Old 07-11-2019, 10:56 AM   #309
Glitchy86
Drives: Red 86
Originally Posted by Vital View Post
Hmm thats a good question, i will let someone else chime in on if a 245/40 will fit, i assume you could run some negative and it might work. That might be an issue since your wheel is so wide i doubt you'd be able to run a lot of negative camber. You can buy any tuner lugnuts and it should fit you dont need fancy ones unless you just feel like spending money just get some decent ones with locks and you will be fine.
Just to be on the same page, for which wheel size do you mean the 245/40 won't fit? The 17×9 +38 or 18×9.5 +38?
And no I don't want to buy the fancy lugnuts. They cost alot tbh. If you know any good once that won't break the bank let me know.
Sent from my SM-G975F using Tapatalk
Glitchy86 is offline   Reply With Quote
Old 07-11-2019, 12:54 PM   #310
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Did you read the highlighted portion? And actually, you can just use the OEM lug nuts because they have a 60 Deg taper.
245/40-17 fit fine on stock height suspension. They just look awful because you're going to have a lot of poke and gap.
EndlessAzure is offline   Reply With Quote
The Following 3 Users Say Thank You to EndlessAzure For This Useful Post:
Glitchy86 (07-11-2019), Shizuka (07-11-2019), Vital (07-11-2019)
Old 07-11-2019, 01:48 PM   #311
Vital
Drives: 2015 BRZ
I apologize i re-read your post i honestly didnt even see you were considering the 17x9 wheel size. Yes, a 245/40/17 will fit on the 17x9 wheel on stock suspension just fine no issues there. As far as 18x9.5 +38 on stock you would need at least a 235/40/18 or 245/35/18 tire size to fit in the front. Hopefully this clears up some of the confusion. Also, keep in mind both of these tire sizes are going to poke up front on stock suspension.
The Following User Says Thank You to Vital For This Useful Post:
Old 07-11-2019, 02:16 PM   #312
Glitchy86
Drives: Red 86
I got you. Thanks again I appreciate it.
Old 07-11-2019, 02:19 PM   #313
Glitchy86
Drives: Red 86
Ya I'm going with the 17×9 +38 it seems the best option for me. Cheaper, lighter weight, cheaper tires and need less mods to get the perfect fitment.
Again thank you and I appreciate your help.
The Following User Says Thank You to Glitchy86 For This Useful Post:
Vital (07-11-2019)
Old 07-22-2019, 04:20 PM   #314
vas
Drives: Subaru BRZ
I need your guy's opinion.
I have a red 86 and was about to order the GL 57CR Gun Blue II 17×9 +38. And sadly they won't be available until late November and I'm not gonna wait that much.
So here is the available colors I can get and I'm not sure which one would look the best:
White
Eternal blue
E8 gold
Almite gold
Or should I get the 18×9.5 +38 in Gun Blue II? Not sure about the fitment for the 18s on stock suspension.
Where are you finding those wheels in stock?
vas is offline   Reply With Quote
Old 07-22-2019, 05:31 PM   #315
Glitchy86
Drives: Red 86
Sadly only found the white on stock at FT86speedfactory. And the rest will be on stock in November. Change my plans and about to order RPF1 it's much cheaper and lighter.
Old 07-24-2019, 05:21 PM   #316
vas
Drives: Subaru BRZ
FYI FT86SF just straight up doesn't say when they don't have wheels in stock on their website. I put an order down for Almite golds and they told me they'd be in stock late july. Now they're saying late August.
Old 07-24-2019, 07:11 PM   #317
Glitchy86
Drives: Red 86
That's why I'm always emailing them before making any purchase. They told me it will be available by the end of November.
That's why I scratched the whole idea of getting 57CR and going with the RPF1. Cheaper, lighter and it's in stock.
Old 07-26-2019, 01:12 PM   #318
vas
Drives: Subaru BRZ
Good call. After I pushed the customer support guy for a more definite ETA, he found out he was given some "incorrect info" previously and the new estimate is 4-5 months. Pretty shady IMO, now I have to get my money back.
Old 07-27-2019, 11:41 PM   #319
Glitchy86
Drives: Red 86
Now I'm rethinking to get the 57CR coz I red many ppl are complaining about the RPF1 bends and I don't want that.
Btw do you think I should save a little more and get the Wedssport or same my money?
Old 09-06-2019, 09:35 AM   #320
Glitchy86
Drives: Red 86
He guys,
Is anyone running 235/45R17 with 17×9 +38 57CR?
I know that the more popular size to run is 245/40R17 but I can't seem to find this size where I live.
I will be running Eibach pro kit 1" and some front camber bolts.
Thanks in advance.
Old 09-06-2019, 10:51 AM   #321
EndlessAzure
Wheels for Brains
He guys,
Thanks in advance.
45 is too tall. Go 235/40R17. I've run 235/40R17 on my Work CR Kiwami with same specs (17x9 +38), and there isn't enough rim protection for my liking. If I set the wheels down, the the rim is literally touching the ground. It's metal-on-metal when I stack the wheels.
245/40R17 is probably most ideal. I've only run 245/40R17 on my 57CR. With 245 sidewall, at least it sits on rubber when laid down.
Old 09-06-2019, 10:58 AM   #322
Glitchy86
Drives: Red 86
That's what I'm most afraid of is the wheel protection that's why I thought if I went with 235/45 would give me a little bit of more wheels protection.
I only tires I found for 245/40R17 is Continental SportContact 5 which I red that are not ideal for DD and found Hankook ventus S1 Evo 2 not sure how good they are.
2015 New Wheel | Gram Lights 57Transcend | Concave 10-Spoke Kami Speed Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 07-15-2019 05:47 PM
WTB Gram Lights CRBCelica Want-To-Buy Requests 0 03-16-2015 07:21 PM
Gram Lights 57s-pro on FRS? MrMarinakos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-27-2014 05:46 PM
Gram Lights in the GTA Skurj CANADA 3 11-22-2012 09:41 PM
gram lights 57s pro jdmboss86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-10-2012 12:58 AM
