Old 08-11-2019, 09:17 PM   #1
turboencabulatr
turboencabulatr's Avatar
Drives: 2013 brz redheaded stepchild
Manual transmission improvements 2017+
For the 2017+ models, was there internal changes to the manual transmissions that alleviated some of the common gear change grinding issues of previous years?
Can anyone physically confirm this?
If this is true, has anyone done a swap into an older car without interchangeability issues?
turboencabulatr is offline   Reply With Quote
Old 08-11-2019, 10:25 PM   #2
86MLR
86MLR's Avatar
Page 89
"Manual transmission
Applicable marketsNorth America Japan C h i n a Australia Europe Generic
(refer to Chapter 2 "Model Variations" for details on the specifications available within each market)
 Applicable to: 6MT models
Durability of the 6MT has been increased
following the higher engine power output
of models for North America, Japan and
Australia.
 Changed shot peening of 6th gear.
 Added honing to the 6th gear teeth
face.
(1) 6th driven gear
(2) 6th drive gear"
Still rated at 250nm
The Following User Says Thank You to 86MLR For This Useful Post:
jflogerzi (08-11-2019)
Old 08-12-2019, 12:57 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
I have nothing to add, just wanted to say i love the username!
Old 08-12-2019, 03:24 PM   #4
mrg666
pessimistic skeptic
mrg666's Avatar
I think that requires a driver change
Old 08-12-2019, 03:32 PM   #5
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
"grinding" as in notchy shifts or are you missing the shift and the lever rattles like a mofo since it isn't fully in the gate? the former is normal operation and the latter usually depends on your shifting technique and won't change with a new 86 gearbox..
HKz is offline   Reply With Quote
Old 08-12-2019, 03:44 PM   #6
toast
Drives: 14 BSP Edelbrock BRZ
They added shot peening to the 6th gear cog? Because the massive torque of the FA20 was snapping teeth off of 6th gear?
Originally Posted by 86MLR View Post
Page 89
Australia.
face.
(1) 6th driven gear
(2) 6th drive gear"
toast is offline   Reply With Quote
Old 08-12-2019, 04:23 PM   #7
Jordanwolf
Rice King
Jordanwolf's Avatar
Agree. This is definitely driver mod.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 08-12-2019, 04:30 PM   #8
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I have the '13 and my gears never grind unless it is my fault. Been driving it for 6 years+ now. As far as I know the only thing that changed is the gear ratio.
DandoX is offline   Reply With Quote
Old 08-12-2019, 06:00 PM   #9
86MLR
86MLR's Avatar
Because people cannot drive and would lug around town in 6th at low speed.
Old 08-12-2019, 06:06 PM   #10
norcalpb
norcalpb's Avatar
Does this mean the 2017 diff got beefed up too?
Old 08-12-2019, 06:13 PM   #11
xdavidx
Emperor McDuck
xdavidx's Avatar
Drives: 2019 86 GT; 2018 BMW S1000RR
I have a 17+ and just recently the high rpm shifter rattle began - 13k miles.
I also had some grinding going into 4th above 6.5k rpms last weekend on a canyon road for about 30 minutes. Really weird as it was definitely not me, I tried it a bunch of different ways and there was a crunch no matter how I shifted if it was into 4th and above 6.5k rpms. Then it suddenly stopped doing it and hasn't come back.
xdavidx is offline   Reply With Quote
Old 08-12-2019, 06:14 PM   #12
86MLR
86MLR's Avatar
Negative red leader, the front diff mounts were changed though
norcalpb (08-12-2019)
Old 08-13-2019, 02:34 AM   #13
turboencabulatr
Page 89
Australia.
face.
(1) 6th driven gear
(2) 6th drive gear"
This is an awesome document! I wish OEMs released this to the public every year! This answers my question, thank you.
Well I should have been more specific on the "issue". It's the 3-4 shift thats a known weak link but I have heard complaints of other gears. There is a thrust problem and over extension in 4th. The aftermarket makes a fork to replace the stock one for a reason.
Mine lasted a long time without an issue and yes, I beat it like a red headed step child, so i'm not blaming Toyobaru.
Old 08-13-2019, 02:43 AM   #14
86MLR
86MLR's Avatar
I believe 4th walks up and eats itself at high torque levels with sticky rubber
I thought the upgraded fork was because the OEM fork failed when using heavier clutch packs
I've had neither issue, as yet, so I cannot say for sure
Transmission- Manual 2017 2950miles FT86Logic Transmission and Driveline 9 05-06-2019 11:33 AM
2017+ Reliability Improvements? MarkR171 Engine, Exhaust, Transmission 3 04-16-2018 10:40 AM
2017 facelift gt86/brz sound deadening improvements rsingh Scion FR-S / Toyota 86 GT86 General Forum 4 03-27-2018 10:55 AM
2017 FT-86 More power for manual but not for automatic transmission Yoniyama Scion FR-S / Toyota 86 GT86 General Forum 52 05-31-2016 08:01 PM
2017 Model Year Improvements FiReStorm2013 Scion FR-S / Toyota 86 GT86 General Forum 353 03-11-2016 03:07 PM
