Old 07-25-2018, 01:05 PM   #57
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by Paulo86 View Post
i want to put one on my 86 in france, i'm edelbrock supercharged, jackson racing dual radiator, built engine etc
i want one to reduce the temp + put out the air at high speed because stock hood flex on the sides at 150mph+
the big question is will it be safe to drive sometimes in germany at 186 mph with stock latch ? or will i take it in the windshield ^^
do you trust your lightweight aluminum stock hood at those speeds? People have said they look nowhere near stable. Some type of hood pins are always a good idea.
why? is offline   Reply With Quote
Old 07-25-2018, 01:09 PM   #58
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
MPH Carbon Fiber hood with reverse scoop and NACA ducts!
I barely trust my stock hood at 90 mph... I've debated aerocatch pins more than once.
Old 11-12-2018, 05:13 PM   #59
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
Can anyone tell me how far down those NACA duct vents go into the engine bay? Just the actual part of the hood, not the hose. I'm wondering if it'll fit with the WORKS turbo kit because the turbo sits in between the intake manifold and the battery which looks to be right where the passenger side duct sits. Also, would that be fine that the vent opens right onto the turbo? I know you can have issues if water drips onto a hot turbo,would I need to make some kind of rainguard or seal it off when raining?
Horrid_Funk is offline   Reply With Quote
Old 11-12-2018, 05:33 PM   #60
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
3.2" from the inside of the hood to the lowest point. I'm sure you can seal if off with a cap secured by a hose clamp; just like the duct is attached.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
Horrid_Funk (11-12-2018)
Old 11-12-2018, 08:01 PM   #61
Horrid_Funk
Do you think it would be possible to trim the duct back if needed? It might make it hard or impossible to get a hose on there but is there enough material to trim away some? I still need to check what the clearance of the turbo is, so it may be a non-issue.
Old 11-13-2018, 11:43 AM   #62
shiumai
shiumai's Avatar
i'd say yes; there's a lot of material there. But if you haven't ordered the hood, why not just let Joel at MPH know to make the part that sticks down on the passenger side duct shorter? That way you don't have to trim it yourself. You're most likely not going to attach a hose/tube to it since your turbo is right there.
Horrid_Funk (11-13-2018)
Old 11-13-2018, 01:49 PM   #63
Horrid_Funk
I'm concerned about fitting a hose because I'd want to use a cap and clamp like you suggested if there's enough room to get the clamp on it after modification. You're right it's probably best just to talk to Joel when I get around to ordering. I'm just build planning atm, doing research on FI kits and I really like this hood. Thanks for helping out with some info
The Following User Says Thank You to Horrid_Funk For This Useful Post:
shiumai (11-13-2018)
Old 07-12-2019, 08:54 PM   #64
Suparu
Drives: 2013 BRZ Limited
Are there any clearance issues with the main vent and a SBD turbo kit?
This looks like by far the best vented hood for the 86 IMO both in function and form.
Suparu is offline   Reply With Quote
Old 07-24-2019, 11:14 AM   #65
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
I'm still wondering if this hood will clear the Full Blown Motorsports turbo kit where the turbo sits by the front vent.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 07-29-2019, 06:46 PM   #66
Suparu
Same concern here with the SBD kit. I really hope this hood clears the turbo cuz it looks amazing. Might have to reach out to them directly once I have the money to buy it. For us turbo 86’s a hood like this is a godsend, there’s a ton of heat under my hood. I’d rather not go Seibon :/
The Following User Says Thank You to Suparu For This Useful Post:
blackfireball5 (07-30-2019)
Old 07-29-2019, 07:08 PM   #67
spike021
spike021's Avatar
I'd send Joel an email.
He's super responsive and is always very detailed. Thanks to his awesome transparency and communication I'm very heavily leaning toward ordering from him when I'm ready for a CF hood.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following 3 Users Say Thank You to spike021 For This Useful Post:
blackfireball5 (07-30-2019), Suparu (08-04-2019), why? (07-30-2019)
Old 07-30-2019, 07:58 AM   #68
why?
why?'s Avatar
Drives: series.blue
You should. Joel makes me want all the carbon.
The Following 2 Users Say Thank You to why? For This Useful Post:
spike021 (07-30-2019), Suparu (08-04-2019)
Old 07-30-2019, 09:28 AM   #69
blackfireball5
Joel has been very helpful.
Take a look at these Facebook posts.
This one he provided me:
https://m.facebook.com/story.php?sto...68661733264699
This one I posted:
https://m.facebook.com/groups/152742...26004937523879
Both have been very helpful.
Wheelwell Profile
The Following 2 Users Say Thank You to blackfireball5 For This Useful Post:
Old 07-30-2019, 06:11 PM   #70
why?
why?'s Avatar
Drives: series.blue
He's awesome. Willing to listen to my insane babble too. And willing to point out stuff in his social media for you, like the different types of carbon. I'm tempted to spend all my money, and beg him to make a carbon fiber seat and dash so I can spend more.
blackfireball5 (07-31-2019), Suparu (08-04-2019)
APR Carbon Fiber Radiator Cooling Plate & Brake Ducts LANI86 Exterior Parts (Aero, Lighting, Etc.) 3 12-21-2016 06:19 PM
Looking for R35/GT-R Aero data... on the NACA ducts Kiske Other Vehicles & General Automotive Discussions 0 03-03-2016 08:34 PM
Hood Venting, NACA Ducts Lunatic Scion FR-S / Toyota 86 GT86 General Forum 70 02-08-2015 11:10 AM
NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days 86_Insider Brakes, Suspension, Chassis 1 09-26-2013 01:39 AM
APR Performance Carbon Fiber Brake ducts! enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 16 06-01-2013 02:56 PM
