#113 |
Drives: 17 Series Yellow BRZ
Didn't read through this entire thread, but has anyone used spacers with the 2017-2018 BRZ with the performance package wheels? Do 15 and 20mm spacers work on these cars with these wheels?
#114 |
If they don't have pockets like the old stock wheels, my guess yes but in the back I would get some longer aftermarket studs...
2013 Series 10 FRS #553
#115 |
Shitpost Generator v8.6
I am planning on running a 20f/25r setup. I am planning on getting the Eibach spacers from ft86speedfactory. Will these work with the stock wheels on my '13 fr-s?
Front: http://www.ft86speedfactory.com/eiba...cers-20mm.html Rear: http://www.ft86speedfactory.com/eiba...acer-1126.html |
#116 | |
Drives: Track preped NA FRS
#117 |
Drives: Scion FRS
Do you have to cut studs with 20mm spacers or will they fit fine without sticking through the spacer? I have 25mm in the back now
#118 | |
Country Boy 4 Life
Welcome to the forum! Yes you will have to cut them, unless your wheels have holes or "pockets" for the studs to stick into. For stock wheels, just go with 25mm front and 30mm rear spacers. Then they will just bolt on. I used a hacksaw to cut 10 studs. It took a solid hour of hacksawing. It's not on my list of things to do again! I'm on my 5th set of spacers... Good Luck!
I LIKE TIRES! |
#119 | |
Drives: 2017 BRZ
#120 | |
Drives: 2017 Toyota 86 860 Special Edition
#121 |
Drives: Toyota GT86 GTS
For people who have fitted 15mm on the front (OEM wheels with standard suspension) did you have to trim the stock studs or did they bolt on with no issues.
#122 |
Drives: 2017 SUBARU BRZ
@Jonboy73, 15mm spacers are too thin. I had them before. Go with 20mm-25mm to be safe.
The OEM wheels have deep pockets and I can see a 15mm working. Here is a pic of them.
"My teacher tells me real beauty is on the inside." "That's just something ugly people say." |
#123 | |
#124 | |
Drives: 2013 WRB BRZ
Edit: Going back one page in this tread, shows pockets. http://www.ft86club.com/forums/showp...&postcount=112
#125 |
Drives: 2017 Brz Series Yellow
I have 20f 25r
I would have probably preferred 15/20 but my spacers came as a set so I went with these.. |
| The Following User Says Thank You to BcRuZn For This Useful Post: | steel86gt (06-19-2019) |
#126 |
| Best springs+spacers for stock wheels? | retrosmiths | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 09-22-2015 08:52 AM |
| Spacers on all 4 corners / stock wheels (20mm/25mm) | zoltiz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 09-14-2015 11:43 AM |
| Spacers and stock wheel studs | solidONE | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-31-2013 08:55 AM |
| Stock Wheels Need Spacers? | theom | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-17-2013 11:49 AM |
| Spacers with Stock Wheels | Starscream15 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-05-2012 01:31 PM |
