Old 08-04-2019, 07:57 PM   #15
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Originally Posted by Grady View Post
You get what you pay for for the most part. You do not want to buy the least expensive components or the most expensive. The least expensive you lose quality, the most expensive you are generally paying extra for a name. Do a lot of research to be an educated buyer. With a Kit you are paying for R&D and packaging. If you are good at fabricating you can design your own and save some money. I ended up going with the Mishimoto oil cooler and sandwich plate then fabricating my own lines. I have fabricated lots of AN lines in my life so that part is no big deal. If you have not, get with someone that can teach you.
Thanks for your input. For me money isn't a problem and I generally get what I feel is the best value with value not equating to the least expensive. Mishimoto seems to be a good middle of the road choice. It IS interesting however that there are complete systems out there for 100 or less. It begs the question of is something that is 6 times more expensive 6 times better? Nobody has really stated why there is such a price difference rather than the "you get what you pay for" narrative.
TommyW is offline   Reply With Quote
Old 08-04-2019, 08:15 PM   #16
That is the oil cooler I wish I would have bought!
When I have it running wide open, I can bury the tach all day long and it stays rock solid at 190F. I bypass about half when cruising.
Old 08-04-2019, 08:25 PM   #17
86MLR
86MLR's Avatar
Mishimoto have a brand name to protect, so, quality assurance on the line is greater.
I've used quite a few Mishimoto parts and have never had a issue with parts fitting.
Convenience costs
Give me convenience or give me death
Old 08-04-2019, 08:32 PM   #18
86MLR
86MLR's Avatar
Opps, forgot my main point
I feel the Forester heat exchanger thingie works best to bring up temps from cold, as a cooler there is minimal benifit.
While I have been NA the Forester item has been gold, I'll see how it handles the added temp from cooling a turbo, I really cannot see it being a issue, even in 40°+ temps as the 86 is a street car only.
If it is a issue, a Mishimoto or a AVO oil cooler will be fitted, thermostat controled of course.
The Following User Says Thank You to 86MLR For This Useful Post:
Ultramaroon (08-04-2019)
Old 08-04-2019, 09:29 PM   #19
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Originally Posted by Impureclient View Post
Name brand whores checking in 3....2....
Gotta pay good money to get those stickers to put all over the car for the car shows so the other bros can drool over.
86TOYO2k17 and DarkPira7e nailed it. Thread over.
I feel attacked
Clutch Dog is offline   Reply With Quote
Old 08-05-2019, 07:22 AM   #20
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
The maximal oil cooler kit is a good, budget friendly unit if you can think of a way to mount the core yourself. You can upgrade the core if you track somewhere it is always hot and they will custom make the lines if you want to mount it somewhere funky.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 08-05-2019, 03:33 PM   #21
CSG Mike
CSG Mike's Avatar
Banjo fittings in an engine oil cooler. Nuff said.
More than a few Mishimoto coolers have backed off at the track, resulting in engine fires.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Clutch Dog (08-05-2019), Tristor (08-08-2019), Ultramaroon (08-05-2019)
Old 08-05-2019, 03:41 PM   #22
norcalpb
norcalpb's Avatar
This guy is selling a thermostatic plate, oil filter adapter, and tube for $100. All you’d need is a core ($160), core mounts ($40) and the hoses/AN fittings ($50)
Old 08-05-2019, 04:09 PM   #23
TommyW
TommyW's Avatar
https://www.ft86club.com/forums/showthread.php?t=45538
interesting.....
Always good to axe questions.
Old 08-05-2019, 04:22 PM   #24
m86
Drives: FRS
Who is?
m86 is offline   Reply With Quote
Old 08-05-2019, 06:43 PM   #25
Grady
Grady's Avatar
Banjo fitting are not bad. However you do need to know their weaknesses. (A) The hoses need a lot of space to not put a load on the fittings during engine flex. This is difficult in our tight engine compartment. (B) They have to be torqued correct. (C) A banjo fitting should be safetied period. Any one of the 3 items listed above done incorrectly will not cause an issue. You will need 2 mistakes to cause an issue. I like the plate due to the clearance with the 2017+ air box.
This was my fix. I have no worries about mine coming loose.
The Following User Says Thank You to Grady For This Useful Post:
NoHaveMSG (08-05-2019)
Old 08-05-2019, 06:48 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There are banjo's on my RacerX thermostatic plate. Over 3 years no issues.
Old 08-05-2019, 06:54 PM   #27
86MLR
86MLR's Avatar
Incorrect install?
Banjo fittings are everywhere
From my experience 99% of issues people have when using brand name parts are due to incorrect install procedures.
Old 08-05-2019, 07:30 PM   #28
norcalpb
norcalpb's Avatar
Originally Posted by m86 View Post
Who is?
https://www.ft86club.com/forums/showthread.php?t=135548
Oil coolers that will fit with the TRD intake? Hanakuso Engine, Exhaust, Transmission 28 03-05-2022 11:24 AM
Inexpensive Oil Coolers - worth it? robwbright Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 05-10-2019 07:58 PM
Oil coolers Matey Forced Induction 37 03-13-2015 08:21 AM
those with perrin oil coolers bkblitzed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 12-08-2013 12:34 AM
HKS Oil Coolers in stock Sam Strano Engine, Exhaust, Bolt-Ons 3 11-13-2012 01:41 PM
