#29 |
Dismember
Drives: 2013 Red Scion FR-S
I find PFC pads very livable on the street.
#30 |
Drives: 13 BRZ, 17 Focus RS
I’ve used Raybestos ST45 and ST47 track and street for over 3 years. I taper the pad edges and use high temp grease to prevent noises. About the only bad thing is the front rotors get eaten away a bit quickly. I had used one fluid (Motul 600 maybe?) and I’d start to get a bit of pedal travel change later in track sessions. I’ve been using Prospeed fluid lately and pedal is rock solid for extended sessions. I also trimmed the front dust shields slightly and have some Porsche air deflectors to get a bit more cooling, but I’m not sure if they help much or not. Cheap though. It’s pretty awesome to be able to trust the brakes as much as I do, and I notice being able to brake much later than others on track. Definitely find a solution to prevent that from happening again!
#31 | |
My current set of CSG pads with Brembo fronts on my turbocharged brz is on track for about ~30 days of life on track. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (08-03-2019) |
#32 |
Drives: '13 FRS - STX
XP10s are livable on the street if they're well bedded, Gloc R10 is a similar compound. Happy with mine as an amateur pad, I couldn't keep them bedded so they were noisey for me, you track more than I ever did so might be ok.
| The Following User Says Thank You to strat61caster For This Useful Post: | biggie (08-05-2019) |
#33 |
Drives: gt86
Here are some pictures with my front pads.
#34 | |
#35 | |
Drives: gt86
I'm running Michelin PSS now but planning to switch to Federal 595 RS-PRO (I know these are not very good but there are some competition related constraints). Should be stickier than PSS. The question would be which one of those 3 (or other suggestions - up to 250$) would be best for trackdays but still streetable
| The Following User Says Thank You to biggie For This Useful Post: | norcalpb (08-04-2019) |
#36 | |
https://www.counterspacegarage.com/p...ont-brake-pads https://www.counterspacegarage.com/p...9-brz-frs-rear |
| The Following User Says Thank You to mixxxx For This Useful Post: | biggie (08-05-2019) |
#37 |
Melty melty! How are the rotors, lots of smearing?
#38 |
Drives: GT86 Supercharged
Go with stock rotors, steel brake lines, RBF600 (or similar) and Ferodo DS2500.
I've tracked a lot with that combo without issues, and stil daily driving the car. |
| The Following User Says Thank You to Gt86Force For This Useful Post: | biggie (08-05-2019) |
#39 |
Drives: gt86
#40 | |
Drives: gt86
Still debating about rotors...slotted or plain!? |
#41 |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#42 | |
| The Following User Says Thank You to CSG David For This Useful Post: | wparsons (08-05-2019) |
| WTB: Race Brake Pads | Kordless | Want-To-Buy Requests | 0 | 02-20-2018 05:03 PM |
| FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo | tampaSi | Brakes, Suspension, Chassis | 4 | 05-27-2017 02:31 PM |
| race/track car | fastfrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 01-14-2013 08:26 AM |
| No Race Track Seats in Race Car Drivers Every Day Cars..!! | JohnnyNight | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 10-16-2012 04:42 PM |
| Toyota 86 race track? | sneaky | AUSTRALIA | 6 | 06-14-2012 10:56 PM |
