Old 05-10-2019, 07:22 PM   #1
86TOYO2k17
Drives: 2017 toyota 86
Cleaning rear diff assembly housing
Decided to swap back to stock rear diff gear ratio, so picked up a used rear diff off eBay. Supposedly it’s off a 2017 with 1.6k miles but it’s pretty dirty and rusty at least the outside housing is.
Looking to try and clean it make it look relatively newish. And maybe do a thorough “flushing” out of the inside.
What’s the best way to clean all this?
What precautionary measures do I need to take?
The axles aren’t in obviously so I figure taping that off with a plastic bag, then a rust spray and wire brush then a thermal black paint after?
If I pressure wash it to clean it first does it matter if water gets inside the axle housing portion? What is the best way to clean/flush the inside? Just fill her up drain and fill again?
Old 05-10-2019, 07:57 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Hum... personally I'll just scrub it with simple green, slap it on, fill her up and call it a day.
But if i want it a bit pretty rattle can it.
I wouldn't even bother pressure washing it or even painting it. It's going to get dirty the moment you drive it.
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (05-11-2019)
Old 05-11-2019, 02:32 AM   #3
humfrz
Yep, I agree with ol @Mr.ac (this time - ).
I'd be more concerned about it being installed correctly rather than how it looks.
Of course, drain all the old oil out first and if it is full of metal shavings and is the color of chocolate milk -
humfrz
Old 05-11-2019, 07:34 AM   #4
new2subaru
Weight Weenie
Drives: 15 FR-S
Degreaser
Wire Brush
Acetone/Brake Clean, Etc
Rust paint
Good Enough
clean rear diff, cleaning rear end, rear diff assembly, rear diff rust
17+ MT Rear Diff Assembly 4.3 FD 86TOYO2k17 Want-To-Buy Requests 2 05-10-2020 02:04 PM
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Chameleon Glass Housing Projector Fog Assembly pansontw Exterior Parts - Lighting 20 12-14-2016 03:07 AM
Rear Hub Assembly? SsmoothyMonster Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-03-2013 02:13 AM
Cleaning the Rear Window Chewie4299 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 08-19-2012 02:18 PM
