Old 08-02-2019, 03:00 PM   #1
mitama
My Brz rear cambers are little off. Should I realign?
Hi all!
I just got an alignment after installing front camber bolts and Eibach prokit Spring, but rear ones are little off
im at -2.12 left and -2.03 right (stock spec -1.92 to -0.42)
Should I get rear camber bolts as well and realign the car?
I am just a daily driver and sprited driving once in a while. No racing
For your information, here is the total spec of my car:
mitama is offline   Reply With Quote
Old 08-02-2019, 03:18 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
That's fine for DD, you actually want a few degrees negative for better handling.
My fronts are -3 and rears are -2.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-02-2019, 03:25 PM   #3
mitama
Originally Posted by mitama View Post
Hi all!
i didnt attach my current spec here it is
Old 08-02-2019, 04:41 PM   #4
re-animator
with uneven camber of a little bit in the back the car is going to slightly pull to one side but nothing crazy. since its in the rear i don't think you can fix this with bolts, you would need an LCA set to get them even. Over such a small difference i wouldn't stress it unless it really bugs you not being 100% straight.
re-animator is offline   Reply With Quote
Old 08-02-2019, 04:56 PM   #5
mitama
http://www.ft86speedfactory.com/whit...B#.XUSjPOhKiUk
with this, it will fix the uneven camber. Confirmed by the manufacturer.
I'm still thinking what to do.
Old 08-02-2019, 05:17 PM   #6
Decep
Drives: 2013 FR-S Series 10
I would leave it as is, not even 0.1 degree difference! MANY stock cars are almost 1.0 degrees off in terms of crosscamber and they drive fine. You're good.
edit: looking at your alignment sheet, did you have them zero out front camber with the bolts? they should be negative.
Old 08-02-2019, 06:15 PM   #7
mitama
Yes , I installed camber bolts front. Why do they have to be negative?
OE spec and Prokit spec are 0.00 deg(+/-0.75deg) and -0.2 deg respectively.
isn't 0 fine?
Old 08-02-2019, 06:29 PM   #8
maslin
Benz Tech
Drives: 2017 BRZ Premium
You install bolt kits to be able to add some negative camber, not to adjust back to 0. OE spec is to make a car understeer, under all conditions. Someone in the government decided cars are safer if they plow in to the barrier rather than spin. Performance wise, that's a terrible decision.
Any reason they didn't measure caster? While not adjustable, it's nice to know nothing weird is going on.
Getting your toe set is definitely the most important, I would deal with the camber as well. As negative as the bolts will go in the front, should be -1.5 or so. LCAs in the rear if you do want to dial it back a bit, your cross camber is good though.
maslin is offline   Reply With Quote
Old 08-02-2019, 06:37 PM   #9
mitama
Thanks, I will realign front to be -1.5. Any recommendation for rear degree?
I will get Rear Control arm - upper inner bushing soon.
Old 08-02-2019, 07:00 PM   #10
Decep
The rear bushings aren't bad but adjustable control arms are easier for alignment techs aka cheaper to adjust and to install. The SPC arms are fine for most and are cheap, $200 or less.
Typically on these cars you'd want more negative camber in the front than the rear but i wouldn't stress about it.
Old 08-03-2019, 02:00 AM   #11
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Get the Moog arms for the rear, they're identical to the SPC and Whiteline rear LCAs, but cheaper. You're shooting for a very minimal amount of negative camber in the rear, at least 1 degree more in the front than the rear. So if you are setting the front to -1.5 (which is good for a daily driver) you should set the rear to around -0.5. Main thing is to ensure your cross camber is zeroed out when the adjustments are done and that toe is taken care of appropriately.
What tires are you running? Some tires prefer more camber than others. For most common 300tw class tires though I wouldn't go more than -2 in the front. Front camber bolts usually max out around -2.5.
Tristor is offline   Reply With Quote
Old 08-03-2019, 02:49 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Rear camber -2.12 left and -2.03 right ? I wouldn't bother, even more so if DD only.
Now if toe would be different side to side by 0.1, i would. But you won't feel much of a difference by 0.09 camber, which also can be slightly further reduced if you sit in car.
Old 08-05-2019, 10:26 AM   #13
Racecomp Engineering
It's good to have more negative camber in the front than rear, but I still wouldn't go under -1.5 in the rear for a fun street car.
Your toe is fine. -1.5 camber front and rear will be fine.
- Andrew
Old 08-05-2019, 11:59 AM   #14
mitama
Stock tires. I might set it up at -1.5 front, -1.0 rear
FS: Brand New Racer X Billet Rear LCAs, Rear Toe Links, and Front Tie Rod Ends EGOBRZ Brakes, Suspension, Chassis 4 07-12-2017 12:12 PM
WTB: Header, Rear Diffuser, Rear Wing/Spolier, Trunk, Tail lights Apples_ZN6 Canada Classifieds 0 06-04-2017 11:27 AM
USDM - Rear foglight indicator in cluster? Trying to do a quality rear fog light inst nalc Cosmetic Modification (Interior/Exterior/Lighting) 8 12-10-2015 04:48 PM
Need advice on rear cambers DarthThinmints Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-10-2014 02:43 AM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
