Old 07-21-2019, 06:11 PM   #15
cueball89
Drives: 15 Impreza
Where in NY are you? Are the battery terminals tight?
cueball89 is offline   Reply With Quote
Old 07-21-2019, 06:59 PM   #16
Snitko13
Drives: brz
so i just tried to disconnect the battery for 30+ min and still nothing
Snitko13 is offline   Reply With Quote
Old 07-21-2019, 07:00 PM   #17
Snitko13
Drives: brz
im in rochester and yes they are tightened down
Old 07-21-2019, 07:08 PM   #18
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
Try this.
http://www.ft86club.com/forums/showthread.php?p=3219936
Sent from my SM-G892A using Tapatalk
FRS13_ is offline   Reply With Quote
Old 07-21-2019, 07:32 PM   #19
steve99
Drives: FT86
Originally Posted by Snitko13 View Post
Hey, so I just recently got a 2013 brz back in March and finally was able to start modifying and just now installed invidia n2 fatback, front pipes over pipe and tomei uel headers. And when I go to start the car too see how it sounds, it starts but dies literally right away. And something doesnt make sense. The car was running perfectly fine before and all I did was change the exhaust. Do want to note that when I tried to disconnect the o2 sensors (wire connector side) when troubleshooting it would run and stay running but after a few seconds the rpms would start to jump between 1000-1500 rpms which I would say it's normal since no o2 sensors were connected. Also did put on some anti sieze on the threads of the o2 sensors and maybe some got on the inside without me knowing but none of this makes sense and tried to find something online and absolutely nothing. So some suggestions would be nice
The car should run fine on stock tune
You dont need to reset ecu
If the car wont stay running you have left something unplugged, either electrical cable or hose or you have damaged a sensor or wiring.
Old 07-21-2019, 07:41 PM   #20
Snitko13
Drives: brz
Originally Posted by FRS13_ View Post
Try this.
i gave the method a try that they explained but didnt work. worth a try but thanks for the link
Old 07-21-2019, 07:42 PM   #21
Snitko13
Drives: brz
thats what im thinking. ,im gnna get new o2 sensors tomorrow and give that a try and hope it works
Old 07-21-2019, 07:48 PM   #22
steve99
Drives: FT86
Hmmm that might be very expensive. You rearly need to test them first they may be ok.
Did you touch intake at all or any intake hoses .
The car should run with 02 sensors disconnected, will go into limp mode but should run.
You symptoms could be a big intake leak or intake hose disconnected
Old 07-21-2019, 07:50 PM   #23
Snitko13
Drives: brz
it does run without the o2 sensors connected. but i will check the intake area and see if anything is disconnected somehow
Old 07-21-2019, 07:51 PM   #24
Snitko13
Drives: brz
so idk if this matters but i tried to see if the car would run with only one o2 sensor and it does. its the one closest to the overpipe (one with black connector). might mean the other o2 sensor is bad. idk
its able to idle perfectly and go down to normal rpms at around 700 when it gets warmed up. but when i try to give it throttle it starts to die but stays on when i let go of throttle
Old 07-21-2019, 08:05 PM   #25
steve99
Drives: FT86
Click link
Go to engine hybrid system
Engine control
Then air fuel ratioo sensor ie front sensor
And heater o2 sensor ie rear sensor
Test as per instructions
These sensors are like $200 each
Test before replacing
https://demos.starbase7.net/t3Portal..._rm_index.html
Old 07-21-2019, 08:06 PM   #26
Grey86
Grey86's Avatar
Drives: Tornato grey 86
I think you've damage the o2 sensor while changing the exhaust, they can be very sensitive, with a slight knock they can be faulty. but still doesn't explain why the car shuts off right away since you can run fine with only one.
long shot but are all the grounds connected? have you accidentally swapped any plugs, or accidentally have the o2 sensors cables swapped around ?
Grey86 is offline   Reply With Quote
Old 07-21-2019, 08:11 PM   #27
Snitko13
Drives: brz
so now after the car was running perfectly fine for a couple min with only 1 o2 sensor, it died on its own and now its only cranking
Old 07-21-2019, 08:11 PM   #28
Snitko13
Drives: brz
Click link
Engine control
ill give it a shot
BRZ wont start in hot weather! Coop Issues | Warranty | Recalls / TSB 3 06-28-2018 05:24 PM
INSTALLED TURBO, CAR WONT START Nightflo Forced Induction 23 06-23-2018 09:26 PM
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
car wont start after tune JesseTheFlash Software Tuning 7 12-17-2014 12:43 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 01:01 AM
