Old 12-15-2017, 10:05 PM   #1
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Flex Fuel Gauge and Boost Control based on Ethanol Content
Hi Everyone,
Say hello to my little friend. He is still in the prototype stages but you kept asking for a gauge to work with our current line of Flex Fuel Kits and here it is. This unit will work with all Delicious Tuning Flex Fuel Kits roaming the marketplace.
[ame="https://www.youtube.com/watch?v=1DfbygQbBbs"]Flex Fuel Gauge and Something Else... - YouTube[/ame]
The other cool option we are debating on is boost control through the gauge. The feature would be a way of setting up boost control based on ethanol content and the user has full control of those settings. Let us know what you think and if you have any suggestions we are always listening.
Planned release is first quarter 2018.
Happy Holidays!
William Knose
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
86 South Africa (12-16-2017), CSG Mike (12-15-2017), Spawn_Of_Creation (02-06-2018)
Old 12-16-2017, 08:12 PM   #2
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
- Since the gauge will be controlling boost based on ethanol content, will this mean that the electronic boost controller signal and power connection will go directly to the gauge instead of plugging into the EVAP connection?
- If the boost controller is still going to be plugged into the EVAP connection then how will the gauge be manipulating the boost? T-ed into the vacuum lines, EBC to gauge then connected to EVAP connector or will the gauge be working off of a racerom map similar to the features on the ecutek bluetooth device?
- Will this be integrated with dynamic system safety system?
**If the boost controller plugs into the gauge only**
- Will the gauge be able to have boost by gear settings and/or boost by rpm settings added?
- If the gauge will not be doing the above and a racerom table is still needed for something like boost by gear or rpm would a 2nd E-Boost Controller still be needed at the EVAP connection?
TachyonBomb is offline   Reply With Quote
Old 02-05-2018, 09:44 PM   #3
DeliciousTuning
Sorry for the delay. It is a standalone system and does not need anything else (EcuTeK, RaceROM, etc...) to work correctly. Everything will be controllable from the gauge directly.
The Following User Says Thank You to DeliciousTuning For This Useful Post:
TachyonBomb (02-06-2018)
Old 01-17-2020, 11:04 AM   #4
Hicklinc
Drives: N/a
What ever happened with this
Sent from my SM-N950U using Tapatalk
Hicklinc is offline   Reply With Quote
Old 10-10-2022, 02:15 PM   #5
DeliciousTuning
Still in the works and getting close. Chip shortages have really slowed development and we had to make a few major revisions to get it to this point.
Currently the gauge will be designed for the following applications.
1. Flex Fuel Input & Output
2. Boost Pressure, Control, and Cut
3. Fuel Pressure
4. Oil Pressure
5. Coolant Pressure
6. Fuel Temperature
7. Oil Temperature
8. Coolant Temperature
The gauge itself incorporates a touch pad interface with no buttons. There will be a selection menu for what gauge you would like to use and how you would like to setup safety features.
aKaGorganZola (10-14-2022)
Old 10-10-2022, 05:40 PM   #6
dpfarr
Drives: BRZ ts
How difficult is getting an app showing up on Apple car play etc?
dpfarr is offline   Reply With Quote
Old 10-11-2022, 05:37 PM   #7
DeliciousTuning
Well if you can download our app into Apply Car Play or an Android device that has a Bluetooth connection you should be able to use our app. I have seen plenty of customers get it working on Android, but I have not seen it happen with Apple Car Play yet.
boost control, delicious tuning, e85, ethanol, gauge
Opensource Flex-Fuel Ethanol Content Analyzer with Bluetooth Fiskafan Software Tuning 26 05-13-2020 01:04 PM
Need advice!!! Low ethanol content and Racing fuel, ok to mix?? chazmuska Software Tuning 2 07-15-2017 04:39 AM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 09:40 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 06:43 PM
Making the switch to Ethanol, Flex Fuel Video Inside.... spdbydesign Forced Induction 0 05-23-2014 11:07 PM
