Old 07-17-2019, 09:13 PM   #1
kev0
Drives: '14
Added E85. Ethanol Gauge didn't change?
Using Moto East's Flex fuel kit. I've been tuned for it as well. I added 11 gallons of E85 for the first time and started up my car. The car drives fine but my digital ethanol display gauge didn't change. Drove 2 miles home after that and it still didn't change.
Any suggestions? :/
kev0 is offline   Reply With Quote
Old 07-17-2019, 09:21 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Keep driving, it takes more than 2 miles
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
DarkPira7e (07-17-2019), kev0 (07-17-2019)
Old 07-17-2019, 09:25 PM   #3
kev0
Drives: '14
Oh okay. I didn't know it takes time to change. I thought it would be an instant reading. Thanks
The Following User Says Thank You to kev0 For This Useful Post:
Yoshoobaroo (07-17-2019)
Old 07-17-2019, 09:33 PM   #4
Yoshoobaroo
TRACKBREAD
Yea on my oft it takes almost 10 miles for my fuel trims so change.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
kev0 (07-17-2019)
Old 07-17-2019, 09:42 PM   #5
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
I think they recommend 75 miles for the tune to adjust fully. I got 5gallon of e85 to test then barely got to drive it lol
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
The Following User Says Thank You to Strife26 For This Useful Post:
kev0 (07-17-2019)
Old 07-17-2019, 11:14 PM   #6
steve99
Drives: FT86
The ethanol percent should start to change on guage in first few e of miles. Two might be a bit short but if you do 5 and nothing changes its a bit unusual
It may depemd on the port to direct injection ratio as you have to put your sensor in either the di or the port feed line. If your tune uses a lot of di down low put in di if it uses a lot of port put it in port line.
If its rear 02 flex kit log the rear 02 sensor volts, close to 0 volts means zero ethanol, close to 5 v means close to 85% ethanol in most cases
kev0 (07-17-2019)
Old 07-17-2019, 11:51 PM   #7
jflogerzi
jflogerzi's Avatar
What is your ecutek log seeing?
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
kev0 (07-17-2019)
Old 07-18-2019, 12:00 AM   #8
kev0
Drives: '14
It started reading correctly after about another mile of driving!
Thanks all.
Flex Fuel Gauge and Boost Control based on Ethanol Content DeliciousTuning Forced Induction 6 10-11-2022 05:37 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
Gauge Lights Change Color In Traction Off Mode dkrou351 Cosmetic Modification (Interior/Exterior/Lighting) 12 04-18-2013 08:49 PM
Everything I didn't like about the BRZ... Laika BRZ First-Gen (2012+) — General Topics 40 06-28-2012 11:00 AM
Nothing we didn't already know 315FR-S Scion FR-S / Toyota 86 GT86 General Forum 12 04-24-2012 11:06 PM
