Old 05-21-2018, 12:35 AM   #1
Astroboy
Astroboy's Avatar
Drives: None
Does a built motor require a tune?
I was thinking about upgrading my rods valve springs and pistons and was wondering if i would need to get a tune right after? Im trying to get forged pistons with a cr of 10:1 and was wondering if I need a tune if im lowering the cr. I also have a turbo kit I'm going to install after installing the rods and pistons and valve springs. But if i don't require a tune for just the rods, pistons and valve springs than I wouldn't mind driving the car around with just a built motor in order to break everything in.
Thanks
Sent from my LG-H871 using Tapatalk
Astroboy is offline   Reply With Quote
Old 05-21-2018, 02:53 AM   #2
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
You are changing basically characteristics of your engine like pistons and compression ratio. You definitely need a tune, since the existing tune will not be optimal. Why don't you install the turbo kit together?
The Following 3 Users Say Thank You to nikitopo For This Useful Post:
Astroboy (05-21-2018), humfrz (05-21-2018), justint5387 (06-08-2019)
Old 05-21-2018, 09:31 PM   #3
Astroboy
Astroboy's Avatar
Drives: None
I didn't want to install the turbo kit because i wanted to break in the built motor first. But my tuner told me that the power goals im aiming for the stock components can handle. So i might just save my money instead
Old 05-21-2018, 09:48 PM   #4
Lantanafrs2
Drives: 2013 frs red
Christ, a stock motor requires a tune.
Lantanafrs2 is offline   Reply With Quote
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
jcw99 (06-08-2019), Sarang (06-10-2019)
Old 05-21-2018, 11:11 PM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Whether you have the turbo on or not, as long as you stay within the break in specs, nothing will go wrong. You drive it without a tune on lowered compression ratio, you will have more to worry about than a break in period.
MS, CSCS, TSAC-F, CPT
Old 05-26-2018, 04:41 PM   #6
shr133
shr133's Avatar
Drives: 2013 FRS
Thanks
The stock tune tune will work on a engine rebuild. If you lower the compression it will be safer than stock. The computer will also learn the new engine. If you are getting lots of porting work, changing valves and cams, you should get a tune sooner than later to play it safe...
That being said I would want at least a stage 1 tune and do a good data log to make sure nothing is out of wack. You don't want to burn up a new engine because the stock settings are too far off.
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 06-07-2019, 10:55 PM   #7
kimcheefists
kimcheefists's Avatar
Drives: 2017 BRZ PP
I apologize in advance for reviving an old thread but I just wanted to know if a newly built engine should start after only changing the compression ratio without a new base map. My car has been in the shop getting forged internals for the past couple months and now will not start..
kimcheefists is offline   Reply With Quote
Old 06-07-2019, 11:56 PM   #8
I'm guessing that the engine should start, maybe not run its best with the stock tune.
PS - I'd suggest you make sure the ECU is screwed down tight (grounded).
Old 06-08-2019, 03:34 AM   #9
Lantanafrs2
More like the amplifier box
Who has a built motor? Fabron757 Forced Induction 77 11-19-2020 10:04 PM
E-85 tune, does it require a new fuel pump? Tal Software Tuning 9 10-02-2015 03:03 AM
10.5:1 Built Motor. alexisfire02 Engine, Exhaust, Bolt-Ons 16 03-24-2015 10:06 AM
which built motor? Fabron757 Forced Induction 82 11-26-2013 10:08 AM
