Old 07-21-2019, 04:06 AM   #1
Snitko13
Drives: brz
New headers installed but car wont start
Hey, so I just recently got a 2013 brz back in March and finally was able to start modifying and just now installed invidia n2 fatback, front pipes over pipe and tomei uel headers. And when I go to start the car too see how it sounds, it starts but dies literally right away. And something doesnt make sense. The car was running perfectly fine before and all I did was change the exhaust. Do want to note that when I tried to disconnect the o2 sensors (wire connector side) when troubleshooting it would run and stay running but after a few seconds the rpms would start to jump between 1000-1500 rpms which I would say it's normal since no o2 sensors were connected. Also did put on some anti sieze on the threads of the o2 sensors and maybe some got on the inside without me knowing but none of this makes sense and tried to find something online and absolutely nothing. So some suggestions would be nice
Snitko13 is offline   Reply With Quote
Old 07-21-2019, 11:00 AM   #2
Howaitoguru
Howaitoguru's Avatar
Drives: 2016 Subaru BRZ
Did you use new gaskets and torque everything?
Howaitoguru is offline   Reply With Quote
Old 07-21-2019, 11:10 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Check your MAF plug. Just disconnect it and plug it back in.
Also, did you apply a tune to the car in anticipation of the headers? The tune could have an issue if you did.
Also check that you didn't disconnect the cam sensor. It's in the immediate vicinity
Old 07-21-2019, 12:28 PM   #4
Snitko13
Drives: brz
I used new everything from gaskets to hardware and torqued everything.
Old 07-21-2019, 12:30 PM   #5
Snitko13
Drives: brz
And where would the cam sensor be located? Will definitely take a look. And no I didnt install a tune yet. I was thinking it shouldn't have an effect on it that much since I've seen tons of people run without one or at least be able to start it lol. But I was thinking that could he the issue somehow
Old 07-21-2019, 01:42 PM   #6
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
So you don't plan on running a tune with the full exhaust setup?
Will BRZ is offline   Reply With Quote
Old 07-21-2019, 02:18 PM   #7
If we assume that you did the minimum required work - didn't disassemble anything unnecessarily - the smart money is on some sort of electrical issue.
It doesn't need a tune to run. Don't sweat that.
Can you write up a list of exactly how you prepped for the job and what you took apart? That might help us come up with ideas. You might even have an 'oh shit' moment on your own.
Timmy_Jones (07-22-2019)
Old 07-21-2019, 03:25 PM   #8
This.
I suggest you take off the underneath plates and look and rethink what you did. I figure something needs to be plugged back in - what -
Ultramaroon (07-21-2019)
Old 07-21-2019, 03:53 PM   #9
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
i assume you disconnected the battery before doing the stock header removal and installation of aftermarket?
Try an ECU reset
DuMa is offline   Reply With Quote
The Following 2 Users Say Thank You to DuMa For This Useful Post:
humfrz (07-21-2019), Lantanafrs2 (07-21-2019)
Old 07-21-2019, 04:57 PM   #10
Snitko13
Drives: brz
I do plan on running a tune on the car shortly to get the most out of this setup. was planning on doing that next but now i need to fix this problem first then get the tune next
Old 07-21-2019, 04:57 PM   #11
Snitko13
Drives: brz
everything i took off was the shield thats right under the headers, then started by disconnecting the o2 sensors up in the engine bay and took out the header. then started to work my way back. and when it came to installing everything back in i started with the headers and also worked my way back. but no i didnt disconnect the battery. but when i was troubleshooting what was going on, i did disconnect the battery to reset the ecu but that was only for a couple minutes. dont know if i should have disconnected it longer or if it doesnt make a difference. I do plan on going to a dealer tomorrow and getting new o2 sensors maybe somehow i damaged them when installing them back in idk. but my guess is also something electrical
The Following 2 Users Say Thank You to Snitko13 For This Useful Post:
humfrz (07-21-2019), Ultramaroon (07-21-2019)
Old 07-21-2019, 05:31 PM   #12
Grady
Grady's Avatar
Disconnect you battery for longer/try to pull codes/clear codes/nothing you did should have disabled the engine. Check o2 connections.
Edit: leave battery disconnected for 30 min.
Old 07-21-2019, 05:41 PM   #13
Snitko13
Drives: brz
i will try that now and see what happens
Old 07-21-2019, 05:59 PM   #14
Snitko13
Drives: brz
wish i had a scan tool to be able to clear the codes tho. so i wont be able to do that
BRZ wont start in hot weather! Coop Issues | Warranty | Recalls / TSB 3 06-28-2018 05:24 PM
INSTALLED TURBO, CAR WONT START Nightflo Forced Induction 23 06-23-2018 09:26 PM
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
car wont start after tune JesseTheFlash Software Tuning 7 12-17-2014 12:43 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 01:01 AM
