Old 04-17-2012, 11:09 PM   #1
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
New Tein Product Announcement H-Tech Springs
Just Announced from Tein Japan - Tein H-Tech Springs for the BRZ/FRS to be Released in May!
Spring Rate: 3.0k-Front spring rate: 4.6k-Rear spring rate
Drop Height: -25 mm Front -20mm Rear
We will release more info as it becomes available.
Thanks guys!
Rick
RallySport Direct is offline   Reply With Quote
Old 04-17-2012, 11:19 PM   #2
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
To translate into Imperial units, it's 258 lb/in front and 168 lb/in rear spring rates. This might be the closest yet to knowing the stock rates, as lowering springs can't deviate too much from stock without creating awful ride characteristics [i.e. bouncy].
Considering the front is a Mac Strut and the rear has some notable motion ratio, the wheel rate delta front to back is rather biased, with a very soft rear wheel rate. Does anyone have the rear motion ratio of the Impreza/WRX/STI?
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 04-17-2012, 11:58 PM   #3
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Still waiting for RCE to tell us their rates
uspspro is offline   Reply With Quote
Old 04-18-2012, 12:00 AM   #4
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
In general Subarus seem to be pretty highly sprung in the front compared to rear. This car they did the same, compared to Toyota. RCE bumps the rear rate a lot more than the fronts on their STI springs. IMO Subaru isn't very good at suspension tuning (as far as springs and dampers go).
I disagree that you can't change rates much on stock dampers. On the STI I know that the stock bounciness is actually caused by the car being undersprung for its dampers. Again, RCE raises their spring rates significantly front and back to get rid of the stock bounce. Just the backs even more so.
blu_ is offline   Reply With Quote
Old 04-18-2012, 10:48 AM   #5
Ryephile
Hot Dog
Ryephile's Avatar
Subaru's alleged tuning incompetence aside, most OEM's match their spring rates to the damper curves reasonably well. As such, deviating too far from OEM rates with OEM damper curves isn't a good idea. FWIW, "bouncy" or "floating" are used to describe underdamped situations, whereas "harsh" or "jolting" are descriptors for overdamped. The situation you're describing is an exception and not the norm.
In the end, it's all about matching the vehicles' parameters such that you achieve the desired wheel rate with the damping curve philosophy of your choice [be it "ideal" or not]. If Tein put the stock dampers on a dyno and found the stock spring rates to not be appropriate, they may feel it necessary to adjust the rates of their offering accordingly.
Old 04-18-2012, 11:12 AM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-18-2012, 11:23 AM   #7
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Sure, I was just chiming in with my layman input from experience. I don't think we are disagreeing after reading your post. Hopefully RCE will stop by and expand.
Old 04-18-2012, 02:05 PM   #8
Racecomp Engineering
nevermind, carry on.
Old 04-19-2012, 12:32 PM   #9
OrbitalEllipses
Drives: Attitude
I always thought it was common knowledge that S-Techs suck.
Old 04-19-2012, 02:09 PM   #10
Hachiroku
Administrator
Hachiroku's Avatar
Drives: Boxster 986
Let's keep the discussion on topic please - about springs.
Hachiroku is offline   Reply With Quote
Old 04-19-2012, 03:18 PM   #11
nibor33
nibor33's Avatar
Drives: SSM BRZ-L 6MT (gone)
Since RCE is here, and they have aftermarket springs, can you tell us the stock spring rates yet? And if that is part of an information embargo, can you tell us when the stock spring rates an be released?
Thank you.
nibor33 is offline   Reply With Quote
Old 04-19-2012, 03:28 PM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Damn I obviously missed some entertainment
In for stock spring rates though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-19-2012, 03:34 PM   #13
We'll start a different thread soon and keep this one on topic.
Old 04-19-2012, 04:01 PM   #14
Turbowned
Turbowned's Avatar
Needs moar low. I hope TRD Japan has more agressive springs like they used to offer in the 80's and 90's... Ones for the MK1 MR2 would lower it be 2.25"F and 1.75"R
tein
Tein Street Advance BRZ/GT-86/FR-S Coilovers Released in Japan JSC Speed Suspension | Chassis | Brakes -- Sponsored by 949 Racing 76 08-13-2014 08:50 AM
First 86 Winners - Prize Announcement MrBRZ Scion FR-S / Toyota 86 GT86 General Forum 52 03-04-2012 02:40 PM
Official Tokyo Motor Show announcement page? Guff Scion FR-S / Toyota 86 GT86 General Forum 152 11-30-2011 01:10 PM
Scion's big announcement!?! Coming on April 20. A-Spike Scion FR-S / Toyota 86 GT86 General Forum 152 03-30-2011 07:18 PM
