Old 06-22-2019, 05:14 PM   #1
Dylon
Drives: Scion FR-S
Engine Stalling During Cold Start
The other morning I went to start my car and when I did it started at 1,500 RPMs like normal, but after a few seconds the RMPs would bounce up to 2,000-2,500 and move around before dropping down to 600-800 and then stalling out. This happened 4-5 times and then I gave the car a few minutes and it started right up. It was about 60 degrees outside, which is the coolest weather I've personal ever ran the car in. The previous owner said it worked fine when he ran it in the cold last winter. He also mentioned he had the same problem one time with the same solution as I did, this has not happened to me since.
The car is a 2013 Scion FR-S with 51,000 miles on it. With the Greddy turbo charger kit on it, outfitted with duel catch cans and full blown oil cooler. I can't seem hear any vacuum leaks and all of the clamps are tight as well.
Any ideas?
Dylon is offline   Reply With Quote
Old 06-23-2019, 08:55 PM   #2
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
I would start by just cleaning your throttle body.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
The Following 2 Users Say Thank You to ActionMaxon For This Useful Post:
humfrz (06-24-2019), jcw99 (06-29-2019)
Old 06-24-2019, 12:24 AM   #3
Any ideas?
Welcome to our forum -
I wouldn't over react, maybe it was just having a bad start day.
Have you had the battery disconnected lately? If so, maybe the ECU was just re-learning.
Have you changed the type or source of fuel lately? If so, maybe you got some fuel with a little water in it.
Maybe it just don't like the turbocharger -
jcw99 (06-29-2019)
Old 06-28-2019, 09:42 AM   #4
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
Try this, it might help, or not.
http://www.ft86club.com/forums/showthread.php?p=3219936
Sent from my SM-G892A using Tapatalk
FRS13_ is offline   Reply With Quote
Old 06-29-2019, 01:05 PM   #5
Dylon
Drives: Scion FR-S
I will give that a shot thank you!
Cold Start, engine makes loud pop sound BTXP.XD Issues | Warranty | Recalls / TSB 10 05-20-2015 11:32 PM
Engine ignition missing upon cold start babydriver Engine, Exhaust, Transmission 4 02-06-2015 12:29 PM
[vehicle now fixed] Hot engine temperature reading on cold start, electrical? Joeystomato Issues | Warranty | Recalls / TSB 22 01-18-2015 10:29 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 07:06 AM
Stalling on the highway with push button start subiestyle BRZ First-Gen (2012+) — General Topics 18 02-17-2014 09:18 PM
