Drives: 14 Limited BRZ
USB adapter for aftermarket HU
Hello all, I recently bought an aftermarket HU for my 14 BRZ. A Sony XAV-AX5000 with Android Auto and Apple CarPlay. The install was perfectly fine however an adapter is needed to retain the use of the OEM USB slot. There were two that said fit my car, one was a METRA AX-TOYUSB, the other was a Spiral audio UX-0007. In not sure why this is so difficult, has anyone had a similar problem when installing an aftermarket unit and can help me find the correct one I need? Thanks!
#3 | |
#4 |
Drives: 2016 BRZ Limited Pure Red
Crutchfield shipped the same incorrect METRA AX-TOYUSB one for my 2016 BRZ when I ordered an aftermarket head unit from them. That one is seems to be only for Toyota 86/FRS's.
For a BRZ USB port, you need Metra AX-SUBUSB2 for 2016 - up. For 2012 to 2015, it should be the Metra AX-SUBUSB, but you might want to take a look in your dash to confirm that your connector is the older one. AX-SUBUSB: ![]() AX-SUBUSB2:
#5 | |
#6 | |
Just the tip
Drives: 2017 DGM BRZ
We should be able to tell you for sure if you can take a picture of your connector end, as the subaru and toyota ones look quite different. Edit: METRA AX-TOYUSB is the same thing as the PAC USB-TY1 by the way. |
| The Following User Says Thank You to wolffbite For This Useful Post: | Slade (06-19-2018) |
#7 | |
Thanks so much, sorry for the late response, busy few days. Here is a picture of the adapter, hopefully it helps. Thanks again. |
#8 |
Certs You Dont Care About
Drives: 2013 Galaxy Blue BRZ
Correct me if I'm wrong, but isn't that the GPS connector? I remember the USB being gray and having symmetrical notches rather than the offset notches, not to mention it needs to connect 4 wires to the radio rather than a single shielded cable like the GPS has
| The Following User Says Thank You to sharpsicle For This Useful Post: | Slade (06-19-2018) |
#9 | |
Edit: I am so embarrassed. Thanks for clearing that up. I found the right connector and now my car play works perfectly! Thanks so much and for the record the one that fit my car was the spiral audio UX-0007, which is good because they were giving me a hard time about refunding lol. Thanks again! Last edited by Slade; 06-19-2018 at 10:01 PM. |
#10 |
#11 |
#12 | |
Drives: Blue BRZ
which manual did you use to install? i'm having a difficult time looking for an installation guide
#13 |
Sorry for the late reply. That may have been the problem though, I didn't use a manual to install, I have some knowledge of radio installation from my first car, an 04 accord.
#14 |
ProCrastinationConsultant
Yeah, these cars have a few more connectors than an 04 accord!
| USB adapter help | gpvecchi | Electronics | Audio | NAV | Infotainment | 6 | 02-06-2019 07:26 AM |
| Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic | ecko04 | Electronics | Audio | NAV | Infotainment | 10 | 05-05-2018 04:47 PM |
| Muteki Lug Adapter | Rifle | Mid-Atlantic | 1 | 01-18-2016 05:41 PM |
| DashCommand + BT1 adapter | Amadeus | Electronics | Audio | NAV | Infotainment | 5 | 09-09-2014 08:59 AM |
| Adapter help | lookchris | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-09-2013 11:39 AM |
