Old 06-19-2019, 01:43 PM   #4089
korhun
Database error
korhun's Avatar
For a 2018 BRZ Premium, do you recommend this setup for winter tires?
195 / 55
Rims: 16 x 6.5 ET 35
or should I prefer another dimensions?
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
korhun is offline   Reply With Quote
Old 06-19-2019, 02:18 PM   #4090
churchx
churchx's Avatar
Drives: 2014 GT86
I'd probably go for 195/60R16 (D +2.41% vs stock 215/45R17) (vs 195/55R16 that is -0.70%). Slight extra ground clearance/sidewall height (0.6in) won't hurt.
Also tire sizing is just one of things to consider, just as with summer types, tire model/vendor/type/compound matters more then that.
BTW, do you see winter weather at all in Turkey? Your location in profile somehow completely doesn't go in my mind along list of countries where winter tires might be needed :/
korhun (06-19-2019), Leonardo (06-19-2019)
Old 06-19-2019, 02:35 PM   #4091
korhun
Database error
korhun's Avatar
Thank you, 60 for better ground clearance is a good idea.. Our roads get worse in winter here (I mean holes etc.)
I'm in Ankara, in the center of Turkey. We must use winter tires by law. My house is outside the city, and it usually snows ~1 months to the city and ~1.5-2 months to my house I've used Continental winter tires in the past, and they were nice. What would you recommend?
Old 06-19-2019, 05:51 PM   #4092
churchx
churchx's Avatar
Drives: 2014 GT86
My choice for next winter will be michelin x-ice north 4 (from most reviews seem current best), for previous two winters were nokian hakkapeliita 8 (observed cons - easily loose studs when drifting and start only with 205 width). But they both are studded, thus banned in most mid-europe countries due damaging tarmac pavement. Studded do wonders if trackdays are on ice tracks though .
From non studded in country with actual snow & ice in winter i'd probably choose between michelin x-ice3, bridgestone blizzak ws80, nokian hakkapeliita r2.
About contis, i heard that they are good middle ground, not among very best leaders but also with no big cons, and that their studs last longer due being glued in. No own experience newer then 7 years and on this car with continental winter tires though.
Haven't studdied much "european" winter tires (of less sipes in thread, a bit harder compound, for better properties on clean roads vs snow/ice for which "nordic" winter tires concentrate on) / all-seasons, so not much i can say on those, just that given how careful you went with tire sizing choice and that you actually do have to drive over snow/ice, imho worth to not consider all-seasons. Such are better then summer tires, but still one can easily enough get stranded.
Probably i'll never consider misc. contraptions other then proper winter tires on these cars. Yes, sometimes snow chains/snow socks and alike things can provide even more grip, but most probably if one ever will need more grip then good winter tires provide, then one will not be able to drive these cars anyway, due their relatively low ground clearance. Bulldozer shaped front bumper will instead of sliding over soon accumulate big pile of snow in front, stopping car, if you'll try to drive in too deep of snow .
Tires aside, also worth in winter to carry in trunk some extra items set, eg. snow brush with ice scrape, towing rope, jumpstart wires, snow shovel. If not for oneself then to help others .
korhun (06-20-2019)
Old 07-10-2019, 09:52 PM   #4093
Glitchy86
Drives: Red 86
I'm about the get the Rays gram lights 57CR but still not sure if I should go with 17×9 +38 or 18×9.5 +38? I'm still on stock suspension and planning to get the RCE yellow lowering springs ( It's my daily and planning to do something drifting down the line)
I'm looking for the best option for handling and fitment. I want the option with the least amount of modifications I could make to get the perfect fitment.
Sent from my SM-G975F using Tapatalk
Glitchy86 is offline   Reply With Quote
Old 07-15-2019, 06:40 PM   #4094
Leonardo
Country Boy 4 Life
Leonardo's Avatar
17x9 +38 will weigh less and fit better with less mods required than 18x9.5 +38.
I'd get 245/40/17s for them. Also get camber bolts for the front; they are inexpensive, add grip, and install easy. I paid $19 for SPC 81305 camber bolts.
Good luck!
I LIKE TIRES!
Glitchy86 (07-15-2019)
Old 07-15-2019, 07:51 PM   #4095
Glitchy86
Drives: Red 86
Good luck!
Awesome. Thanks for the help, I appreciate it.
The Following User Says Thank You to Glitchy86 For This Useful Post:
Leonardo (07-18-2019)
Old 07-24-2019, 02:35 PM   #4096
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Has any tried RPF1 17x9 +45 on a wilwood superlite caliper? I know it will fit the barrel but dont have a set to check the spokes against. Any rubbing issues with tires either?
B T is offline   Reply With Quote
Old 07-24-2019, 02:38 PM   #4097
Leonardo
Country Boy 4 Life
Leonardo's Avatar
IDK about the brakes, but they will rub the spring perch if you are not on coilovers. Lots of guys run a +35 offset to give more room for camber, wider tires, and brake clearance.
I LIKE TIRES!
Old 07-24-2019, 03:08 PM   #4098
B T
RCE Tarmac 2 with camber plates, i just dont like the poke of the +35 as well as how much dirt it throws up
Old 07-27-2019, 12:27 PM   #4099
lumbeardjack
lumbeardjack's Avatar
Drives: 2017 Toyota 86
First time wheel buyer here.
I'm trying to get off of the stock Prius wheels and Michelin tires that my 2017 86 drove off the lot with. I checked out Fitment industries after watching some 'buying wheels 101' videos and my head is still spinning. BMX wheels were tough as it was when I was a kid lol.
I'm not looking to do performance yet, nothing competitive and the rest of the car is still stock
lumbeardjack is offline   Reply With Quote
Old 07-27-2019, 01:25 PM   #4100
churchx
churchx's Avatar
Drives: 2014 GT86
If you are not into HPDE/autox, i suggest to save money and keep using stockers till they are due to replacement. They are not THAT bad. Even more so, in stock car they might be more fun then grippier tires. Think of what tires (and if wheels) when these will need replacement.
Here, free money saving tip.
Old 07-27-2019, 11:27 PM   #4101
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
We’re in the same boat lol are you doing wheels and tires at the same time? Also will you leave the suspension stock or no?
Will BRZ is offline   Reply With Quote
Old 07-28-2019, 12:56 AM   #4102
lumbeardjack
suspension stays stock until I can get out of the part of town with curbs to go over and pot holes. I'm planning on wheels and tires at the same time just because I see dealers mount and balance for free and I do want to keep my original stock wheels for when I do decide to do something risqué
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
