Old 08-02-2019, 11:52 AM   #29
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by wparsons View Post
IMO that's either a unicorn track, or you're under driving by a fair amount. I've never personally driven on them, but anyone I know that's a properly fast driver can get 2-3 hot laps absolute maximum.
HA!! You MUST be *joking*!
You have zero experience with these tires, but you're ready to critique the awesomeness of my driving?!
FWIW, I'm not that great a driver and fairly inconsistent usually, but if anything I tend to overdrive the fizook out of the car, to a fault. I only got two events out of my first set last year, actually bought 3 sets last year for 7 events, and I was also sometimes running NT01s :O
In ANY case, what does "a properly fast driver" have to do with the context of this thread?
I stated my experience with these tires, which is more than you can do as you've never driven on them
Old 08-02-2019, 12:24 PM   #30
wparsons
wparsons's Avatar
FWIW, I'm not that great a driver and fairly inconsistent usually, but one thing I do is overdrive the fizook out of the car, to a fault. I only got two events out of my first set last year, actually bought 3 sets last year for 7 events, and I was also sometimes running NT01s :O
If you're getting 7 good laps, you're under driving. The other potential is you're over driving so badly that they're always over heated and never at full potential.
I wasn't trying to attack you (despite you taking it that way), but data doesn't lie, and I'll take a much larger sample set over your single reference.
My opinion is far from isolated too... they aren't called one lap wonders for no reason.
flickr
Old 08-02-2019, 12:33 PM   #31
ZDan
ZDan's Avatar
Drives: '23 BRZ
There's all sortsa potential reasons why. One of which is, maybe these tires *aren't* garbage after 2 laps....
And it is *1st hand* info, which again is more than you can provide!
Right, data doesn't lie, and I provided mine. So let's see your lap time info.
FWIW i was kinda joking and trying to give you a jokey sanctimonious "How DARE you sir!"
Your opinion is based on the experience of others, though.
Anyway for 90% of the cases where someone lacking experience is asking for info, it is most likely not pertinent if tires lose a few tenths after 3 or four laps in the hands of an expert driver.
Old 08-02-2019, 01:08 PM   #32
wparsons
wparsons's Avatar
I'll dig into it later if you actually want it...
Totally missed the sarcasm... stupid internet.
And in those cases where they don't have the experience to extract every tenth out of the tires, and aren't competing, there are much better tire options (which was my original statement). More consistent, last longer overall, last for longer sessions, cheaper, etc.
flickr
Old 08-02-2019, 03:17 PM   #33
ZDan
ZDan's Avatar
Drives: '23 BRZ
If you happen upon it, I'm interested... Not a big deal but I am curious as to what kind of lap time falloff others may be seeing. FWIW I was on tires with ~2mm tread depth left, less tread squirm...
I find when I reread my posts they usually come of significantly more aggressive than intended...
Hankook RS4...
Old 08-02-2019, 04:21 PM   #34
wparsons
wparsons's Avatar
I'll see what I can dig up, I can share the live timing url but that doesn't tell you what tires people are on, and looking that up is a completely separate db/system.
Here's one guy that I believe was on RE71R's for this event, and is a really quick/consistent driver. Look at the practice laps, boxed by time (practice is run as one session all monring, but you'll see his actual runs are ~1 hour apart)
http://livetiming.time-attack.ca/eve...tor/68/details
Hankook RS4...
They're a great choice, there's some other good ones too especially if not competing.
flickr
Old 08-03-2019, 08:43 AM   #35
jayliu.jiayu@gamil.com
jayliu.jiayu@gamil.com's Avatar
Drives: 2017_86 2016_frs 2007_335i
i will keep my mouth zipped until the next track day with my alignment ready, and show the result.
most driver are using re71r for people around from newbie to advance
one driver is using r888r or r888 who is driving r35 gtr
however, re71r is cheaper in my area.
so far as know, no matter wut u do. the re71r only hold 2 track day before u find out it is pointless to keep lapping with them
4-5 section 20-25mins lapping on each track day
no matter wut, it is all come down to the track layout.
so here is the vimc track
a lot of u turn with off camber and hard braking
and here is video of the last section on the tire i had showed in the post
[ame]http://www.youtube.com/watch?v=nZVoOEvoeLk&t=131s[/ame]
[ame]http://www.youtube.com/watch?v=XkFKC8DYdrw&t=2s[/ame]
from start to end 2 videos
in my opinion, the re71r will get into working temperature very fast like 1-2 laps. the grip keeps linear until u cool it down, and then u will notice the grip a bit less compare before.
something like decreasing steps
anyway will show the result after i done the next trackday
jayliu.jiayu@gamil.com is offline   Reply With Quote
Old 08-03-2019, 08:53 AM   #36
one of my friends use 215 45 17 re71r on stock brz, no racing line no heel toe. just push the tire to the limit.
like a rally driver right on the limit and careless
he is 3 seconds faster than me
but he had way more seat time compare to me
i only had 1 set of re71r last year
he had 6 set now i think. he knows the limit of the re71r
my goal is keep up with him
still try to find the limit of the tire at braking into the corner
Old 08-03-2019, 08:36 PM   #37
wparsons
wparsons's Avatar
I'd suggest RS4's for your next tires instead of RE71R's, they're a much better lapping tire than RE71R's. They'll last you a lot longer, and should be cheaper (they are here).
flickr
Old 08-04-2019, 02:20 AM   #38
u just dont get wut i need in there
i wanna be as fast as i can not more laps
tire wearing show me i need some camber for front tire to be fast
i like to be familiar with re71 first and more on to the 100 grade tires
thx for the help tho
will post up once i got my alignment
Old 08-04-2019, 09:58 AM   #39
ZDan
ZDan's Avatar
Drives: '23 BRZ
RE71R or Yok A052 as far as streetable track tires go...
yeah, you want -3 or more front camber...
RE71R and A052 are labeled "200 treadwear", but they are up there with NT01, R888R etc. in terms of grip and lap times. It was back and forth but last year I went a couple of tenths faster in the TT on 225 RE71R vs. 235 NT01s.
Old 08-04-2019, 08:19 PM   #40
wparsons
wparsons's Avatar
I don't think you get what you actually need... if you're not already driving to the full potential of the car and setup then you need seat time, not faster tires. Faster tires will give you a tiny plateau of being faster, but if you're actually trying to be a faster driver that's not the best path. If you're not logging data and analyzing it to see where you're losing time, then you're also leaving a TON of time on the table.
RE71R's are actually quicker than some of the older 100tw tires, RA1's, R888R's, NT01's, etc as well.
flickr
Old 08-04-2019, 10:03 PM   #41
hum...... u really not going to stop this,
i had track the stock car in the same circuit 6times
then i move to the tire and brake
also got a seat just because corner 2
right now, got harrys laptimer and gopro
so will get that gap number on my next track day
i understand wut r u trying to say, and that s y i keep my stock suspension
try the re71 first, i think u will love it!
Old 08-05-2019, 01:00 AM   #42
Cole
Not a troll
Cole's Avatar
As far as I know, @wparsons likely has quite a bit more seat time than you do. You’re doing yourself a disservice to be shit canning the advice he’s giving you...
Cole is offline   Reply With Quote
Question About Negative Camber: More Negative Camber == More Grip at Corner? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-10-2019 02:08 PM
Question about wheel/tire fittment Jolt182 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 04-27-2015 12:51 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
Camber Question subaruatheart Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 03-24-2013 01:49 PM
Fittment question digital_assassin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-09-2012 12:21 AM
