Old 08-05-2019, 12:00 PM   #15
mitama
It's good to have more negative camber in the front than rear, but I still wouldn't go under -1.5 in the rear for a fun street car.
Your toe is fine. -1.5 camber front and rear will be fine.
- Andrew
Thanks, Andrew!
-1.5 front ,and -1.0 rear is good too , right?
mitama is offline   Reply With Quote
Old 08-05-2019, 12:03 PM   #16
Originally Posted by mitama View Post
Thanks, Andrew!
I wouldn't go less than -1.5 in the rear.
Tristor (08-05-2019)
Old 08-05-2019, 05:45 PM   #17
mitama
Didn't you say its better to have front to be more negative than rear?
Why do you recommend front and both to be same?
Old 08-05-2019, 05:51 PM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I heard its better to have front to be more negative than rear..
So if I set front to be -1.5 , should rear be -1.0 ~ -1.4?
Even camber won't be horrible on the street. I would take even if you are keeping the front down to -1.5. If you were getting up into the -2 and higher in the front then you start to dial less in the rear.
Take Andrew's word for it more then mine. He is the professional. lol
Racecomp Engineering (08-05-2019)
Old 08-05-2019, 08:27 PM   #19
It's better to have more front than rear as a general rule, but less than -1.5 rear is IMO not good if you happen to be limited up front.
- Andrew
timurrrr (08-06-2019), Tristor (08-08-2019)
Old 08-06-2019, 01:09 PM   #20
mitama
- Andrew
i c. I will leave my toes as now, and set up -1.5 front , -1.5 rear.
Thanks for your advice, Andrew!
Old 08-06-2019, 01:11 PM   #21
mitama
- Andrew
by the way, did your advice take account of lowered spring (Eibach Pro-kit) and I'm a daily driver with just occasional sprited driving (no racing, autox)?
Old 08-06-2019, 01:21 PM   #22
ZDan
ZDan's Avatar
Drives: '23 BRZ
Alignment looks OK except they should maximize front camber.
Do not worry about whether you have more camber in back, it is not a big deal, particularly for street. Your rear camber numbers are fine, you don't need to get adjustable arms (which I think are WAY overprescribed BTW...).
All you need is to have them dial in more front camber, as much as you can get with the camber bolts as while maintaining ~2-3mm clearance between suspension and tires/wheels. Keep toe minimized, close to zero. The zero front and 12 arc-minutes total rear (0.2 degrees total) is fine, you could go less rear toe, half what you have now or even down to zero, but where you are now is likely OK...
Old 08-06-2019, 01:36 PM   #23
mitama
Thanks.. I'm thinking to -1.5 front , -1.5~-1.3 rear.
Do I need to consider lowering spring for this alignment spec?
Like.. ideal alignment spec can be different if I have lowereing spring?
I have Eibach prokits now
Old 08-06-2019, 01:44 PM   #24
ZDan
ZDan's Avatar
Drives: '23 BRZ
As stated before, you can leave rear camber alone IMO...
no.
IMO "ideal" alignment spec is going to be a fairly broad range as far as camber is concerned. Being lowered will naturally give you a smidge more camber in the front and quite a bit more in back, IMO that's fine...
FS: Brand New Racer X Billet Rear LCAs, Rear Toe Links, and Front Tie Rod Ends EGOBRZ Brakes, Suspension, Chassis 4 07-12-2017 12:12 PM
WTB: Header, Rear Diffuser, Rear Wing/Spolier, Trunk, Tail lights Apples_ZN6 Canada Classifieds 0 06-04-2017 11:27 AM
USDM - Rear foglight indicator in cluster? Trying to do a quality rear fog light inst nalc Cosmetic Modification (Interior/Exterior/Lighting) 8 12-10-2015 04:48 PM
Need advice on rear cambers DarthThinmints Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-10-2014 02:43 AM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
