Avatar
Drives: 2013 Raven
I know my water pump is going out. I can get one from toyota, but I see several after market brands for a fraction of the cost. Does anyone have experience with these? Damage to the engine is a whole lot more than an oem part. However, if a cheap one works just as well, I'd rather save my money.
Sent from my SM-N960U using Tapatalk
KDad2 is offline   Reply With Quote
Old 12-16-2019, 12:24 AM   #12
soundman98
ProCrastinationConsultant
soundman98's Avatar
What's your time worth? Is it cheap enough to have the car go down to do the job twice?
If yes, get the cheaper one.
KDad2 (12-16-2019)
Old 12-16-2019, 09:47 AM   #13
KDad2
KDad2's Avatar
Drives: 2013 Raven
ACDelco makes a replacement for $66 on Amazon Prime. I've already had the car up on jack stands and under panels off 3 times this weekend for other projects. I'm sure I will be either under the hood or under the car doing something to it again.
Old 12-17-2019, 09:41 AM   #14
wparsons
wparsons's Avatar
Not the serpentine belt, the timing belt. The only reason for doing the water pump when replacing the timing belt is because on an engine like that you have to remove the timing belt again to replace the water pump, so while it's all apart to replace the timing belt (which does require replacement) it was common to replace the water pump since it's a cheap part and everything is apart already. Timing belt jobs were easily $1000, to not replace a $100 part while you're in there is just silly.
Not doing the water pump while doing the timing belt would be like replacing a clutch and reusing the throwout bearing.
flickr
Tcoat (12-17-2019)
Water Pump Replacement Djratrap Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 01-18-2018 11:29 PM
Water pump pouring fluid SavingManuals Engine, Exhaust, Transmission 5 07-22-2014 11:31 PM
Leaking water pump DJCarbine Issues | Warranty | Recalls / TSB 11 05-13-2014 05:59 PM
Water pump Micene Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-08-2013 07:57 AM
