Old 07-22-2019, 02:42 AM   #1
Jonbonilla
Drives: 2017 Toyota 86
Angry Weird clicking noise
So this weekend I was driving I hit a mean pothole and I heard a weird clicking noise from my front driver side I checked to see if everything was tight if there was anything stuck in all 4 of the tires but nothing was there when I steer to my left the clicking noise isn’t there but when I steer to my right it’s there clicking I am on coil overs yes there tighten to and I’m running 18x9.5 in the fronts so I’m wondering if anyone has encounter this before to get an idea what it could be I’m thinking it could be a bad hub.
Jonbonilla is offline   Reply With Quote
Old 07-22-2019, 02:54 AM   #2
First off, I'd suggest you check and make sure none of the under panels are lose.
If they are all in place, I'd suggest you take the front wheel off and check the brakes (maybe a pad or the caliper got knocked lose).
If that don't work, I'd take it into a brake/suspension/front end shop and explain what it's doing and ask them to fix it.
Who is ol humfrz trying to kid - I'd just do step three, while I sat in the waiting room and drank a cup of coffee and read a car magazine -
Old 07-22-2019, 02:59 AM   #3
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
My guesses: Sway bar end link, inner or outer tie rod, wheel bearing, or transverse link bushing.
I'd lift the car and pull/push on some things to see if anything seems abnormally loose (compare sides) including the wheels. Also make sure no boots or bushings are obviously damaged or leaking.
Have a look at the diagram below to get an idea for what's where...
https://estore.subarupartswarehouse..../Z1020001.html
theadmiral976 is offline   Reply With Quote
Old 07-22-2019, 03:12 AM   #4
Grey86
Grey86's Avatar
Drives: Tornato grey 86
have you looked at the rim itself ? it could be cracked ??
Grey86 is offline   Reply With Quote
Old 07-22-2019, 11:07 AM   #5
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Lift the whole front up, grab a flashlight and your gloves and have a REAL GOOD look.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Clicking noise from the rear Seiryuu Issues | Warranty | Recalls / TSB 18 05-17-2020 08:07 PM
Weird clicking sound when raising and or lowering the car with a jack juniorrr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-28-2019 11:25 PM
What is this OTHER clicking noise? radroach Issues | Warranty | Recalls / TSB 0 02-16-2019 01:10 PM
Eibach Sportline Weird Clicking Noise coming from car VeganGirl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-25-2016 03:19 PM
Clicking noise in engine bay teddydoggy Issues | Warranty | Recalls / TSB 4 08-12-2013 04:15 AM
