Old 06-19-2012, 02:07 AM   #15
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
Originally Posted by Draco-REX View Post
S-Techs were one of, if not THE, worst springs to put on the Impreza. I'm not sure these will be any different.
Yup. They also sucked balls on one of my 240's.
GenkiElite is offline   Reply With Quote
Old 06-19-2012, 07:55 AM   #16
wcbjr
Drives: 2006 Subaru LGT
I'll let you all make your own choice, but here is some light reading.
http://forums.nasioc.com/forums/show...highlight=tein
wcbjr is offline   Reply With Quote
The Following User Says Thank You to wcbjr For This Useful Post:
chulooz (06-19-2012)
Old 06-19-2012, 12:26 PM   #17
Calidrifter
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
They werent that bad on my 240, but then again I had gr2's installed at the same time so I never had the chance to see how they were stock.
And with this car I don't want it slammed so i might go with something mild as far as springs. Either H. Techs, Eibach, or Tanabe.
Calidrifter is offline   Reply With Quote
Old 06-22-2012, 03:33 AM   #18
ThatGuy
Drives: R33 GTST - slightly modified.
They're pretty good on my R33 (with bilsteins).
You really can't judge by the product name - all s-techs are different (actually there are even different models for each car). I'd still recommend coilovers like KW.
ThatGuy is offline   Reply With Quote
Old 07-18-2012, 05:43 PM   #19
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I wouldn't get the Teins. I had them on a couple of my old 94-99 Celicas and they were perfect, but for the ZN6 I would stay with Eibach or RCE.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 07-18-2012, 07:34 PM   #20
wu_dot_com
Drives: accord
Originally Posted by wcbjr View Post
Say hi to your bumpstops for me.
Your stock struts will not be able to handle those springs. I tried those on my LGT with little success. And with the BRZ having even less shock travel, it'll be worse.
not ture. Tein just installed their S-tech spring on my BRZ last week with STOCK struts...
i dont know if the 18" will fit.
the car runs firm. the suspension was able to damped most bumps with just one oscillation.
wu_dot_com is offline   Reply With Quote
Old 07-18-2012, 07:39 PM   #21
os86
Drives: 2jz
Originally Posted by Reflections View Post
The Eibach Pro-Kit are always some great springs, generally enhancing the handling of your vehicle. They won't look slammed but it will give it a great stance.
What a lot of people miss out on is using cheaper sub $1000 coil overs, your really not getting added handling unless you properly align and corner balance. Sure you can get them stiff, and 'feel' like its on rails, but in reality handling limits would be compromised. Either get a solid spring-shock combo or quality coil overs.
This man speaks the truth. well said
os86 is offline   Reply With Quote
Old 07-18-2012, 07:45 PM   #22
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
Wait for SWIFT Springs USA; will be high quality; including, they are completely linear springs, giving you the most handling predictability, they use less material which results in less un-sprung mass, & SWIFT generally has a great track record for suspension =D
Any progressive rate spring like the S-Techs I usually consider as a for looks only kinda thing; some people may like that feeling, but a linear spring simply gives you a more direct feeling
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
Old 07-18-2012, 07:50 PM   #23
deucethemoose
You do know that the stock springs are also progressive, right?
The Following User Says Thank You to deucethemoose For This Useful Post:
DAEMANO (07-28-2013)
BRZ DRIVEN FULL REVIEW (lowering springs pics too) Racecomp Engineering BRZ First-Gen (2012+) — General Topics 99 12-14-2019 05:14 PM
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 08:12 PM
New Tein Product Announcement H-Tech Springs RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 06-24-2012 10:16 PM
Lowering springs? Jeff Lange Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-10-2012 11:36 PM
Anyone running Eibach lowering springs? Bahraini86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-01-2012 02:05 PM
