Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Members Classifieds > Transmission and Driveline
Old 07-18-2019, 05:38 PM   #1
86TOYO2k17
Drives: 2017 toyota 86
Sold
I have complete rear diff assembly that was professionally installed onto my 2017 86 with auto factory 4.5 final drive gears. I also upgraded to the Cusco solid pinion spacer instead of the stock crush washer at the same time.
5k miles on 4.5 FD gears 9k miles on the rest of diff assembly.
Gears are high quality with absolutely no gear whine or extra noise, which is the reason I paid more and opted for these gears instead of some others that have been known to be noisy and whine.
I paid about 650$ + a 50$ exchange rate fee (not shown on receipt but total paid showed on transaction) for 4.5 FD+Solid Spacer from RHDjapan
I purchased a low mileage 2017 FD assembly for 415$ on eBay that I installed into my car when pulling this 4.5 FD assembly off that is for sale now.
I had the shop initially do the entire install (pull pumpkin and install gears) for 900$ but was quoted 450$ if they just installed the gears.
So total value approximately 1565$
Selling 950$ OBO local pick up near Seattle WA - Everett WA area
Or 1100$ OBO shipped to lower 48 states.
For anyone doing the diff swap themselves. It is actually pretty quick and easy. Should be able to take your time and get diff pulled including setup in under an hour. Then reverse the steps for install.
Need
Jack stands
Jack
Various sockets i think 12-19mm
10mm hex key for plugs
Highly recommend axle puller tool for about 20$ makes removal and install of axles a breeze.
Put car on stands, remove muffler back exhaust, drain diff, put jack under rear diff jacking point, remove 4 bolts to driveshaft and move out of way, remove all 5 bolts on rear diff, slowly lower diff until it is about to be hanging from axles, pull axles (be careful especially when removing second axle not to knock diff off jack but if jack is positioned correctly it balances pretty well) now reverse steps for re assembly. I tried two other guides on here and ended up doing it this way, way easier and faster.
A video of this method done in under 15mins.
Old 07-18-2019, 07:13 PM   #2
jtcahill93
Drives: 2013 frs
How did you come about the value of 1500 if the parts only cost 560ish?
jtcahill93 is offline   Reply With Quote
Old 07-18-2019, 07:18 PM   #3
kch
Senior Misanthrope
kch's Avatar
700 for gears
415 for pumpkin
450 for install
Old 07-18-2019, 07:21 PM   #4
jtcahill93
Drives: 2013 frs
Originally Posted by kch View Post
700 for gears
415 for pumpkin
450 for install
The gears themselves arent 700. He also purchased a transmission mount. Not used for rear differentials. The gears were 506, and another 55 for the cusco pinion sleeve. All im saying gonna be hard getting over a grand for it. So glws
Old 07-18-2019, 07:38 PM   #5
86TOYO2k17
@jtcahill93
Oops a little off 761$ not 740$. Oh well close enough.
Old 07-18-2019, 10:34 PM   #6
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Im sorry but... did the 17 auto cars come with a 4.5 diff? or is he saying he got them installed from m-factory?
Clutch Dog is offline   Reply With Quote
Old 07-18-2019, 11:14 PM   #7
jtcahill93
Drives: 2013 frs
Originally Posted by 86TOYO2k17 View Post
@jtcahill93
But again you arent selling the cusco trans mount bushing so that price is irrelevant
Old 07-18-2019, 11:51 PM   #8
86TOYO2k17
Right which cost 40$. Even say 60$ With shipping and exchange rate etc. Hence the 700$ instead of 760$... pretty simple math.
Old 07-18-2019, 11:53 PM   #9
86TOYO2k17
Neither. A 2017 rear diff assembly with 9k miles with a auto factory (not mfactory, mfactory is whiny and loud.) 4.5final drive gear ratio already swapped in by a local shop with 5k miles on it.
Old 07-20-2019, 03:14 AM   #10
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
2017 comes with 4.3 from factory manual transmission.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 07-20-2019, 02:51 PM   #11
86TOYO2k17
EDIT, price adjustment + added brief install guide for easy DIY 2hour diff assembly swap.
Old 07-21-2019, 10:49 PM   #12
86TOYO2k17
Packaged ready to ship out, looks like about 150$ for shipping all the way across country to east coast.
Old 07-22-2019, 12:17 AM   #13
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Is it really that heavy?
Dr. BRZ is offline   Reply With Quote
Old 07-22-2019, 12:38 AM   #14
86TOYO2k17
Pallet + packaging + diff is 104lbs. Diff alone is probably a good 80lbs. Has to be on a pallet to ship safely. And pallet shipping is extra, plus extra for “lift gate” home pick up and “lift gate” home delivery. And WA to NY was about 150$. So I’m sure west coast/PNW is a lot cheaper.
4.5 final drive, complete final drive swap, fd swap, rear diff assembly
17+ MT Rear Diff Assembly 4.3 FD 86TOYO2k17 Want-To-Buy Requests 2 05-10-2020 02:04 PM
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Cleaning rear diff assembly housing 86TOYO2k17 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-11-2019 07:34 AM
opening 2017 brz foglight assembly Breadman Cosmetic Modification (Interior/Exterior/Lighting) 20 10-22-2018 10:02 PM
FS..complete stock rear diff Newfoundland_scion_frs Canada Classifieds 1 11-06-2015 05:00 PM
