Old 11-06-2018, 02:43 PM   #15
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
just a heads up... 150 bucks for the OLM version of this.
http://www.ft86speedfactory.com/olm-...-2017-brz.html
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
The Following 6 Users Say Thank You to Roadcone For This Useful Post:
5H1F7Y (11-07-2018), Akuma-ZN6 (02-05-2019), Busybee (06-16-2019), Irace86.2.0 (05-04-2019), Leonardo (11-06-2018), Victorscp (12-01-2018)
Old 04-05-2019, 04:45 PM   #16
STI-ish
STI-ish's Avatar
Drives: 13 BRZ Sport Tech Turbo
I'm doing the 2017 bumper upgrade on my 2013 and got the OLM ones for Xmas. I had fog lights, but I'm not putting them back in...
Forgive me if this is a dumb question...I know nothing about wiring or electrical type stuff
Is it possible to hook the vertical DRL's up to the fog light wiring?
STI-ish is offline   Reply With Quote
Old 04-29-2019, 05:50 PM   #17
Noction
Drives: 2018 BRZ Limited
Im thinking of getting these soon. What is the best way to install them? If you ground the negative and then just fuse splice them into the DRL fuse, would they turn on and off with the boomerang DRLs? What is the switch they come with for then?
Noction is offline   Reply With Quote
Old 06-18-2019, 12:22 AM   #18
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Originally Posted by Elliotw View Post
I basically cut the JDM harness in half. The harness goes from 4 wires into 2 wire, after the transition I cut the harness. From there I took the ground wire from the now cut harness added a terminal and grounded it to a bolt in the engine bay. Then I took the power wire from the harness into the cabin and used a fuse tap to tap it into the DRL fuse which is under the steering wheel. It's a 90% solution. The DRLs don't function exactly like the normal boomerangs. The JDM DRLs only run when the engine is running. and don't turn off with the hand brake.
If you want exactly the same behavior as the boomerang DRLs. You would ground wire in similar way as above. Then tap the power into the headlight wire that powers the DRLs. I didn't want to do this because the headlight wiring is not exposed. So you would have to cut open wiring loom.
If you need more detail let me know.
More photos:
Thanks for the information. I plan to get the JDM Kit which comes with all the harness and turn on/off switch (Ft86speedfactory $400)
I also got the interior panel and will mount it as the Japanese version.
Based on your description, do you have /use the switch that comes together with the kit?
Do you know whether the 2018/2019 have a prewiring to install the kit directly ?
Last question, does it to take out the bumper?
Thanks
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 06-18-2019, 01:34 PM   #19
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Thanks
I bought the same kit as you. If I remember correctly(which could be wrong since it was awhile ago). These aren't plug and play because the US cars have different harnesses under the steering wheel and for the lights. So where this kit would plug into there is no plug on US spec cars. So I think you'd either have to buy a JDM harness for under the steering column and for the lights. Other wise you'll have to make a custom harness.(you could use the JDM switch to the custom harness) Good luck on the mod one of my favorites!
Elliotw is offline   Reply With Quote
The Following User Says Thank You to Elliotw For This Useful Post:
Busybee (06-18-2019)
Old 06-18-2019, 04:29 PM   #20
Busybee
Busybee's Avatar
I bought the same kit as you. If I remember correctly(which could be wrong since it was awhile ago). These aren't plug and play because the US cars have different harnesses under the steering wheel and for the lights. So where this kit would plug into there is no plug on US spec cars. So I think you'd either have to buy a JDM harness for under the steering column and for the lights. Otherwise you'll have to make a custom harness.(you could use the JDM switch to the custom harness) Good luck on the mod one of my favorites!
Just got a little puzzled. The kit I will get is this:
https://www.ft86speedfactory.com/sub...l#.XQlI1Ov0mUk
and in the description, it says that all OEM compenents are inside. converting some of those harnessing that is included to a custom made is enough. Do I have to purchase any other harness? I thought they are all JDM and have everything inside the kit.
Thanks
Old 06-18-2019, 06:24 PM   #21
Elliotw
Elliotw's Avatar
Thanks
I was just sharing the fact that the US BRZ wiring harness doesn't have plug and play compatibility with this kit. I had to purchase additional wiring supplies to get this to work. I am not a wiring expert and so maybe I did something wrong.
Also I did not have to remove the bumper to install these lights.
Busybee (06-19-2019)
Old 06-19-2019, 10:58 AM   #22
Busybee
Busybee's Avatar
Dear Elliotw,
I really appreciate your time and the experience you shared. You are the only person I got information regarding these DRLs.
Thanks for the information and it will help me a lot.
Thanks again
The Following User Says Thank You to Busybee For This Useful Post:
Elliotw (06-19-2019)
Old 07-07-2019, 04:08 PM   #23
gpvg30
Drives: 2018 Subaru BRZ
Japanparts.com has the lights for $364 for the pair. Those are the original ones.
Quick question, off topic (sorry). The yellow brz, which side skirts do you have, they look great! Thanks
gpvg30 is offline   Reply With Quote
The Following User Says Thank You to gpvg30 For This Useful Post:
Busybee (07-10-2019)
Old 07-10-2019, 04:36 AM   #24
Busybee
Busybee's Avatar
2017+ Bumper Vertical DRLs
The shipping is around $30 + 364 = ~ $400
Same as the one that speedfactory has.
I think japanparts is selling the same.
I don’t know why the manufacturer part number H4517CA100 is not listed.
Old 07-25-2019, 03:30 PM   #25
BlaqkHavok
Drives: 2014 DGM BRZ
has anyone gotten the OLM one? if so how did you end up wiring it? also the power lead is the red wire with the fuse and the yellow is the ground?
BlaqkHavok is offline   Reply With Quote
Old 07-27-2019, 05:42 AM   #26
AndMsc
Drives: MY2018 GT86 EU
Is there a vertical DRL for stock bumper GT86 2017+ (Like the ones one the TRD bumper)?
AndMsc is offline   Reply With Quote
Old 08-24-2019, 11:46 PM   #27
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I don’t know if anyone has figured these out, but if not, I will be tackling this in a few weeks once I get my bumper back from being painted. I’m doing the MY17+ bumper conversion. I’m dropping my fog lights, and I’m hoping to wire these into the stock DRL harness, which hopefully will all work with my DD Always On kit.
Old 08-24-2019, 11:52 PM   #28
Busybee
Busybee's Avatar
which one are you getting? JDM or budget-friendly?
FS: 2017 86 Bumper Socal Akuma-ZN6 Exterior Parts (Aero, Lighting, Etc.) 2 03-16-2018 12:40 PM
2017 front bumper Jmk91 Cosmetic Modification (Interior/Exterior/Lighting) 19 12-13-2016 01:15 PM
WTB BRZ front end (bumper-whiteout, headlights, DRLs, and fog light) jupillam Exterior Parts (Aero, Lighting, Etc.) 0 06-12-2013 06:15 PM
Difference Between $3 DRLS and $40 DRLS? FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 14 12-31-2012 05:05 AM
