Old 08-03-2019, 11:59 AM   #29
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I find PFC pads very livable on the street.
Old 08-03-2019, 01:18 PM   #30
bhmax
Drives: 13 BRZ, 17 Focus RS
I’ve used Raybestos ST45 and ST47 track and street for over 3 years. I taper the pad edges and use high temp grease to prevent noises. About the only bad thing is the front rotors get eaten away a bit quickly. I had used one fluid (Motul 600 maybe?) and I’d start to get a bit of pedal travel change later in track sessions. I’ve been using Prospeed fluid lately and pedal is rock solid for extended sessions. I also trimmed the front dust shields slightly and have some Porsche air deflectors to get a bit more cooling, but I’m not sure if they help much or not. Cheap though. It’s pretty awesome to be able to trust the brakes as much as I do, and I notice being able to brake much later than others on track. Definitely find a solution to prevent that from happening again!
bhmax is offline   Reply With Quote
Old 08-03-2019, 06:05 PM   #31
CSG Mike
CSG Mike's Avatar
Originally Posted by cjd View Post
That's the right call. Track pads on the street is safer than street pads on the track.
Expense is never easy to calculate. Over time, those $400 pads are very possibly cheaper... Just like a BBK can pay for itself.
This. If you end up outgrowing those pads, you now own a nice set of expensive paperweights. On the other hand, having too much pad will never hurt your experience, and sometimes it's better to know brakes will not be a failure point for you.
My current set of CSG pads with Brembo fronts on my turbocharged brz is on track for about ~30 days of life on track.
wparsons (08-03-2019)
Old 08-03-2019, 06:24 PM   #32
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
XP10s are livable on the street if they're well bedded, Gloc R10 is a similar compound. Happy with mine as an amateur pad, I couldn't keep them bedded so they were noisey for me, you track more than I ever did so might be ok.
ineedyourdiddly
biggie (08-05-2019)
Old 08-04-2019, 01:50 PM   #33
biggie
Drives: gt86
Here are some pictures with my front pads.
biggie is offline   Reply With Quote
Old 08-04-2019, 02:10 PM   #34
CSG David
CSG David's Avatar
Originally Posted by biggie View Post
Track pads it is then!
Considering that I'm not (yet) willing to spend 400$ on pads for front only and recommendations on this topic (THANKS GUYS! ) my top 3 would be (in no particular order):
CARBOTECH XP10
Project Mu Club Racer
HAWK DTC-60
I think you got an idea of my current needs so I would appreciate your recommendation! Thanks!
P.S. still not willing to change pads for track/street
Let me know what kind of courses you'll be frequently attending and what tire you're planning to run on a consistent basis. Just as a disclaimer, those are good entry level track pads. If you cook those, you'll have to understand it's the pad, not the other components of the brakes.
Old 08-04-2019, 02:23 PM   #35
biggie
Drives: gt86
Most frequently I go to this one - http://motorparkromania.ro - for time attack challenge type of racing.
I'm running Michelin PSS now but planning to switch to Federal 595 RS-PRO (I know these are not very good but there are some competition related constraints). Should be stickier than PSS.
The question would be which one of those 3 (or other suggestions - up to 250$) would be best for trackdays but still streetable
The Following User Says Thank You to biggie For This Useful Post:
norcalpb (08-04-2019)
Old 08-04-2019, 07:31 PM   #36
mixxxx
mixxxx's Avatar
CARBOTECH XP10
HAWK DTC-60
Good decision. For a similar price of the Club Racer, get the ProjectMu 999 because racecar.
https://www.counterspacegarage.com/p...ont-brake-pads
https://www.counterspacegarage.com/p...9-brz-frs-rear
mixxxx is offline   Reply With Quote
The Following User Says Thank You to mixxxx For This Useful Post:
biggie (08-05-2019)
Old 08-04-2019, 08:25 PM   #37
wparsons
wparsons's Avatar
Melty melty! How are the rotors, lots of smearing?
flickr
Old 08-05-2019, 10:35 AM   #38
Gt86Force
Drives: GT86 Supercharged
Go with stock rotors, steel brake lines, RBF600 (or similar) and Ferodo DS2500.
I've tracked a lot with that combo without issues, and stil daily driving the car.
Gt86Force is offline   Reply With Quote
The Following User Says Thank You to Gt86Force For This Useful Post:
biggie (08-05-2019)
Old 08-05-2019, 02:25 PM   #39
biggie
Drives: gt86
They look quite good, no smearing at all. Strange...
Old 08-05-2019, 02:29 PM   #40
biggie
Drives: gt86
Brake lines are on their way (stoptech), already using Castrol SRF (should be even better than motul) and I think I made up my mind and I'm going for Carbotech XP10.
Still debating about rotors...slotted or plain!?
Old 08-05-2019, 03:35 PM   #41
CSG Mike
CSG Mike's Avatar
"works for me =/= works for you"
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
mixxxx (08-05-2019), strat61caster (08-05-2019), Tristor (08-08-2019), wparsons (08-05-2019)
Old 08-05-2019, 04:00 PM   #42
CSG David
CSG David's Avatar
We can help supply you with the correct parts as necessary.
The Following User Says Thank You to CSG David For This Useful Post:
WTB: Race Brake Pads Kordless Want-To-Buy Requests 0 02-20-2018 05:03 PM
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 02:31 PM
race/track car fastfrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 01-14-2013 08:26 AM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 04:42 PM
Toyota 86 race track? sneaky AUSTRALIA 6 06-14-2012 10:56 PM
