Old 04-12-2019, 01:14 AM   #295
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Originally Posted by kch View Post
17x9 +38 with 245/40 Dunlop Z3s. Gunmetallic.
Ooo I've wanted a set of these for a while now. I've only seen Gun blue and black colors for the 57cr. Where did you find this color?
mistople is offline   Reply With Quote
Old 04-12-2019, 11:38 AM   #296
kch
Senior Misanthrope
kch's Avatar
Kevin Ket, but I forgot which distributor he uses. The gunmetallic is a special order (20 set minimum) but the distributor happened to have some on hand.
Edit: but don't make the same mistake I did. Get them in sakura pink. I wish I had done that.
Edit2: I should get the pinks and sell these to you 🤔
Old 04-12-2019, 11:52 AM   #297
mistople
mistople's Avatar
Edit2: I should get the pinks and sell these to you ��
Got it. I had the same special order situation with my gunmetal Weds.
Pink would be an awesome track day wheel, but I don't think I could copy @CSG Mike so soon PM me a price if you ever do want to sell!
Old 04-12-2019, 07:41 PM   #298
CSG Mike
CSG Mike's Avatar
There seems to be a bidding war for my set...
More can be made with enough demand.... you and @kch should PM @CounterSpace Garage and put down deposits... if 4 people commit, they'll absorb the fifth and make it happen!
Old 05-31-2019, 08:08 AM   #299
AllThePeat
Drives: 2019 Autox BRZ & 2021 GTI (Daily)
Anyone know where I can pickup some touch up paint for the gloss black wheels? Installed them last night and accidentally dropped the socket on the rim and it chipped
2019 BRZ | Autocross focused, CSG tuned w/Jackson racing C38 & PTuning flex fuel kit
2021 GTI | Daily
AllThePeat is offline   Reply With Quote
Old 05-31-2019, 08:36 AM   #300
Thunder86
Thunder86's Avatar
Drives: 2018 Toyota 86 GT trim (Thunder)
Did that to my Work wheels...
Sounds ridiculous, BUT... grab your GF and go to a ladies’ store. Pick up some nail base coat, the color that matches your wheel most, and some nail clear coat. Worked on the blue TE37Sls I had on my first car. Looked perfect for the few years it was on there.
Or ignore it like I do nowadays.
[insert poor quality, phone-taken picture here]
Thunder86 is offline   Reply With Quote
Old 05-31-2019, 11:30 PM   #301
AllThePeat
Ha — Awesome — that’s some ingenuity!
I’ll have to test that out — thanks man!
2021 GTI | Daily
Old 06-01-2019, 11:15 AM   #302
AllThePeat
Stock suspension until I pickup the CSG Spec TEINs...
17x9 +38 245/40 RE71R
2021 GTI | Daily
Old 07-10-2019, 02:54 PM   #303
Glitchy86
Drives: Red 86
I need your guy's opinion.
I have a red 86 and was about to order the GL 57CR Gun Blue II 17×9 +38. And sadly they won't be available until late November and I'm not gonna wait that much.
So here is the available colors I can get and I'm not sure which one would look the best:
White
Eternal blue
E8 gold
Almite gold
Or should I get the 18×9.5 +38 in Gun Blue II? Not sure about the fitment for the 18s on stock suspension.
Sent from my SM-G975F using Tapatalk
Glitchy86 is offline   Reply With Quote
Old 07-10-2019, 04:01 PM   #304
Vital
Drives: 2015 BRZ
White
Eternal blue
E8 gold
Almite gold
I think the Almite Gold would look with Red. As for as those wheels specs you can only fit a 235/40 or 245/35 tire size up front. Other than that it should fit stock suspension just fine and it will poke a bit too...
Old 07-10-2019, 04:06 PM   #305
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
White
Eternal blue
E8 gold
Almite gold
Hey! We have those wheels in stock and ready to ship!
https://www.kamispeed.com/products/g...00-gun-blue-ii
Let me know if interested
Joshua | KamiSpeed
Kami Speed is offline   Reply With Quote
Old 07-10-2019, 05:09 PM   #306
Glitchy86
Drives: Red 86
I'm leaning more towards the Eternal blue but still not sure tbh, I'm thinking about the Almite gold as well.
Are you sure I can't fit 245/40 on them with stock suspension?
Old 07-10-2019, 06:47 PM   #307
Glitchy86
Drives: Red 86
Any ideas on which lug nuts I should be getting for the 57CR? Should I go with an expensive ones? Like Project kics or Rays?
Old 07-11-2019, 09:31 AM   #308
Vital
Drives: 2015 BRZ
Hmm thats a good question, i will let someone else chime in on if a 245/40 will fit, i assume you could run some negative and it might work. That might be an issue since your wheel is so wide i doubt you'd be able to run a lot of negative camber. You can buy any tuner lugnuts and it should fit you dont need fancy ones unless you just feel like spending money just get some decent ones with locks and you will be fine.
2015 New Wheel | Gram Lights 57Transcend | Concave 10-Spoke Kami Speed Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 07-15-2019 05:47 PM
WTB Gram Lights CRBCelica Want-To-Buy Requests 0 03-16-2015 07:21 PM
Gram Lights 57s-pro on FRS? MrMarinakos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-27-2014 05:46 PM
Gram Lights in the GTA Skurj CANADA 3 11-22-2012 09:41 PM
gram lights 57s pro jdmboss86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-10-2012 12:58 AM
