| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
-1.5 front ,and -1.0 rear is good too , right? |
#17 |
#18 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Take Andrew's word for it more then mine. He is the professional. lol |
| The Following User Says Thank You to finch1750 For This Useful Post: | Racecomp Engineering (08-05-2019) |
#19 | |
- Andrew |
#20 |
#21 |
by the way, did your advice take account of lowered spring (Eibach Pro-kit) and I'm a daily driver with just occasional sprited driving (no racing, autox)?
#22 |
Drives: '23 BRZ
Alignment looks OK except they should maximize front camber.
Do not worry about whether you have more camber in back, it is not a big deal, particularly for street. Your rear camber numbers are fine, you don't need to get adjustable arms (which I think are WAY overprescribed BTW...). All you need is to have them dial in more front camber, as much as you can get with the camber bolts as while maintaining ~2-3mm clearance between suspension and tires/wheels. Keep toe minimized, close to zero. The zero front and 12 arc-minutes total rear (0.2 degrees total) is fine, you could go less rear toe, half what you have now or even down to zero, but where you are now is likely OK... |
#23 | |
Do I need to consider lowering spring for this alignment spec? Like.. ideal alignment spec can be different if I have lowereing spring? I have Eibach prokits now |
#24 | ||
Drives: '23 BRZ
As stated before, you can leave rear camber alone IMO...
| FS: Brand New Racer X Billet Rear LCAs, Rear Toe Links, and Front Tie Rod Ends | EGOBRZ | Brakes, Suspension, Chassis | 4 | 07-12-2017 12:12 PM |
| WTB: Header, Rear Diffuser, Rear Wing/Spolier, Trunk, Tail lights | Apples_ZN6 | Canada Classifieds | 0 | 06-04-2017 11:27 AM |
| USDM - Rear foglight indicator in cluster? Trying to do a quality rear fog light inst | nalc | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 12-10-2015 04:48 PM |
| Need advice on rear cambers | DarthThinmints | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 07-10-2014 02:43 AM |
| Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision | n7011n | Exterior Parts (Aero, Lighting, Etc.) | 7 | 03-26-2014 04:46 AM |
